Compiz-0.5.2
Compiz-0.5.2
Postby ashley194 » Tue Aug 14, 2007 20:36
I noticed on http://gentoo-portage.com that Compiz 0.5.2 was released today, here's the link http://gentoo-portage.com/x11-wm/compiz . Is there any easy way of upgrading to the latest 'n' greatest, ie. emerge -u beryl :D I know this might have been answered elsewhere, just want some clear & cut advice.
Thanks :D
ashley194
Postby wolfden » Wed Aug 15, 2007 2:12
Well you can follow this for the most part
http://www.sabayonlinux.org/forum/viewtopic.php?t=9352
You don't need to modify the ebuild, but you will need to uninstall everything, delete the git-sources and than add the xeffects overlay and emerge compiz. I remove the sabayon overlay before installing it tho, just to make sure I get the right ebuilds and than delete the xeffects overlay and than readd the sabayon overlay.
Postby wolfden » Wed Aug 15, 2007 12:08
Ok, here is what I did, do note the extra packages atlantis and screensaver:
Change back to the kwin window manager and close down fusion-icon
layman -d sabayon
layman -a xeffects
rm -rf /usr/portage/distfiles/git-src/*
echo "x11-libs/libX11 xcb" >> /etc/portage/package.use
echo "x11-libs/bcop **" >> /etc/portage/package.keywords
echo "x11-libs/compiz-bcop **" >> /etc/portage/package.keywords
echo "x11-plugins/compiz-fusion-plugins-atlantis **" >> /etc/portage/package.keywords
echo "x11-plugins/compiz-users-pafy-screensaver **" >> /etc/portage/package.keywords
emerge -C x11-libs/bcop x11-apps/ccsm x11-wm/compiz x11-libs/compiz-bcop x11-libs/compizconfig-backend-gconf x11-libs/compizconfig-backend-kconfig dev-python/compizconfig-python x11-wm/compiz-fusion x11-plugins/compiz-fusion-plugins-extra x11-plugins/compiz-fusion-plugins-main x11-plugins/compiz-fusion-plugins-threed x11-plugins/compiz-fusion-plugins-unsupported x11-apps/compiz-settings x11-apps/fusion-icon x11-libs/libcompizconfig
CFLAGS="-DNDEBUG" emerge x11-libs/libxcb
emerge x11-libs/compiz-bcop x11-apps/ccsm x11-wm/compiz  x11-libs/compizconfig-backend-gconf x11-libs/compizconfig-backend-kconfig dev-python/compizconfig-python x11-wm/compiz-fusion x11-plugins/compiz-fusion-plugins-extra x11-plugins/compiz-fusion-plugins-main x11-plugins/compiz-fusion-plugins-threed x11-plugins/compiz-fusion-plugins-unsupported x11-apps/compiz-settings x11-apps/fusion-icon x11-libs/libcompizconfig x11-plugins/compiz-fusion-plugins-atlantis x11-plugins/compiz-users-pafy-screensaver
layman -a sabayon
layman -d xeffects
emerge bcop
Postby ashley194 » Wed Aug 15, 2007 13:47
After shutting down compiz-fusion & changing into kwin, does all that code have to be entered in a terminal as root :? After that, will compiz-fusion start automatically following a reboot :? So many questions I know, just trying to fix it in my head.
Thanks wolfden :D
ashley194
Postby ashley194 » Wed Aug 15, 2007 22:03
Followed your advice, but now can't seem to start compiz-fusion at all :cry: Any thoughts, after a reboot?
Thanks!
ashley194
Postby ashley194 » Wed Aug 15, 2007 22:31
I still have no idea how to start compiz-fusion, so it's a case of backing-up my /home dir (31GB), wiping the lot & starting from scratch. As all my window handles have disappeared :?
ashley194
Postby wolfden » Thu Aug 16, 2007 0:01
It should auto start like it always did before
What is your window decorator?
what is your window manager?
All working great here
Postby jimonyzangs » Thu Aug 16, 2007 0:37
i went to update compiz-fusion just there now
checked overlay with eix, then added the overlay
within the few minutes i did this fusion-icon-0.5.2 has been removed from the overlay
so eix says its there but the only ebuild i can emerge is fusion-icon-9999
i updated the overlay in eix and its gone there now too
so maybe there was a problem with it and it was pulled
worst is i remove all of compiz-fusion before i went to update :wink:
i'll just have to wait and see
jimonyzangs
Postby wolfden » Thu Aug 16, 2007 1:02
ummmm, this method gets you the latest svn version which is always going to be 9999
Postby ashley194 » Thu Aug 16, 2007 6:43
Hi wolfden
After booting-up this morning, I still find myself in kwin. Normally my window decorator in compiz-fusion is emerald, but when I run the command 'compiz --replace' I loose my title bar. That's the very top bar, where the maximise/minimise buttons are, making dragging windows pretty tough :lol:
ashley194
