KDM freezes on Log Out [Solved]
pajamabama
Post by pajamabama » Wed Sep 24, 2008 4:10
Just wanted to post a solution I found to an issue that was introduced by the upgrade to KDE 3.5.10. I found that after the upgrade
1) the Sabayon kdm theme was not being used
and
2) Selecting 'End Session' was causing the system to log me out, but then freeze with just the X cursor showing, just before getting back to the kdm login screen. Shutdown/Reboot worked fine, just the log out failed.
Both are now solved.
1) Thanks to sjieke for this solution.
2) I added TerminateServer=true to the [X-:*-Core] section of kdmrc.
in /usr/kde/3.5/share/config/kdm/kdmrc:
[X-:*-Core]
AllowNullPasswd=true
AllowShutdown=All
NoPassEnable=false
NoPassUsers=
ServerArgsLocal=-nolisten tcp
ServerCmd=/usr/bin/X
TerminateServer=true                        <------- add this line
Hope this helps :cyclops:
HP dv6000t
SabayonLinux 5.5 - x86_64
www.pedorro.com
Re: KDM freezes on Log Out [Solved]
Post by wolfden » Wed Sep 24, 2008 8:48
sjieke
Post by sjieke » Wed Sep 24, 2008 11:05
Thx,
I was looking for a fix but hadn't found one yet. Now my logout problem is also solved :alien:
Post by Fitzcarraldo » Wed Sep 24, 2008 11:30
pajamabama wrote:2) I added TerminateServer=true to the [X-:*-Core] section of kdmrc.
[X-:*-Core]
AllowShutdown=All
NoPassEnable=false
NoPassUsers=
Strange: in /usr/kde/3.5/share/config/kdm/kdmrc on my PC the ServerCmd has an additional parameter:
ServerCmd=/usr/bin/X -br
sjieke
Post by sjieke » Wed Sep 24, 2008 12:00
I checked it and I also have the additional '-br' paramemeter.
The fix also works with the additional parameter, but I do wonder what it is for :?:
Post by Fitzcarraldo » Wed Sep 24, 2008 14:37
As a matter of fact, I don't have the problem of KDM freezing on logout, and adding "TerminateServer=true" makes no apparent difference in my case.
But I do have a problem when selecting Logout (as opposed to Shutdown Computer or Restart Computer): the screen goes blank, the usual KDM/SL login screen appears, I enter my password and my Desktop appears as expected, then Compiz-Fusion starts and... bang, my screen goes black and nothing responds any more (not Ctrl-Alt-F<n>, not Ctrl-Alt-Backspace, not Ctrl-Alt-Del). The only way I can recover is to power down my laptop and power it up again. (Shutdown Computer or Restart Computer both work fine, both with and without Compiz-Fusion enabled.) This happened under KDM 3.5.9 and still happens under 3.5.10-r1. Any ideas?
EDIT: Actually, after powering down and up again, I no longer have the problem, so adding TerminateServer=true did do the trick. So, thanks to you both for two good tips!
doom0r
Post by doom0r » Sat Sep 27, 2008 3:23
Thank you, pajamabama!
I was experiencing freezing on ending and sometimes on kdm reloading.
skiman
Post by skiman » Mon Sep 29, 2008 12:09
Hi everyone! i have same error with system freezing when trying to logout in kdm or other logon manager gdm for example. When it freezing there is no mouse cursor it's just blank screen and system don't response for key pressing. Help me to fix it please!.
Sabayon 3.5 X86 kernel 2.6.25-sabayon-r1, laptop Toshiba A210-1AP, AMD Turion 2100mHz, 2Gb RAM, Video- ATI HD2600, 250Gb HDD SATA.
in Xorg log:
(WW) AIGLX:3D driver claims to not support visual 0x...
Warning: LookupDrawable()/SecurityLookupsDrawable() are deprecated. Please convert your driver/module to use dixLookupDrawable().
in messges:
APIC error on CPU0: 00(40)
APIC error on CPU0: 40(40)
when kernel is booting i can see that system trying find PCI and EISA devices.
Everything that doesn't kill you only makes you stronger!
Post by Fitzcarraldo » Mon Sep 29, 2008 13:48
^That looks like a completely different problem. Try booting with the noapic or acpi=off cheat codes to see if it helps.
http://wiki.sabayonlinux.org/index.php? ... heat_Codes
If one of those works, you can edit /boot/grub/grub.conf and make it permanent.
You could also try googling your error messages to see what comes up.
skiman
Post by skiman » Tue Oct 07, 2008 11:10
Fitzcarraldo wrote:^That looks like a completely different problem. Try booting with the noapic or acpi=off cheat codes to see if it helps.
It doesn't take effect.
