Weather on Gnome Panel suddenly die...[Solved]
Postby alonsoty » Mon Jun 06, 2011 18:35
with latest updates (06 June) I've noticed there also present GnomePanel and some related libraries...
With this new version of panel the Weather applet and/or the Clock applet (if 'show weather' are set) suddenly died :cry:
I'm so lazy and I don't want to look out the window for the weather! :lol:
alonsoty
Re: Weather on Gnome Panel suddenly die...
Postby alonsoty » Mon Jun 06, 2011 21:19
I think I'm getting old! :cry:
or maybe my laptop tells me about the breaking will come!
I noticed that many other Gnome applications no longer worked after last updates.
I ran the mischievous programs from the terminal and I found that many schema files were gone! :shock:
In the end i've solved re-installing:
gnome-base/gsettings-desktop-schemas
it's a mystery :roll:
alonsoty
Re: Weather on Gnome Panel suddenly die...[Solved]
Postby joost » Tue Jun 07, 2011 6:57
Wow, same thing happened to me here.
:shock:
I noticed banshee would not start this morning.
jruis@k-02 ~ $ banshee-1
[Info  07:54:33.648] Running Banshee 1.8.1: [Gentoo/banshee/1.8.1 (linux-gnu, x86_64) @ 2011-06-07 06:27:21 UTC]
GLib-GIO-ERROR **: Settings schema 'org.gnome.system.proxy' is not installed
aborting...
Stacktrace:
  at (wrapper managed-to-native) Banshee.WebBrowser.OssiferSession.ossifer_session_initialize (intptr,Banshee.WebBrowser.OssiferSession/CookieJarChangedCallback) <0xffffffff>
  at Banshee.WebBrowser.OssiferSession.Initialize () <0x000af>
  at Banshee.WebBrowser.OssiferWebView..ctor () <0x00037>
  at Banshee.Wikipedia.WikipediaView..ctor () <0x00043>
  at Banshee.Wikipedia.ContextPage.get_Widget () <0x00033>
  at Banshee.ContextPane.ContextPane.AddPage (Banshee.ContextPane.BaseContextPage) <0x000d4>
  at Banshee.ContextPane.ContextPageManager.OnExtensionChanged (object,Mono.Addins.ExtensionNodeEventArgs) <0x000a3>
  at Mono.Addins.ExtensionNode.add_ExtensionNodeChanged (Mono.Addins.ExtensionNodeEventHandler) <0x0015d>
  at Mono.Addins.ExtensionContext.AddExtensionNodeHandler (string,Mono.Addins.ExtensionNodeEventHandler) <0x0003f>
  at Mono.Addins.AddinManager.AddExtensionNodeHandler (string,Mono.Addins.ExtensionNodeEventHandler) <0x0003b>
  at Banshee.ContextPane.ContextPageManager..ctor (Banshee.ContextPane.ContextPane) <0x00083>
  at Banshee.ContextPane.ContextPane..ctor () <0x0011b>
  at Nereid.ViewContainer.BuildHeader () <0x00517>
  at Nereid.ViewContainer..ctor () <0x00043>
  at Nereid.PlayerInterface.BuildViews () <0x000eb>
  at Nereid.PlayerInterface.BuildPrimaryLayout () <0x00043>
  at Nereid.PlayerInterface.OnShown () <0x00043>
  at Gtk.Widget.shown_cb (intptr) <0x0005a>
  at (wrapper native-to-managed) Gtk.Widget.shown_cb (intptr) <0xffffffff>
  at (wrapper managed-to-native) Gtk.Widget.gtk_widget_show (intptr) <0xffffffff>
  at Gtk.Widget.Show () <0x00013>
  at Banshee.Gui.BaseClientWindow.InitialShowPresent () <0x000bf>
  at Nereid.PlayerInterface.Initialize () <0x0000f>
  at Banshee.Gui.BaseClientWindow.InitializeWindow () <0x00013>
  at Banshee.Gui.BaseClientWindow..ctor (string,string,int,int) <0x00133>
  at Nereid.PlayerInterface..ctor () <0x00043>
  at (wrapper runtime-invoke) object.runtime_invoke_void__this__ (object,intptr,intptr,intptr) <0xffffffff>
  at (wrapper managed-to-native) System.Reflection.MonoCMethod.InternalInvoke (System.Reflection.MonoCMethod,object,object[],System.Exception&) <0xffffffff>
  at System.Reflection.MonoCMethod.Invoke (object,System.Reflection.BindingFlags,System.Reflection.Binder,object[],System.Globalization.CultureInfo) <0x001bb>
  at System.Reflection.MonoCMethod.Invoke (System.Reflection.BindingFlags,System.Reflection.Binder,object[],System.Globalization.CultureInfo) <0x0003d>
  at System.Reflection.ConstructorInfo.Invoke (object[]) <0x0003f>
  at System.Activator.CreateInstance (System.Type,bool) <0x00193>
  at System.Activator.CreateInstance (System.Type) <0x0000f>
  at Banshee.ServiceStack.ServiceManager.RegisterService (System.Type) <0x00047>
  at Banshee.ServiceStack.ServiceManager.Run () <0x0009b>
  at Banshee.ServiceStack.Application.Run () <0x0005f>
  at Banshee.Gui.GtkBaseClient.Initialize (bool) <0x002e3>
  at Banshee.Gui.GtkBaseClient..ctor (bool,string) <0x00033>
  at Banshee.Gui.GtkBaseClient..ctor () <0x0001b>
  at Nereid.Client..ctor () <0x0000f>
  at Banshee.Gui.GtkBaseClient.Startup () <0x0001b>
  at Hyena.Gui.CleanRoomStartup.Startup (Hyena.Gui.CleanRoomStartup/StartupInvocationHandler) <0x0008e>
  at Banshee.Gui.GtkBaseClient.Startup<T> () <0x00063>
  at Banshee.Gui.GtkBaseClient.Startup<T> (string[]) <0x000ff>
  at Nereid.Client.Main (string[]) <0x00017>
  at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
  at (wrapper managed-to-native) System.AppDomain.ExecuteAssembly (System.AppDomain,System.Reflection.Assembly,string[]) <0xffffffff>
  at System.AppDomain.ExecuteAssemblyInternal (System.Reflection.Assembly,string[]) <0x0003b>
  at System.AppDomain.ExecuteAssembly (string,System.Security.Policy.Evidence,string[]) <0x00037>
  at (wrapper remoting-invoke-with-check) System.AppDomain.ExecuteAssembly (string,System.Security.Policy.Evidence,string[]) <0xffffffff>
  at System.AppDomain.ExecuteAssembly (string) <0x0001f>
  at (wrapper remoting-invoke-with-check) System.AppDomain.ExecuteAssembly (string) <0xffffffff>
  at Booter.Booter.BootClient (string) <0x0006b>
  at Booter.Booter.Main () <0x001e3>
  at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
   banshee-1() [0x491d47]
   /lib64/libpthread.so.0(+0xf120) [0x7f711e7ab120]
   /lib64/libc.so.6(gsignal+0x35) [0x7f711e4741d5]
   /lib64/libc.so.6(abort+0x180) [0x7f711e475600]
   /usr/lib64/libglib-2.0.so.0(+0x4e41a) [0x7f7115ab541a]
   /usr/lib64/libglib-2.0.so.0(g_log+0x83) [0x7f7115ab54a3]
   /usr/lib64/libgio-2.0.so.0(+0x953fb) [0x7f71166893fb]
   /usr/lib64/libgio-2.0.so.0(+0x97a96) [0x7f711668ba96]
   /usr/lib64/libgobject-2.0.so.0(g_object_newv+0x827) [0x7f71161a01f7]
   /usr/lib64/libgobject-2.0.so.0(g_object_new_valist+0x1d1) [0x7f71161a0c51]
   /usr/lib64/libgobject-2.0.so.0(g_object_new+0xd1) [0x7f71161a0f51]
   /usr/lib64/gio/modules/libgiognomeproxy.so(+0x20ac) [0x7f71015450ac]
   /usr/lib64/libgobject-2.0.so.0(g_type_create_instance+0x573) [0x7f71161bf603]
   /usr/lib64/libgobject-2.0.so.0(+0x11f4c) [0x7f711619cf4c]
   /usr/lib64/libgobject-2.0.so.0(g_object_newv+0x8a1) [0x7f71161a0271]
   /usr/lib64/libgobject-2.0.so.0(g_object_new+0xec) [0x7f71161a0f6c]
   /usr/lib64/libgio-2.0.so.0(+0x64dc5) [0x7f7116658dc5]
   /usr/lib64/libglib-2.0.so.0(g_once_impl+0x5a) [0x7f7115ad39ca]
   /usr/lib64/libsoup-gnome-2.4.so.1(+0x288e) [0x7f710392f88e]
   /usr/lib64/libsoup-2.4.so.1(soup_session_add_feature_by_type+0xbc) [0x7f710370905c]
   /usr/lib64/banshee-1/libossifer.so(ossifer_session_initialize+0xe5) [0x7f7106bd37a5]
   [0x41520ce2]
Debug info from gdb:
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
After installing gnome-base/gsettings-desktop-schemas it was fixed. (it never was installed here)
Postby joost » Tue Jun 07, 2011 7:18
I think I found the solution.
gnome-base/gsettings-desktop-schemas gets pulled in when net-libs/glib-networking has the gnome useflag enabled.
Let me fix that in Entropy.
Postby alonsoty » Tue Jun 07, 2011 9:51
mmh... glib-networking! Probably yes
I not use banshee routinely, but I think the weather applet needs the "system.proxy.schema"...
Ciao :)
alonsoty
Postby joost » Tue Jun 07, 2011 9:55
All libsoup schemas got moved to gnome-base/gsettings-desktop-schemas.
net-libs/glib-networking was supposed to pull it in as a dep but it didn't because it SOMEHOW got compiled with the gnome useflag disabled.
Postby alonsoty » Tue Jun 07, 2011 10:01
all against Gnome ... sigh :cry:
alonsoty
Postby joost » Tue Jun 07, 2011 10:09
thx to your hint alonsoty I was able to track down the problem quickly.
:alien:
Postby Oranjer » Tue Jun 07, 2011 10:20
I faced this issue too and yes that solved by update the latest. :roll:
Oranjer
Postby alonsoty » Tue Jun 07, 2011 10:41
Joost, mine it's just a lucky approach! :wink:
...if I told you the times I've disintegrated my Gentoo by forcing about dependencies, you will laugh for hours and hours. :lol:
alonsoty
Users browsing this forum: No registered users and 0 guests
