Installer not recognizing NVMe drive
magister94
Post by magister94 » Mon Dec 21, 2015 3:52
I've got an Intel 750 SSD installed. When I get to the partitions section of the install, the only thing I see under the 'Disk' dropdown is the flash drive I'm booting from and " - 0 B (/dev/sda)" which I assume is my Blu-ray drive.
I can mount and see the windows partition on the NVMe drive from /dev/nvme0n1, just not in the installer.
Seems like the installer is just ignoring it.
EDIT: im using sabayon v15.12
ruddy32
Re: Installer not recognizing NVMe drive
Post by ruddy32 » Tue Feb 16, 2016 7:54
I've the same problem using version 16.02. Any solution ?
Post by wolfden » Tue Feb 16, 2016 8:46
hmmmm, seems like it's an issue with others, some more info
https://forums.gentoo.org/viewtopic-p-7 ... f5c4dd8bb8
ruddy32
Post by ruddy32 » Wed Feb 17, 2016 22:51
I don't understand why booting Sabayon using usb live, the system detect nvme drive and then starting installer, the nvem device is not detected.
What's going wrong ?
Post by wolfden » Thu Feb 18, 2016 8:44
I don't know nor have the equipment to test it. :(
