Cant install from a overlay [Solved]
Package Managers that use Portage
Postby giannis12a » Sat Mar 13, 2010 9:45
Hallo to all,
i want the cwp ( customizable weather ) plasmoid and it is in overlay kde. I do emerge --sync , eix-update ,layman -S and all its ok. The package is masked by keywords.
pleiades giannis # eix customizable weather
* kde-misc/customizable-weather [1]
     Available versions:  (~)0.9.17 {debug}
     Homepage:            http://www.kde-look.org/content/show.php/Customizable+Weather+Plasmoid?content=98925
     Description:         KDE4 weather plasmoid. It aims to be highly customizable, but a little harder to setup.
[1] "kde" layman/kde
after in konsole to unmask the package
echo "=kde-misc/customizable-weather-0.9.17" >> /etc/portage/package.keywords
and the end
pleiades giannis # emerge -av =kde-misc/customizable-weather-0.9.17
* IMPORTANT: 3 news items need reading for repository 'gentoo'.
* Use eselect news to read news items.
emerge: there are no ebuilds to satisfy "=kde-misc/customizable-weather-0.9.17".
whats wrong here?
giannis12a
Re: Cant install from a overlay
Postby micia » Sat Mar 13, 2010 10:34
micia
Postby giannis12a » Sat Mar 13, 2010 21:13
hmm, i use the eselect new and have not notification for a new version of layman. :?
giannis12a
Postby Fitzcarraldo » Sat Mar 13, 2010 21:54
giannis12a wrote:hmm, i use the eselect new and have not notification for a new version of layman. :?
Then you've done something incorrectly.
# emerge --sync
# emerge -1v portage <---- DO NOT DO THIS IF YOU USE ENTROPY
# layman -S
# eselect news read all
Sabayon Linux amd64, kernel 2.6.34-sabayon (dual-boot Windows 7)
KDE 4.4.4
Mesh Edge DX
- Intel Core i7 720QM (1.6 GHz)
- 4 GB DDR3
- 15.6" LCD (1920x1080)
- ATI Mobility Radeon HD 5650, 1 GB GDDR3
- 320 GB HDD
- Intel WiFi Link 5300
- Broadcom BT
Postby giannis12a » Sat Mar 13, 2010 22:33
pleiades giannis # eselect news read all
2009-04-18-java-config-wrapper-0.16
  Title                     Generation 1 Java Setup Deprecated
  Author                    Petteri Räty <betelgeuse@gentoo.org>
  Posted                    2009-04-18
  Revision                  2
For a long time the Java team required a 1.4 JDK to be
installed in order for old java ebuilds to work. All these
ebuilds are now gone from the main tree so the requirement
to have a 1.4 JDK installed has been lifted.
In order to remove things left over by the generation 1
setup please run java-check-environment and follow the
instructions.
If you want to remove 1.4 JDKs, you should use emerge --depclean.
Depending on what you have installed you might not need a
1.4 JDK any more. To see if you still need a 1.4 JDK use:
emerge -av --depclean virtual/jdk:1.4
If you don't need virtual/jdk:1.4 any more then you can remove the
individual JDKs. First get the list of installed JDKs with
eselect and then remove those that are not needed any longer with
depclean, for example:
eselect java-vm list
emerge -av --depclean sun-jdk:1.4
2009-07-02-kdeprefix+monolithics
  Title                     kdeprefix and monolithic ebuilds issues
  Author                    Theo Chatzimichos <tampakrap@gentoo.org>
  Posted                    2009-07-02
  Revision                  1
The Gentoo KDE Guide has been updated and now covers the two most
serious issues affecting KDE users:
1) masking of the kdeprefix USE flag for KDE 4 users and
2) the upgrade of KDE 3 and KOffice 1.6.3 due to stabilisation to KDE
3.5.10 and KOffice 1.6.3_p20090204 for users of monolithic ebuilds.
Please refer to the guide [0] to solve those issues.
[0] http://www.gentoo.org/proj/en/desktop/kde/kde4-guide.xml
2010-02-21-mysql-upgrade
  Title                     MySQL 5.1 unmasking and upgrade procedures
  Author                    Robin H. Johnson <robbat2@gentoo.org>
  Posted                    2010-02-21
  Revision                  4
The 5.1 series of MySQL is going to be unmasked at the same time as the release
of this news item. When upgrading from an older major version (including 5.0),
you will be required to rebuild everything linked to the libmysqlclient.so.15
and libmysqlclient_r.so.15.
You can do this by installing app-portage/gentoolkit and running:
# revdep-rebuild --library libmysqlclient.so.15
# revdep-rebuild --library libmysqlclient_r.so.15
If you use the Portage 2.2 series, you may also use:
# emerge @preserved-rebuild
The official upgrade documentation is available here:
http://dev.mysql.com/doc/refman/5.1/en/upgrade.html
Note that existing databases may need converting as well, again including those
upgrading from 5.0 to 5.1. Details are in the update documentation.
nope :|
giannis12a
Postby giannis12a » Sat Mar 13, 2010 22:49
have you right. Done :D
giannis12a
Postby Fitzcarraldo » Sun Mar 14, 2010 14:11
Ianni, the reason you didn't see the advisory initially is because you had not 'synced' (synchronised) with the on-line Portage repositories. To keep up-to-date, roughly once a week you should do the following:
# emerge --sync
# layman -S
The command "emerge --sync" synchronises your PC with the main Portage repositories; the command "layman -S" synchronises you PC with any repositories of overlays that you have specified previously (which, as installed from the LiveDVD, will only be the Sabayon overlay).
If you use Entropy then you should ignore any message that is displayed when you do the "emerge --sync" telling you to update portage.
If you haven't already done so, I recommend that you read the articles on Portage and Entropy in the SL Wiki (see the link at the top right of this page).
KDE 4.4.4
Mesh Edge DX
- 4 GB DDR3
- 320 GB HDD
- Broadcom BT
Re: Cant install from a overlay [solved]
Postby splippity » Tue Apr 06, 2010 0:25
now is there no newer version anywhere??? I see 1.0.1 is out........
I installed this version 0.9.17 but at least for my area nothing works and I saw in 1.0.0 that weather.com has been fixed.
I tried weather.com and it didnt work
I tried accuweather and it didnt work
and no Ive tried myforecast.com with no luck
any help would be great.... thanks.
splippity
Postby splippity » Tue Apr 06, 2010 0:35
I actually got freemeteo.com to work but would still like a new version if we can......... Its a pretty nice lil app.
at least a few versions have gone by since this thing was added.....
splippity
Re: Cant install from a overlay [Solved]
Postby splippity » Tue Apr 06, 2010 20:50
I tell you what Im starting to think Im becoming a sabayon ninja....
anyway check out
http://bugs.gentoo.org/show_bug.cgi?id=308631
it has an ebuild for the newer customizable weather if you want 1.0.1
Though all I did was rename the ebuild I had and redid the manifest.
Now Im sporting the new 1.0.1 and all of the other weather sites work fine now......
just figured I would point it out.
splippity
Users browsing this forum: No registered users and 0 guests
