Problem tith instalation driver Avermedia tv tuner [Solved]
Hardware Related Issues
Postby wlodarek1 » Tue Feb 09, 2010 10:09
When i need install drivers for Avermedia VOLAR HX A827 [USB HYBRID tuner] i have this bug;
AVerMedia AVerTV Volar HX/AX/MAX Linux Driver Installer
?Kernel version error?
? Installer cannot determine kernel version or the running kernel is not  ?
? 2.6.x kernel.                                                            ?
? Installer will abort now.                                                ?
?                                <  OK  >                                ?
sabayon H826D_Installer_x86_0.10-Beta # uname -a
Linux sabayon 2.6.31-sabayon #1 SMP Tue Nov 17 19:04:56 UTC 2009 i686 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz GenuineIntel GNU/Linux
I installing package ; gcc , make , linux-sabayon-source ,
I write symlink "linux" in /usr/src/.
Not positive results ;
Please help me
wlodarek1
Re: Problem tith instalation driver Avermedia tv tuner
Postby Fitzcarraldo » Tue Feb 16, 2010 0:04
What do you get when you enter the following command as root user in a Konsole/Terminal window?
eselect kernel list
Sabayon Linux amd64, kernel 2.6.34-sabayon (dual-boot Windows 7)
KDE 4.4.4
Mesh Edge DX
- Intel Core i7 720QM (1.6 GHz)
- 4 GB DDR3
- 15.6" LCD (1920x1080)
- ATI Mobility Radeon HD 5650, 1 GB GDDR3
- 320 GB HDD
- Intel WiFi Link 5300
- Broadcom BT
Postby wlodarek1 » Tue Feb 16, 2010 11:23
I resolving problem ; installed new kernel 2.6.32-sabayon and your source .
In new kernel Avermedia driver installed properly :D
Why in kernel 2.6,31-sabayon is bugs :(
darek@sabayon ~ $ eselect kernel list
  [1]   linux-2.6.31-sabayon *
  [2]   linux-2.6.32-gentoo-r5
  [3]   linux-2.6.32-sabayon
darek@sabayon ~ $
wlodarek1
Postby Fitzcarraldo » Tue Feb 16, 2010 13:51
If you have installed the 2.6.32-sabayon kernel then the symlink should point to it, not to the 2.6.31-sabayon kernel. Therefore you need to do the following as root user in a Konsole/Terminal window:
eselect kernel set 3
See SL Wiki article HOWTO: Upgrade kernel using genkernel.
wlodarek1 wrote:and your source
It's not 'my' source. I'm not a Sabayon developer. I'm a forum moderator.
wlodarek1 wrote:Why in kernel 2.6,31-sabayon is bugs :(
It might not be a bug, it might simply be that all the files required (Linux sources and headers) for the 2.6.31-sabayon kernel were not on your HDD. Did you try re-building the 2.6.31-sabayon kernel (see SL Wiki article HOWTO: Upgrade kernel using genkernel)?
KDE 4.4.4
Mesh Edge DX
- 4 GB DDR3
- 320 GB HDD
- Broadcom BT
Postby wlodarek1 » Tue Feb 16, 2010 18:46
I wanted to recompile the kernel 2.6.31 but it jumped me such errors;
darek@sabayon ~ $ su -
Hasło:
sabayon ~ # cd /usr/src/linux-2.6.31-sabayon
sabayon linux-2.6.31-sabayon # genkernel --kernel-config=/usr/src/config --menuconfig --bootloader=grub --splash=sabayon --disklabel --lvm --luks all
* Gentoo Linux Genkernel; Version 3.4.10.907
* Running with options: --kernel-config=/usr/src/config --menuconfig --bootloader=grub --splash=sabayon --disklabel --lvm --luks all
* Linux Kernel 2.6.31-sabayon for x86...
* kernel: >> Running mrproper...
* ERROR: Failed to compile the "mrproper" target...
* -- Grepping log... --
Makefile:527: /usr/src/linux-2.6.31-sabayon/arch/x86/Makefile: Nie ma takiego pliku ani katalogu
make: *** Brak reguł do wykonania obiektu `/usr/src/linux-2.6.31-sabayon/arch/x86/Makefile'. Stop.
* -- End log... --
* Please consult /var/log/genkernel.log for more information and any
* errors that were reported above.
* Report any genkernel bugs to bugs.gentoo.org and
* assign your bug to genkernel@gentoo.org. Please include
* as much information as you can in your bug report; attaching
* /var/log/genkernel.log so that your issue can be dealt with effectively.
* Please do *not* report compilation failures as genkernel bugs!
When I wrote the "source" I thought about the package "linux-source " :D
wlodarek1
Return to Hardware
