new flash beta
new flash beta
Postby junglist » Sun Aug 26, 2007 3:14
Does anyone know if gentoo has it in its portage tree and if it's possible to emerge -C, then emerge the beta without killing the pre set-up system for x32 firefox on x64 that sabayon already has?
More importantly is it worth the effort/risk?
Thanks.
junglist
Re: new flash beta
Postby WarraWarra » Sun Aug 26, 2007 4:03
http://gentoo-portage.com/Search?search=flash
Not sure if worth trying yet. Not sure how good / bad idea it is but would likely have to download a source tar ball and buil dit yourself ?
WarraWarra
Re: new flash beta
Postby junglist » Sun Aug 26, 2007 5:05
Thanks for the reply WarraWarra. i will search a little more.
junglist
Users browsing this forum: affirmedatheist and 1 guest
