No working Firewall on recent install Disk?
andreios
Post by andreios » Fri Jan 16, 2015 15:32
I have setup a new Sabayon System from the daily DVD.
After installing I have setup the SSHD to listen on an non standard port.
I have opened this port with ufw.
Everything runs fine.
But after every restart I have no remote access to this computer anymore because iptales is setup to not let me in. I have to flush all iptables rules to get access.
But the strange thing is, i have even uninstalled ufw and also firewalld << don#t know why this was installed, but no change!
So what script is it that manipulates iptables rules on boot?
Re: No working Firewall on recent install Disk?
Post by Fitzcarraldo » Wed Jan 21, 2015 4:46
How did you 'uninstall' firewalld? Apparently it is not sufficient to do:
sytemctl disable firewalld
You need to do:
sytemctl mask firewalld
Then you can install, enable and configure ufw.
andreios
Post by andreios » Wed Jan 21, 2015 10:12
On an test System I have just diasabled and uninstalled both ufw and firewalld.
This has work on an test system with virtualbox, but not on this system for some reason.
