need a c++ compiler
need a c++ compiler
Postby karlpox » Thu Aug 23, 2007 15:28
need a c++ compiler similar to Dev-C++? and how to install it since ive been trying to install kdevelop and anjuta but doesnt work. :cry:
karlpox
Re: need a c++ compiler
Postby Eden » Thu Aug 23, 2007 15:34
Dev-C++ isnt a compiler its an ide, its also an ide that sucks.
Anyway, for a compiler you can use gcc which is already installed.
for an IDE i recomend Anjuta or Code::Blocks(from svn)
If you want Anjunta i suggest unmasking (if it isnt already) version 2.0.* and if your getting errors post them so they can be fixed.
Eden
Postby karlpox » Thu Aug 23, 2007 15:53
oh sorry. where do i find gcc?
karlpox
Postby Eden » Thu Aug 23, 2007 16:03
Its already installed. for info on how to use it type: man gcc
both Anjuta and codeblocks use gcc for compiling as well as other compilers.
Eden
