Installation of sabayon mate failed on ACER Helios 300
Postby jaguar1637 » Fri Dec 29, 2017 21:42
hi
I just recently bought a new portable, bcoz, my old one, under Sabayon was stolen, so it's ACER Predator helios 300 for gaming(Sabayon Mate is perfect for CS ;)
configuration a intel I7 core 8Gb w/ a SSD 256gb, the best to store CS binaries
so, I need to install the distribution Sabayon_Linux_16.11_amd64_MATE
but I suck while booting on a USB created by Unebuiltin
when I launch the following command "Default"
/ubnkern initrd=/ubninit overlayfs cdroot splash quiet --
the message I got
INFO: rcu_sched detected stalls on CPUs/tasks
o0-...: (2 GPs behind) idle=65e/0/0 softirq=26/26 fqs=0
o1-...: (5 GPs behind) idle=b62/0/0 softirq=15/17 fqs=0
o2-...: (1 GPs behind) idle=a5a/0/0 softirq=20/20 fqs=0
o5-...: (5 GPs behind) idle=794/0/0 softirq=16/18 fqs=0
o'detected by 3, t=60002 giffies, g=-287, c=288, q=30)
rcu_sched kthread starved for 60002 jiffies! g18446744073709551329 c18446744073709551328 f0x0 RCU_GP_WAIT_FQS(3) -> state=0x1
=> It seems to be a pb of screen detection
Please, help !
Ana
jaguar1637
Re: Installation of sabayon mate failed on ACER Helios 300
Postby jaguar1637 » Fri Dec 29, 2017 23:54
ooops I was installing an old release. Now, I am downloading the Sabayon linux 18.01 MATE.
I hope it should work better ;) .. wait and see
jaguar1637
Postby jaguar1637 » Sat Dec 30, 2017 10:48
nope
the installation w/ MATE rel 18.1 does not work
ok, I will starrt first by the installation of KDE rel 18.1
jaguar1637
Postby jaguar1637 » Sat Dec 30, 2017 11:48
well, the grapical card id an NVIDIA GEFORCE Gtx
and I tried to set up the xorg.conf w/ drive fbdev and also vesa
I got a poor screen, and no access to install SABAYON
Where can I find NVIDIA xorg "s examp es
bcoz it's pain in the ass to directly install sabayon where there is a NVIDIA graphical card
any help ?
jaguar1637
Postby jaguar1637 » Tue Jan 09, 2018 15:11
hi
Any ideas or help to tell people how to perform from scratch a new installation Sabayon Mate on a PC ACER with a Nividia graphic card ?
I know perfectly how to install a Nvidia driver, this issue regards just the launching of the installation (may be modification of the Xorg... grub configuration.... )
Please, help !
jaguar1637
Postby jaguar1637 » Fri Feb 02, 2018 23:29
Start sabayon 18.2 Mate
initrd=/boot/sabayon.igz overlayfs cdroot splash quiet -- sabayon opengl=nvidia
I got
sabayon:
root
# startx
X.Org X Server 1.19.5
kernel command line:
dovirtio vconsole.keymap=fr vconsole.keymap.variant=oss
Build Date: 06 November 2017
Current version of pixman: 0.34.0
ERROR; Error querying enabled displays on GPU 0(Missing Extension)
jaguar1637
Postby jaguar1637 » Mon Feb 05, 2018 0:59
I tried to put this file in /etc/X11/xorg.conf.d/20opengl.conf
Section "Files"
   ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "Module"
    SubSection  "extmod"
       Option    "omit xfree86-dga"
    EndSubSection
    Load    "i2c"
    Load    "ddc"
    Load    "vbe"
    Load    "dri"
   # Load    "glx"
#    Load    "synaptics" ### the cursed driver causing jumping mousepad on laptop issues #####
EndSection
Section "ServerFlags"
     Option    "AllowMouseOpenFail"    "true"
EndSection
Section "DRI"
    Mode 0666
EndSection
Section "ServerLayout"
    Identifier     "layout"
    Screen      0  "intel" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Keyboard0"
    Driver         "keyboard"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
    #Option         "DPMS"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
EndSection
Section "Device"
    Identifier     "intel"
    Driver         "modesetting"
    Option         "AccelMethod" "None"
    BusID          "PCI:[email protected]:2:0"
EndSection
Section "Screen"
    Identifier     "intel"
    Device         "intel"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "AllowEmptyInitialConfiguration" "on"
    Option         "IgnoreDisplayDevices" "CRT"
    Option         "ConstrainCursor" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section  "DRI"
   Mode 0666
EndSection
the windows show are stuborn, and there is no window manager as expected
but I got this message from /var/log/Xorg.0.log
[   917.769]
Release Date: 2017-10-12
[   917.771] X Protocol Version 11, Revision 0
[   917.771] Build Operating System: Linux 4.9.0-sabayon x86_64 Gentoo
[   917.772] Current Operating System: Linux sabayon 4.14.0-sabayon #1 SMP Sat Jan 20 20:57:13 UTC 2018 x86_64
[   917.772] Kernel command line: initrd=/boot/sabayon.igz overlayfs cdroot splash quiet -- res=1440x900 dovirtio vconsole.keymap=fr vconsole.keymap.variant=oss
[   917.773] Build Date: 06 November 2017  09:07:20AM
[   917.773]
[   917.774] Current version of pixman: 0.34.0
[   917.775]    Before reporting problems, check http://wiki.x.org
   to make sure that you have the latest version.
[   917.775] Markers: (--) probed, (**) from config file, (==) default setting,
   (++) from command line, (!!) notice, (II) informational,
   (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   917.777] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Feb  4 23:25:52 2018
[   917.778] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   917.779] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   917.779] (==) ServerLayout "layout"
[   917.779] (**) |-->Screen "intel" (0)
[   917.779] (**) |   |-->Monitor "Monitor0"
[   917.779] (**) |   |-->Device "intel"
[   917.779] (**) |   |-->GPUDevice "SabayonVga0"
[   917.779] (**) |   |-->GPUDevice "intel"
[   917.779] (**) |   |-->GPUDevice "nvidia"
[   917.779] (**) |-->Input Device "Keyboard0"
[   917.779] (**) |-->Input Device "Mouse0"
[   917.779] (**) Option "AllowMouseOpenFail" "true"
[   917.779] (==) Automatically adding devices
[   917.779] (==) Automatically enabling devices
[   917.779] (==) Automatically adding GPU devices
[   917.779] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   917.779] (WW) The directory "/usr/share/fonts/TTF/" does not exist.
[   917.779]    Entry deleted from font path.
[   917.779] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[   917.779] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[   917.779] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[   917.779]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[   917.779] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[   917.779]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[   917.779] (==) FontPath set to:
   /usr/share/fonts/misc/
[   917.779] (**) ModulePath set to "/usr/lib64/xorg/modules"
[   917.779] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   917.779] (WW) Disabling Keyboard0
[   917.779] (WW) Disabling Mouse0
[   917.779] (II) Loader magic: 0x556c9fa9ed20
[   917.779] (II) Module ABI versions:
[   917.779]    X.Org ANSI C Emulation: 0.4
[   917.779]    X.Org Video Driver: 23.0
[   917.779]    X.Org XInput driver : 24.1
[   917.779]    X.Org Server Extension : 10.0
[   917.780] (++) using VT number 1
[   917.780] (--) controlling tty is VT number 1, auto-enabling KeepTty
[   917.781] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[   917.781] (II) xfree86: Adding drm device (/dev/dri/card1)
[   917.781] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 10 paused 0
[   917.781] (II) xfree86: Adding drm device (/dev/dri/card0)
[   917.782] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[   917.783] (--) PCI:*(0:0:2:0) 8086:591b:1025:1208 rev 4, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[   917.783] (--) PCI: (0:1:0:0) 10de:1c20:1025:1207 rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[   917.783] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[   917.783] (II) LoadModule: "extmod"
[   917.783] (II) Module "extmod" already built-in
[   917.783] (II) LoadModule: "i2c"
[   917.783] (II) Module "i2c" already built-in
[   917.783] (II) LoadModule: "ddc"
[   917.783] (II) Module "ddc" already built-in
[   917.783] (II) LoadModule: "vbe"
[   917.783] (II) Loading /usr/lib64/xorg/modules/libvbe.so
[   917.783] (II) Module vbe: vendor="X.Org Foundation"
[   917.783]    compiled for 1.19.5, module version = 1.1.0
[   917.783]    ABI class: X.Org Video Driver, version 23.0
[   917.783] (II) LoadModule: "dri"
[   917.783] (II) Module "dri" already built-in
[   917.783] (II) LoadModule: "glx"
[   917.784] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[   917.785] (II) Module glx: vendor="X.Org Foundation"
[   917.785]    compiled for 1.19.5, module version = 1.0.0
[   917.785]    ABI class: X.Org Server Extension, version 10.0
[   917.785] (II) LoadModule: "modesetting"
[   917.785] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[   917.785] (II) Module modesetting: vendor="X.Org Foundation"
[   917.785]    compiled for 1.19.5, module version = 1.19.5
[   917.785]    Module class: X.Org Video Driver
[   917.785]    ABI class: X.Org Video Driver, version 23.0
[   917.785] (II) LoadModule: "nvidia"
[   917.785] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[   917.785] (II) Module nvidia: vendor="NVIDIA Corporation"
[   917.785]    compiled for 4.0.2, module version = 1.0.0
[   917.785] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   917.785] (II) NVIDIA dlloader X Driver  384.98  Thu Oct 26 14:06:45 PDT 2017
[   917.785] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   917.785] (II) modeset(0): using drv /dev/dri/card0
[   917.785] (WW) Falling back to old probe method for modesetting
[   917.785] (II) systemd-logind: releasing fd for 226:1
[   917.785] (II) Loading sub module "fb"
[   917.785] (II) LoadModule: "fb"
[   917.785] (II) Loading /usr/lib64/xorg/modules/libfb.so
[   917.785] (II) Module fb: vendor="X.Org Foundation"
[   917.785]    ABI class: X.Org ANSI C Emulation, version 0.4
[   917.785] (II) Loading sub module "wfb"
[   917.785] (II) LoadModule: "wfb"
[   917.786] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[   917.786] (II) Module wfb: vendor="X.Org Foundation"
[   917.786]    compiled for 1.19.5, module version = 1.0.0
[   917.786]    ABI class: X.Org ANSI C Emulation, version 0.4
[   917.786] (II) Loading sub module "ramdac"
[   917.786] (II) LoadModule: "ramdac"
[   917.786] (II) Module "ramdac" already built-in
[   917.786] (EE) Screen 1 deleted because of no matching config section.
[   917.786] (II) UnloadModule: "nvidia"
[   917.786] (II) UnloadSubModule: "wfb"
[   917.786] (II) UnloadSubModule: "fb"
[   917.786] (**) modeset(0): Depth 24, (--) framebuffer bpp 32
[   917.786] (**) modeset(0): Option "AccelMethod" "None"
[   917.786] (==) modeset(0): RGB weight 888
[   917.786] (==) modeset(0): Default visual is TrueColor
[   917.786] (**) modeset(0): glamor disabled
[   917.786] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[   917.786] (II) modeset(0): Double-buffered shadow updates: off
[   917.787] (II) modeset(0): Output eDP-1 using monitor section Monitor0
[   917.788] (II) modeset(0): EDID for output eDP-1
[   917.788] (II) modeset(0): Manufacturer: CMN  Model: 1738  Serial#: 0
[   917.788] (II) modeset(0): Year: 2014  Week: 47
[   917.788] (II) modeset(0): EDID Version: 1.4
[   917.788] (II) modeset(0): Digital Display Input
[   917.788] (II) modeset(0): 6 bits per channel
[   917.788] (II) modeset(0): Digital interface is DisplayPort
[   917.788] (II) modeset(0): Max Image Size [cm]: horiz.: 38  vert.: 21
[   917.788] (II) modeset(0): Gamma: 2.20
[   917.788] (II) modeset(0): No DPMS capabilities specified
[   917.788] (II) modeset(0): Supported color encodings: RGB 4:4:4
[   917.788] (II) modeset(0): First detailed timing is preferred mode
[   917.788] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[   917.788] (II) modeset(0): redX: 0.646 redY: 0.338   greenX: 0.316 greenY: 0.614
[   917.788] (II) modeset(0): blueX: 0.157 blueY: 0.044   whiteX: 0.313 whiteY: 0.329
[   917.788] (II) modeset(0): Manufacturer's mask: 0
[   917.788] (II) modeset(0): Supported detailed timing:
[   917.788] (II) modeset(0): clock: 152.8 MHz   Image Size:  381 x 214 mm
[   917.788] (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2250 h_border: 0
[   917.788] (II) modeset(0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1132 v_border: 0
[   917.788] (II) modeset(0):  N173HCE-E31
[   917.788] (II) modeset(0):  CMN
[   917.788] (II) modeset(0): EDID (in hex):
[   917.788] (II) modeset(0):    00ffffffffffff000dae381700000000
[   917.788] (II) modeset(0):    2f1801049526157802a155a556519d28
[   917.788] (II) modeset(0):    0b505400000001010101010101010101
[   917.788] (II) modeset(0):    010101010101b43b804a713834403020
[   917.788] (II) modeset(0):    35007dd610000018000000fe004e3137
[   917.788] (II) modeset(0):    334843452d4533310a20000000fe0043
[   917.788] (II) modeset(0):    4d4e0a202020202020202020000000fe
[   917.788] (II) modeset(0):    004e3137334843452d4533310a200056
[   917.788] (II) modeset(0): Not using mode "1920x1080" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "800x600" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "400x300" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "1024x768" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "512x384" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "1280x960" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "640x480" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "1280x1024" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "640x512" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "896x672" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "928x696" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "960x720" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "1400x1050" (hsync out of range)
[   917.788] (II) modeset(0): Not using default mode "700x525" (hsync out of range)
[   917.788] (II) modeset(0): Printing probed modes for output eDP-1
[   917.788] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[   917.788] (II) modeset(0): Modeline "320x240"x60.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[   917.788] (II) modeset(0): Output eDP-1 connected
[   917.788] (II) modeset(0): Using exact sizes for initial modes
[   917.788] (II) modeset(0): Output eDP-1 using initial mode 640x480 +0+0
[   917.788] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[   917.788] (==) modeset(0): DPI set to (96, 96)
[   917.788] (II) Loading sub module "fb"
[   917.788] (II) LoadModule: "fb"
[   917.788] (II) Loading /usr/lib64/xorg/modules/libfb.so
[   917.788] (II) Module fb: vendor="X.Org Foundation"
[   917.788]    compiled for 1.19.5, module version = 1.0.0
[   917.788]    ABI class: X.Org ANSI C Emulation, version 0.4
[   917.788] (II) Loading sub module "shadow"
[   917.788] (II) LoadModule: "shadow"
[   917.789] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[   917.789] (II) Module shadow: vendor="X.Org Foundation"
[   917.789]    compiled for 1.19.5, module version = 1.1.0
[   917.789]    ABI class: X.Org ANSI C Emulation, version 0.4
[   917.789] (==) Depth 24 pixmap format is 32 bpp
[   917.789] (==) modeset(0): Backing store enabled
[   917.789] (==) modeset(0): Silken mouse enabled
[   917.789] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[   917.847] (==) modeset(0): DPMS enabled
[   917.847] (WW) modeset(0): Option "AllowEmptyInitialConfiguration" is not used
[   917.847] (WW) modeset(0): Option "IgnoreDisplayDevices" is not used
[   917.847] (WW) modeset(0): Option "ConstrainCursor" is not used
[   917.847] (--) RandR disabled
[   917.847] (II) AIGLX: Screen 0 is not DRI2 capable
[   917.847] (EE) AIGLX: reverting to software rendering
[   917.914] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[   917.914] (II) IGLX: Loaded and initialized swrast
[   917.914] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[   917.915] (II) modeset(0): Damage tracking initialized
[   917.915] (II) modeset(0): Setting screen physical size to 169 x 127
[   917.933] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[   917.933] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   917.933] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   917.933] (**) Power Button: Applying InputClass "joystick-all"
[   917.933] (II) LoadModule: "libinput"
[   917.933] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[   917.933] (II) Module libinput: vendor="X.Org Foundation"
[   917.933]    compiled for 1.19.5, module version = 0.26.0
[   917.933]    Module class: X.Org XInput Driver
[   917.933]    ABI class: X.Org XInput driver, version 24.1
[   917.933] (II) Using input driver 'libinput' for 'Power Button'
[   917.934] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 22 paused 0
[   917.934] (**) Power Button: always reports core events
[   917.934] (**) Option "Device" "/dev/input/event3"
[   917.934] (**) Option "_source" "server/udev"
[   917.934] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[   917.934] (II) event3  - (II) Power Button: (II) device is a keyboard
[   917.934] (II) event3  - (II) Power Button: (II) device removed
[   917.934] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[   917.934] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   917.935] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[   917.935] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   917.935] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   917.935] (**) Video Bus: Applying InputClass "joystick-all"
[   917.935] (II) Using input driver 'libinput' for 'Video Bus'
[   917.935] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 25 paused 0
[   917.935] (**) Video Bus: always reports core events
[   917.935] (**) Option "Device" "/dev/input/event6"
[   917.935] (**) Option "_source" "server/udev"
[   917.935] (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[   917.935] (II) event6  - (II) Video Bus: (II) device is a keyboard
[   917.935] (II) event6  - (II) Video Bus: (II) device removed
[   917.935] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input6/event6"
[   917.935] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   917.936] (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[   917.936] (II) event6  - (II) Video Bus: (II) device is a keyboard
[   917.936] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[   917.936] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   917.936] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   917.936] (**) Video Bus: Applying InputClass "joystick-all"
[   917.936] (II) Using input driver 'libinput' for 'Video Bus'
[   917.936] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 26 paused 0
[   917.936] (**) Video Bus: always reports core events
[   917.936] (**) Option "Device" "/dev/input/event5"
[   917.936] (**) Option "_source" "server/udev"
[   917.937] (II) event5  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[   917.937] (II) event5  - (II) Video Bus: (II) device is a keyboard
[   917.937] (II) event5  - (II) Video Bus: (II) device removed
[   917.937] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input5/event5"
[   917.937] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   917.937] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   917.937] (**) Lid Switch: Applying InputClass "joystick-all"
[   917.937] (II) No input driver specified, ignoring this device.
[   917.937] (II) This device may have been added with another device file.
[   917.937] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   917.937] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   917.937] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   917.937] (**) Power Button: Applying InputClass "joystick-all"
[   917.937] (II) Using input driver 'libinput' for 'Power Button'
[   917.938] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 27 paused 0
[   917.938] (**) Power Button: always reports core events
[   917.938] (**) Option "Device" "/dev/input/event2"
[   917.938] (**) Option "_source" "server/udev"
[   917.938] (II) event2  - (II) Power Button: (II) is tagged by udev as: Keyboard
[   917.938] (II) event2  - (II) Power Button: (II) device is a keyboard
[   917.938] (II) event2  - (II) Power Button: (II) device removed
[   917.938] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[   917.938] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[   917.939] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[   917.939] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   917.939] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   917.939] (**) Sleep Button: Applying InputClass "joystick-all"
[   917.939] (II) Using input driver 'libinput' for 'Sleep Button'
[   917.939] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 28 paused 0
[   917.939] (**) Sleep Button: always reports core events
[   917.939] (**) Option "Device" "/dev/input/event1"
[   917.939] (**) Option "_source" "server/udev"
[   917.939] (II) event1  - (II) Sleep Button: (II) is tagged by udev as: Keyboard
[   917.939] (II) event1  - (II) Sleep Button: (II) device is a keyboard
[   917.939] (II) event1  - (II) Sleep Button: (II) device removed
[   917.939] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[   917.939] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[   917.940] (II) event1  - (II) Sleep Button: (II) is tagged by udev as: Keyboard
[   917.940] (II) event1  - (II) Sleep Button: (II) device is a keyboard
[   917.940] (II) config/udev: Adding input device SOAI Gaming Mouse (/dev/input/event7)
[   917.940] (**) SOAI Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[   917.940] (**) SOAI Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[   917.940] (**) SOAI Gaming Mouse: Applying InputClass "joystick-all"
[   917.940] (II) Using input driver 'libinput' for 'SOAI Gaming Mouse'
[   917.941] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 29 paused 0
[   917.941] (**) SOAI Gaming Mouse: always reports core events
[   917.941] (**) Option "Device" "/dev/input/event7"
[   917.941] (**) Option "_source" "server/udev"
[   917.941] (II) event7  - (II) SOAI Gaming Mouse: (II) is tagged by udev as: Keyboard
[   917.941] (II) event7  - (II) SOAI Gaming Mouse: (II) device is a keyboard
[   917.941] (II) event7  - (II) SOAI Gaming Mouse: (II) device removed
[   917.941] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:1D57:AD03.0001/input/input7/event7"
[   917.941] (II) XINPUT: Adding extended input device "SOAI Gaming Mouse" (type: KEYBOARD, id 11)
[   917.942] (II) config/udev: Adding input device SOAI Gaming Mouse (/dev/input/event8)
[   917.942] (**) SOAI Gaming Mouse: Applying InputClass "evdev pointer catchall"
[   917.942] (**) SOAI Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[   917.942] (**) SOAI Gaming Mouse: Applying InputClass "libinput pointer catchall"
[   917.942] (**) SOAI Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[   917.942] (**) SOAI Gaming Mouse: Applying InputClass "joystick-all"
[   917.942] (II) Using input driver 'libinput' for 'SOAI Gaming Mouse'
[   917.942] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 30 paused 0
[   917.942] (**) SOAI Gaming Mouse: always reports core events
[   917.942] (**) Option "Device" "/dev/input/event8"
[   917.942] (**) Option "_source" "server/udev"
[   917.942] (II) event8  - (II) SOAI Gaming Mouse: (II) is tagged by udev as: Keyboard Mouse
[   917.942] (II) event8  - (II) SOAI Gaming Mouse: (II) device is a pointer
[   917.942] (II) event8  - (II) SOAI Gaming Mouse: (II) device is a keyboard
[   917.942] (II) event8  - (II) SOAI Gaming Mouse: (II) device removed
[   917.943] (II) libinput: SOAI Gaming Mouse: needs a virtual subdevice
[   917.943] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1D57:AD03.0002/input/input8/event8"
[   917.943] (II) XINPUT: Adding extended input device "SOAI Gaming Mouse" (type: MOUSE, id 12)
[   917.943] (**) Option "AccelerationScheme" "none"
[   917.943] (**) SOAI Gaming Mouse: (accel) selected scheme none/0
[   917.943] (**) SOAI Gaming Mouse: (accel) acceleration factor: 2.000
[   917.943] (**) SOAI Gaming Mouse: (accel) acceleration threshold: 4
[   917.943] (II) event8  - (II) SOAI Gaming Mouse: (II) is tagged by udev as: Keyboard Mouse
[   917.943] (II) event8  - (II) SOAI Gaming Mouse: (II) device is a pointer
[   917.943] (II) event8  - (II) SOAI Gaming Mouse: (II) device is a keyboard
[   917.943] (II) config/udev: Adding input device SOAI Gaming Mouse (/dev/input/mouse0)
[   917.943] (**) SOAI Gaming Mouse: Applying InputClass "joystick-all"
[   917.943] (II) No input driver specified, ignoring this device.
[   917.943] (II) This device may have been added with another device file.
[   917.943] (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event14)
[   917.943] (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
[   917.943] (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
[   917.943] (**) HD WebCam: HD WebCam: Applying InputClass "joystick-all"
[   917.943] (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
[   917.944] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 31 paused 0
[   917.944] (**) HD WebCam: HD WebCam: always reports core events
[   917.944] (**) Option "Device" "/dev/input/event14"
[   917.944] (**) Option "_source" "server/udev"
[   917.944] (II) event14 - (II) HD WebCam: HD WebCam: (II) is tagged by udev as: Keyboard
[   917.944] (II) event14 - (II) HD WebCam: HD WebCam: (II) device is a keyboard
[   917.944] (II) event14 - (II) HD WebCam: HD WebCam: (II) device removed
[   917.944] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input16/event14"
[   917.944] (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 13)
[   917.945] (II) event14 - (II) HD WebCam: HD WebCam: (II) is tagged by udev as: Keyboard
[   917.945] (II) event14 - (II) HD WebCam: HD WebCam: (II) device is a keyboard
[   917.945] (II) config/udev: Adding input device ELAN0501:01 04F3:3060 Touchpad (/dev/input/event11)
[   917.945] (**) ELAN0501:01 04F3:3060 Touchpad: Applying InputClass "evdev touchpad catchall"
[   917.945] (**) ELAN0501:01 04F3:3060 Touchpad: Applying InputClass "libinput touchpad catchall"
[   917.945] (**) ELAN0501:01 04F3:3060 Touchpad: Applying InputClass "joystick-all"
[   917.945] (**) ELAN0501:01 04F3:3060 Touchpad: Applying InputClass "touchpad catchall"
[   917.945] (**) ELAN0501:01 04F3:3060 Touchpad: Applying InputClass "Default clickpad buttons"
[   917.945] (II) LoadModule: "synaptics"
[   917.945] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[   917.945] (II) Module synaptics: vendor="X.Org Foundation"
[   917.945]    compiled for 1.19.5, module version = 1.9.0
[   917.945]    Module class: X.Org XInput Driver
[   917.945]    ABI class: X.Org XInput driver, version 24.1
[   917.945] (II) Using input driver 'synaptics' for 'ELAN0501:01 04F3:3060 Touchpad'
[   918.054] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 32 paused 0
[   918.054] (**) ELAN0501:01 04F3:3060 Touchpad: always reports core events
[   918.054] (**) Option "Device" "/dev/input/event11"
[   918.054] (II) synaptics: ELAN0501:01 04F3:3060 Touchpad: found clickpad property
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: x-axis range 0 - 3234 (res 32)
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: y-axis range 0 - 2342 (res 32)
[   918.054] (II) synaptics: ELAN0501:01 04F3:3060 Touchpad: device does not report pressure, will use touch data.
[   918.054] (II) synaptics: ELAN0501:01 04F3:3060 Touchpad: device does not report finger width.
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: buttons: left double triple
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: Vendor 0x4f3 Product 0x3060
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: invalid pressure range.  defaulting to 0 - 255
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: invalid finger width range.  defaulting to 0 - 15
[   918.054] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[   918.054] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: touchpad found
[   918.054] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-5/i2c-ELAN0501:01/0018:04F3:3060.0003/input/input14/event11"
[   918.054] (II) XINPUT: Adding extended input device "ELAN0501:01 04F3:3060 Touchpad" (type: TOUCHPAD, id 14)
[   918.054] (**) synaptics: ELAN0501:01 04F3:3060 Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[   918.054] (**) synaptics: ELAN0501:01 04F3:3060 Touchpad: (accel) MaxSpeed is now 1.75
[   918.054] (**) synaptics: ELAN0501:01 04F3:3060 Touchpad: (accel) AccelFactor is now 0.050
[   918.055] (**) ELAN0501:01 04F3:3060 Touchpad: (accel) keeping acceleration scheme 1
[   918.055] (**) ELAN0501:01 04F3:3060 Touchpad: (accel) acceleration profile 1
[   918.055] (**) ELAN0501:01 04F3:3060 Touchpad: (accel) acceleration factor: 2.000
[   918.055] (**) ELAN0501:01 04F3:3060 Touchpad: (accel) acceleration threshold: 4
[   918.055] (--) synaptics: ELAN0501:01 04F3:3060 Touchpad: touchpad found
[   918.055] (II) config/udev: Adding input device ELAN0501:01 04F3:3060 Touchpad (/dev/input/mouse1)
[   918.055] (**) ELAN0501:01 04F3:3060 Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
[   918.055] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event12)
[   918.055] (**) HDA Digital PCBeep: Applying InputClass "joystick-all"
[   918.055] (II) No input driver specified, ignoring this device.
[   918.055] (II) This device may have been added with another device file.
[   918.055] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[   918.055] (**) HDA Intel PCH Front Headphone: Applying InputClass "joystick-all"
[   918.056] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[   918.056] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   918.056] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   918.056] (**) AT Translated Set 2 keyboard: Applying InputClass "joystick-all"
[   918.056] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   918.056] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[   918.056] (**) AT Translated Set 2 keyboard: always reports core events
[   918.056] (**) Option "Device" "/dev/input/event4"
[   918.056] (**) Option "_source" "server/udev"
[   918.057] (II) event4  - (II) AT Translated Set 2 keyboard: (II) is tagged by udev as: Keyboard
[   918.057] (II) event4  - (II) AT Translated Set 2 keyboard: (II) device is a keyboard
[   918.057] (II) event4  - (II) AT Translated Set 2 keyboard: (II) device removed
[   918.057] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[   918.057] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[   918.057] (II) config/udev: Adding input device PC Speaker (/dev/input/event10)
[   918.057] (**) PC Speaker: Applying InputClass "joystick-all"
[   918.057] (II) No input driver specified, ignoring this device.
[   918.057] (II) This device may have been added with another device file.
[   918.058] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event9)
[   918.058] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   918.058] (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   918.058] (**) Acer WMI hotkeys: Applying InputClass "joystick-all"
[   918.058] (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
[   918.058] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 34 paused 0
[   918.058] (**) Acer WMI hotkeys: always reports core events
[   918.058] (**) Option "Device" "/dev/input/event9"
[   918.058] (**) Option "_source" "server/udev"
[   918.058] (II) event9  - (II) Acer WMI hotkeys: (II) is tagged by udev as: Keyboard
[   918.058] (II) event9  - (II) Acer WMI hotkeys: (II) device is a keyboard
[   918.059] (II) event9  - (II) Acer WMI hotkeys: (II) device removed
[   918.059] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event9"
[   918.059] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 16)
[   918.059] (II) event9  - (II) Acer WMI hotkeys: (II) is tagged by udev as: Keyboard
[   918.059] (II) event9  - (II) Acer WMI hotkeys: (II) device is a keyboard
[   918.063] (**) SOAI Gaming Mouse: Applying InputClass "evdev pointer catchall"
[   918.063] (**) SOAI Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[   918.063] (**) SOAI Gaming Mouse: Applying InputClass "libinput pointer catchall"
[   918.063] (**) SOAI Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[   918.063] (**) SOAI Gaming Mouse: Applying InputClass "joystick-all"
[   918.063] (II) Using input driver 'libinput' for 'SOAI Gaming Mouse'
[   918.063] (II) systemd-logind: returning pre-existing fd for /dev/input/event8 13:72
[   918.063] (**) SOAI Gaming Mouse: always reports core events
[   918.063] (**) Option "Device" "/dev/input/event8"
[   918.063] (**) Option "_source" "_driver/libinput"
[   918.063] (II) libinput: SOAI Gaming Mouse: is a virtual subdevice
[   918.063] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:1D57:AD03.0002/input/input8/event8"
[   918.063] (II) XINPUT: Adding extended input device "SOAI Gaming Mouse" (type: KEYBOARD, id 17)
[   921.182] (**) Option "fd" "22"
[   921.182] (II) event3  - (II) Power Button: (II) device removed
[   921.182] (**) Option "fd" "25"
[   921.182] (II) event6  - (II) Video Bus: (II) device removed
[   921.182] (**) Option "fd" "26"
[   921.182] (II) event5  - (II) Video Bus: (II) device removed
[   921.182] (**) Option "fd" "27"
[   921.182] (II) event2  - (II) Power Button: (II) device removed
[   921.182] (**) Option "fd" "28"
[   921.182] (II) event1  - (II) Sleep Button: (II) device removed
[   921.182] (**) Option "fd" "29"
[   921.182] (II) event7  - (II) SOAI Gaming Mouse: (II) device removed
[   921.182] (**) Option "fd" "30"
[   921.182] (**) Option "fd" "31"
[   921.182] (II) event14 - (II) HD WebCam: HD WebCam: (II) device removed
[   921.182] (**) Option "fd" "33"
[   921.182] (II) event4  - (II) AT Translated Set 2 keyboard: (II) device removed
[   921.182] (**) Option "fd" "34"
[   921.182] (II) event9  - (II) Acer WMI hotkeys: (II) device removed
[   921.182] (II) event8  - (II) SOAI Gaming Mouse: (II) device removed
[   921.182] (II) UnloadModule: "libinput"
[   921.182] (II) systemd-logind: not releasing fd for 13:72, still in use
[   921.182] (II) systemd-logind: releasing fd for 13:73
[   921.183] (II) UnloadModule: "libinput"
[   921.183] (II) systemd-logind: releasing fd for 13:68
[   921.183] (II) UnloadModule: "synaptics"
[   921.183] (II) systemd-logind: releasing fd for 13:75
[   921.183] (II) systemd-logind: releasing fd for 13:78
[   921.184] (II) UnloadModule: "libinput"
[   921.184] (II) systemd-logind: releasing fd for 13:72
[   921.184] (II) systemd-logind: releasing fd for 13:71
[   921.184] (II) systemd-logind: releasing fd for 13:65
[   921.184] (II) systemd-logind: releasing fd for 13:66
[   921.185] (II) UnloadModule: "libinput"
[   921.185] (II) systemd-logind: releasing fd for 13:69
[   921.185] (II) systemd-logind: releasing fd for 13:70
[   921.185] (II) systemd-logind: releasing fd for 13:67
[   922.516] (II) Server terminated successfully (0). Closing log file.
please, help
jaguar1637
