Thanks & NVIDIA GEForce GT540M problem
Re: Thanks
Postby DeadlyWolf » Sat Jun 16, 2012 5:04
The error message maybe because of the bug, so I find I can get around it by starting Bumblebee with this command each reboot
# bumblebeed --daemon
Then optirun<whatever>
Linux User #521458.
DeadlyWolf
Re: Thanks & NVIDIA GEForce GT540M problem
Postby Fitzcarraldo » Sat Jun 16, 2012 11:39
I've given this thread a more meaningful title. Just having "Thanks" as the title does not reflect the thread at all.
Postby jgretired » Sun Jun 17, 2012 3:49
That is fine by me
jgretired
Postby st.toma » Wed Jun 20, 2012 6:26
i have the same card and if your computer is infact using optimus i can vouch that it works, it's quite simple in sabayon actually, but you probably still have to make sure you dont install nvidia-drivers or noveuo untill AFTER equo install bumblebee, rc-update add bumblebee, gpasswd -a *user* -g bumblebee. when you reboot you might have to type from su or sudo bumblebeed --daemon, i have to do that once every boot other wise i canot optirun anything.
st.toma
Previous
