Sabayon Linux x86/x86-64 3.4 Revision E: Stable Release
This is the place where you can find all the Sabayon Linux Press Releases
Postby lxnay » Mon Aug 06, 2007 18:03
Press release: Sabayon Linux x86/x86-64 3.4 Revision E [Stable Release]
as in... "Entropy is not vapourware"
August 6th, 2007 - The Internet:
"Sabayon is an Italian dessert made with egg yolks, sugar, a sweet liquor (usually Marsala wine), and sometimes cream or whole eggs. It is a very light custard, which has been whipped to incorporate a large amount of air." Source: Wikipedia.
    Distribution updates:
  • Introduced a (teaser) pre-alpha release of the Entropy stack (Equo application)
  • Updated Portato to 0.8.0
  • Updated Compiz Fusion to work with XGL and AMD/ATI cards
  • Updated WINE to 0.9.42 and fixed Wine Doors
  • Reintroduced sudo after Install
  • Updated Second Life to 1.18.0.6
  • Fixed Partitioning issues on some system caused by dmraid stack (disabled by default now)
  • Reintroduced old and stable ipw3945 driver (keeping ipw4965 one)
  • Updated pommed to 1.7 (better MacBook support)
  • Reintroduced old bcm43xx wireless driver (disabling mac80211 one)
    Important Notes:
  • This distribution contains libdvdcss look here if you live in the U.S. !.
  • This distribution contains proprietary and non-GPL softwares too (like from NVIDIA, ATI, Google, etc). Before running them, be sure to read their license and agree with that, otherwise, just remove those applications. To run SabayonLinux without Proprietary drivers, just use "noproprietary" boot flag.
  • When you exit ColdWar or Sauerbraten the System will shut down automatically.
  • Trademarks are property of their respective owners, everywhere.
Contribute to our Wiki
Follow me on Twitter
lxnay
Land Owner
Land Owner
Postby wolfden » Mon Aug 06, 2007 18:06
x86_64
split -d -b 2000000000 SabayonLinux-x86_64-3.4a.iso sabayon.new.0
xdelta patch sl-x86_64-3.4a-to-3.4e-0.xdelta sabayon.new.000 new.000
xdelta patch sl-x86_64-3.4a-to-3.4e-1.xdelta sabayon.new.001 new.001
xdelta patch sl-x86_64-3.4a-to-3.4e-2.xdelta sabayon.new.002 new.002
cat new.00* > SabayonLinux-x86_64-3.4e.iso
md5sum SabayonLinux-x86_64-3.4e.iso
72dc873baef75200ed7eba97d6638d5b SabayonLinux-x86_64-3.4e.iso
x86
split -d -b 2000000000 SabayonLinux-x86-3.4a.iso sabayon.new.0
xdelta patch sl-x86-3.4a-to-3.4e-0.xdelta sabayon.new.000 new.000
xdelta patch sl-x86-3.4a-to-3.4e-1.xdelta sabayon.new.001 new.001
xdelta patch sl-x86-3.4a-to-3.4e-2.xdelta sabayon.new.002 new.002
cat new.00* > SabayonLinux-x86-3.4e.iso
md5sum SabayonLinux-x86-3.4e.iso
e902da21299736f52b075af58f0dc91c SabayonLinux-x86-3.4e.iso
Postby Element » Tue Aug 07, 2007 2:40
wolfden wrote:x86_64
x86
Thanks, saved me a lot of trouble.
On Sabayon @ Freenode: <ColdFlo> im not asking for support <ColdFlo> im asking for help
Element
Postby fhemeidan » Tue Aug 07, 2007 4:10
Thanks too...saved me a lot of time...
fhemeidan
Re: Sabayon Linux x86/x86-64 3.4 Revision E: Stable Release
Postby Louis » Tue Aug 07, 2007 12:55
Is it possible to upgrade from 3.4 to 3.4E?
Louis
Postby dave_p_b » Tue Aug 07, 2007 13:34
Hi
I'm either being really thick or really blind but I can't see the xdelta patches. Where are they? :oops:
Cheers
Dave
dave_p_b
Postby spiffytech » Tue Aug 07, 2007 13:35
The DVD's installer has an "upgrade" selection, which you can use to upgrade from 3.4a to 3.4e. I've never used it, though, so I can't comment on how well it works.
spiffytech
Postby Louis » Tue Aug 07, 2007 13:40
spiffytech wrote:The DVD's installer has an "upgrade" selection, which you can use to upgrade from 3.4a to 3.4e. I've never used it, though, so I can't comment on how well it works.
So thats means that I should burn a new DVD every mouth or more often.
Louis
Postby mktyap » Tue Aug 07, 2007 13:41
dave_p_b wrote:Hi
Cheers
Dave
ftp://bo.mirror.garr.it/mirrors/sabayonlinux/xdelta
mktyap
Postby Sergio1704 » Tue Aug 07, 2007 14:01
mktyap wrote:
dave_p_b wrote:Hi
Cheers
Dave
I wish I had realized it before :)
Sergio1704
Return to Press Releases
Users browsing this forum: No registered users and 0 guests
