How do I make VLC the default player for DVD's?
Postby handy » Sat Aug 11, 2007 1:35
I can easily use properties to change the associated application for .avi's & such. I have done the same for the .bup & .ifo files on a DVD but I can't get the .vob files. Whenever I try the a requester comes up telling me I can cancel the operation. If I don't cancel nothing changes over time?
So, if someone can tell me what to edit & where to find the configuration file(s) to change the default DVD player I will be very happy! :-D
Thank you in advance.
handy
Postby wolfden » Sun Aug 12, 2007 8:05
usually what I do is find a file and than I can right click on it and choose open with and browse or choose the program I want to open with it and than select to always remember or make default.
Postby handy » Sun Aug 12, 2007 8:37
Thanks for your reply.
What I want is when I put a DVD disk into my machine, for it to be automatically opened by VLC.
I have told the .vob files that VLC is the default, but still I get Totem when a disk is inserted.
Any ideas?
handy
Postby Fitzcarraldo » Mon Aug 13, 2007 1:36
Could the following do it?
K Menu > Control Centre > KDE Components > File Associations
Click on e.g. x-mpeg, x-msvideo and the other video-related entries, click on VLC media player and click on Move Up
Worth s shot.
Postby handy » Mon Aug 13, 2007 6:07
Fitzcarraldo wrote:Could the following do it?
Worth s shot.
I am using Gnome, so unfortunately I can not follow your directions.
I would think that there is a file or two that just needs simple editing, like replace totem, with vlc, most likely with x-mpeg & x-msvideo involved.
handy
Postby Fitzcarraldo » Mon Aug 13, 2007 11:25
GNOME, huh? Try the third post down in the following thread:
http://ubuntuforums.org/showthread.php?t=521566
Postby handy » Mon Aug 13, 2007 12:25
Fitzcarraldo wrote:GNOME, huh? Try the third post down in the following thread:
I've already done that, it still brings up Totem on inserting a DVD in the drive? :-)
I'm pretty sure that something needs to be edited to set the defaults for the disk.
handy
