Installation failed Sabayon 15.10 Gnome Command: mkswap
Postby knnwulf » Fri Oct 16, 2015 13:49
Hi all
In this last days I try to install Sabayon 15.10 Gnome 64 bit, but always when I try the installation fails. I have a screenshot of error. This happen with Sabayon 15.10 KDE 64 bit too. I create an usb boot with dd command. (dd if=ISO of=USB).
I have UEFI but I disabled. The partitions are manually and I have 3 partitions one for swap, another for / in ext4 and other for /home
Thanks and regards.
