restarting xorg
restarting xorg
Postby Skippy » Fri Jul 10, 2009 20:37
Hi - I wasn't sure if this is the correct forum for X org related questions.
I just updated to xorg-server-1.6.2 and I see that ctrl+alt+backspace no longer restarts X. Is this a bug or a feature?
thanks, Skippy
Skippy
Re: restarting xorg
Postby DHalens » Sat Jul 11, 2009 1:50
As far as I know, that key combination is disabled by default in xorg-server-1.6.X
Probably sabayon devs will activate it when adding that package version to entropy.
DHalens
Re: restarting xorg
Postby Skippy » Sun Jul 12, 2009 17:16
Interesting. For those who find this post with the same problem, try these solutions:
http://bbs.archlinux.org/viewtopic.php?id=73617
http://wiki.archlinux.org/index.php/Xor ... 27t_exit_X
Skippy
Re: restarting xorg
Postby Skippy » Tue Jul 21, 2009 16:22
I tried modifying my files as described at
Yet it still doesn't work. Anyone know why? Thanks all. Skippy
---- xorg.conf keyboard section -------------------------------------------
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
Option "AutoRepeat" "500 5"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
Option "XkbRules" "xorg"
# added lines below to get ctrl+alt+backspace to work
Option "XkbOptions" "terminate: ctrl_alt_bksp"
# Option "Dont Zap" "False"
# Macintosh keyboard
#Option "XkbOptions" "lv3:rwin_switch"
EndSection
----- xinitrc -----------------------------------------------------------
#!/bin/sh
# $Xorg: xinitrc.cpp,v 1.3 2000/08/17 19:54:30 cpqbld Exp $
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
xinitdir=/etc/X11
sysresources=$xinitdir/Xresources
sysmodmap=$xinitdir/Xmodmap
# added line below to make ctrl+alt+backspace work
setxkbmap -option terminate: ctrl_alt_bksp
# merge in defaults and keymaps
if [ -f $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -f $userresources ]; then
xrdb -merge $userresources
fi
if [ -f $usermodmap ]; then
xmodmap $usermodmap
fi
# First try ~/.xinitrc
if [ -f "$HOME/.xinitrc" ]; then
XINITRC="$HOME/.xinitrc"
if [ -x $XINITRC ]; then
# if the x bit is set on .xinitrc
# it means the xinitrc is not a
# shell script but something else
exec $XINITRC
else
exec /bin/sh "$HOME/.xinitrc"
fi
# If not present, try the system default
elif [ -n "`/etc/X11/chooser.sh`" ]; then
exec "`/etc/X11/chooser.sh`"
# Failsafe
else
# start some nice programs
twm &
xclock -geometry 50x50-1+1 &
xterm -geometry 80x50+494+51 &
xterm -geometry 80x20+494-0 &
exec xterm -geometry 80x66+0+0 -name login
fi
Skippy
