3.4e compiz fusion lockup [Solved]
Postby sjeter » Tue Aug 14, 2007 18:47
After the install, I updated a few things in kcontrol, like the mouse acceleration, power control, etc. but didn't do a kde restart until I was done. Then I did the restart, and two compiz fusion icons started. I selected quit for the second one. The Patience card game I had open wouldn't move - no wobbly - and a klipper instance showed up in the task bar (I did not run it before). Neither the windows key nor the mouse would start the kicker menu. I didn't know how to get out of this, so I reinstalled.
Does this problem have anything to do with the Nvidia driver?
http://sabayonlinux.org/forum/viewtopic.php?t=8944
I'm using Nvidia, but the install is the 32-bit, not the 64.
sjeter
3.48 compiz fusion lockup (Solved)
Postby sjeter » Wed Aug 15, 2007 4:32
I reinstalled without NFS and Secure Shell, and things seem to be hunky-dory - so far.
sjeter
Postby sjeter » Thu Aug 16, 2007 13:56
I spoke too soon - the problem is back. Nvidia card is EVGA 7800 GS.
sjeter
Re: 3.4e compiz fusion lockup [SOLVED]
Postby sjeter » Thu Aug 30, 2007 4:19
The problem was Kcontrol: "KDE Components --> Session Manager --> Restore manually saved session" was set. Once I saved the session before logout, it seems that it saved the whole desktop and caused the lockup.
sjeter
Postby wolfden » Thu Aug 30, 2007 4:22
so it's solved than or not?
Postby sjeter » Thu Aug 30, 2007 5:55
Yes - I modified the title but I guess that part didn't get posted.
sjeter
