SpinBase Installation [Solved]
callmebreezy
Post by callmebreezy » Wed Mar 09, 2016 11:08
Hi there, I'm a recent sabayon linux convert, and I\m having problems with the SpinBase spin. from what i gather, you just need to input the installer command and the text installer will run, but this is not the case for me. I checked the md5sum of the iso and it matched, I even downloaded the SpinBase amd64 16.03 3 times to no success. It always says that "Installer command not found." The shell script doesn't also run, which is i tried by issuing "sh installer-text.sh" but still says that the file isn't found. I also followed the instructions at fitcarraldo's blog https://fitzcarraldoblog.wordpress.com/ ... installer/ but it still no success there also.
Thank you in advance!
P.S. : not really sure if this should also be posted here.
Re: SpinBase Installation
Post by wolfden » Wed Mar 09, 2016 12:04
When you boot the iso up, the boot menu has a selection for installation no? It's been forever since I looked at spinbase.
callmebreezy
Post by callmebreezy » Wed Mar 09, 2016 13:20
yes. it does have that, but it takes forever to start though, it only show the sabayon logo and that's that for hours.
Thank you for your time.
Post by wolfden » Wed Mar 09, 2016 13:32
hmmmm sounds like I will have to test it out and see what is going on.
Have you tried the minimal iso? It has the calamares installer in a fluxbox gui.
callmebreezy
Post by callmebreezy » Wed Mar 09, 2016 13:34
Yep, i tried it. but i wanted the spinbase though. I guess it's back to the minimal installation for me. Thank you!
Post by wolfden » Wed Mar 09, 2016 22:30
I double checked with others and they confirm there is no installer on spinbase.
Use server or minimal iso
callmebreezy
Post by callmebreezy » Thu Mar 10, 2016 8:33
Thank you wolfden!
