MP4 converter??
MP4 converter??
Postby ENNO » Sat Sep 01, 2007 12:23
Ok i wanna rip my dvd collection on to my comp and convert it to MP4 so i can slap it on my PS3....can sabayon do this?
ENNO
Re: MP4 converter??
Postby xlnagla » Sat Sep 01, 2007 13:53
Sabayon comes with a program called DVD::RIP, but I'm not sure if it support mp4... but google is always your friend, I'm sure there's some free software out there that will either go from DVD to mp4 or go from one of the formats DVD::RIP handles to mp4... and chances are that Sabayon can run whatever it is. If you have source of a linux build of the program, you'll always be golden, otherwise try emerge [packagename] when you find something you like to have portage handle the install.
xlnagla
Re: MP4 converter??
Postby chickenhawk » Sat Sep 01, 2007 15:28
The fastest way:
ffmpeg -vcodec xvid -b 1000 -qmax 10 -bufsize 8192 -g 300 -acodec aac
-ab 128 -ac 2 -i origin.avi -s 624x352 -aspect 4:3 output.mp4
If you want widescreen for some insane reason put 16:9 instead of 4:3.
Or you can use mencoder to make a Two pass encode of a DVD to an MPEG-4 ("DivX") AVI while encoding the audio track to MP3.
mencoder dvd://# -ovc lavc -lavcopts vpass=1 -oac mp3lame -o movie.avi
mencoder dvd://# -ovc lavc -lavcopts vpass=2 -oac mp3lame -o movie.avi
Two pass encode of a DVD to an MPEG-4 ("DivX") AVI while copying the audio track.
mencoder dvd://# -ovc lavc -lavcopts vpass=1 -oac copy -o movie.avi
mencoder dvd://# -ovc lavc -lavcopts vpass=2 -oac copy -o movie.avi
You will probably find it easiest to use dvdrip only to read the TOC contents on the DVD to find the track numbers you want to rip, sometimes mencoder automatically finds the one you want. When you do find it put the title number change the "#" to the number of the dvd title that you want to rip.
chickenhawk
Re: MP4 converter??
Postby Luna » Sat Oct 20, 2007 11:44
I am using aimersoft DVD to PSP converter, it works well for me, fast convertion speed and excellent output quality, that's greatful
Luna
