missing libGL.so in SL 3.4e [Solved]
Postby pajamabama » Sat Aug 11, 2007 3:08
On the live dvd of SL 3.4e Second Life and Goolgle Earth won't launch because libGL.so is missing.
sabayonuser@sabayonx86-64 ~ $ googleearth
./googleearth-bin: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
sabayonuser@sabayonx86-64 ~ $ secondlife-bin
bin/do-not-directly-run-secondlife-bin: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
any ideas? Thanks.
also, Compiz seems to work perfectly.
HP dv6000t
SabayonLinux 5.5 - x86_64
www.pedorro.com
pajamabama
Postby davemc » Sat Aug 11, 2007 5:17
So install it?
Your talking about libglade right?
davemc
Postby pajamabama » Sat Aug 11, 2007 5:40
I don't think libglade is involved. libGL.so is the OpenGL library right? And libglade generates gui's?
And it makes sense that both Google Earth and Second Life would need OpenGL. I'm not sure they'd need dynamically generated gui's.
The other questions though are how does Compiz work? And, why isn't that library there? Maybe those apps are looking for another version of it?
HP dv6000t
www.pedorro.com
pajamabama
Postby pajamabama » Sat Aug 11, 2007 7:37
update:
Warsow does work. How is that? Why do some OpenGL apps work, and othes don't?
from the console output while running Warsow:
Using libGL.so.1 for OpenGL...Display initialization
HP dv6000t
www.pedorro.com
pajamabama
Postby lxnay » Sat Aug 11, 2007 8:17
What's the output of:
eselect opengl show
Follow me on Twitter
Add me on Facebook
Add me on Google+
lxnay
Land Owner
Postby AmpLiF1eR » Sat Aug 11, 2007 14:05
the output is 'nvidia' in my case... having the same issue on my installed 3.4e x64.
AmpLiF1eR
Postby lxnay » Sat Aug 11, 2007 14:15
emerge emul-linux-x86-xlibs (for x86-64) && eselect opengl set xorg-x11 && eselect opengl set nvidia
Add me on Facebook
Add me on Google+
lxnay
Land Owner
Postby gazal » Sat Aug 11, 2007 14:37
My 3.4e-64 is on HD, and Google Earth does not start.
The command fails:
SABAYON ~ # emerge emul-linux-x86-xlibs (for x86-64) && eselect opengl set xorg-x11 && eselect opengl set nvidia
-su: syntax error near unexpected token `('
gazal
Postby AmpLiF1eR » Sat Aug 11, 2007 17:21
gazal wrote:The command fails:
You have to remove the "(for x86-64)" from the code :)
(and delete the part in front of it also when you do not own the x64 version)
@lxnay, thanks but still the same output when starting googleearth.
gr.
Amp
AmpLiF1eR
Postby pajamabama » Sat Aug 11, 2007 17:21
sabayonx86-64 ~ # eselect opengl show
nvidia
got this while remerging emul-linux-x86-xlibs:
TEXTREL usr/lib32/opengl/xorg-x11/lib/libGL.so.1.2
 * QA Notice: The following files contain executable stacks
 *  Files with executable stacks will not work properly (or at all!)
 *  on some architectures/operating systems.  A bug should be filed
 *  at http://bugs.gentoo.org/ to make sure the file is fixed.
 *  For more information, see http://hardened.gentoo.org/gnu-stack.xml
 *  Please include this file in your report:
 *  /var/tmp/portage/app-emulation/emul-linux-x86-xlibs-10.0/temp/scanelf-execstack.log
 * --- --- RWX usr/lib32/opengl/xorg-x11/lib/libGL.so.1.2
the other two commands appear to have finished normally. But, Google Earth still fails in the same way.
One thing I'm seeing that may or may not be relevant is that the file that failed during emerge was libGL.so.1.2
Google Earth fails looking for libGL.so.1
Does this mean something?
HP dv6000t
www.pedorro.com
pajamabama
Users browsing this forum: PennyRoyal and 1 guest
