installed dispcalGUI is not listed by equo & co
Postby msdobrescu » Sat Nov 24, 2012 8:46
I have switched from Datacolor Spyder 3 to X-Rite I1 Display Pro. Knowing that the support for the latter was added more recently than for Spyder 3, I have checked the installed software versions, i.e. Argyll CMS and dispcalGUI. I have found that installed dispcalGUI version is 0.9.9.1, by accessing the About dialog. Here I have an issue: the installed version is not listed by the equo command and no package manager finds it installed. Everything seems up to date. Sould I try to install dispcalGUI from the repo (1.1.0.0), over the existing one?
Thank you.
msdobrescu
Return to Entropy|Equo|Rigo Package Managers
