beagle deamon will not start Sabayon 3.4a 64bit
Postby KRA » Sun Aug 05, 2007 22:09
this is the output:
** (/usr/lib64/beagle/BeagleDaemon.exe:3388): WARNING **: The following assembly referenced from /usr/lib64/beagle/BeagleDaemon.exe could not be loaded:
     Assembly:   glib-sharp    (assemblyref_index=6)
     Version:    2.10.0.0
     Public Key: 35e10195dab3c99f
The assembly was not found in the Global Assembly Cache, a path listed in the MONO_PATH environment variable, or in the location of the executing assembly (/usr/lib64/beagle).
** (/usr/lib64/beagle/BeagleDaemon.exe:3388): WARNING **: Could not load file or assembly 'glib-sharp, Version=2.10.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' or one of its dependencies.
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or assembly 'glib-sharp, Version=2.10.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' or one of its dependencies.
Beagle Daemon exited with errors.  See ~/.beagle/Log/current-Beagle for more details.
The LOG file is not there !
KRA
Postby wolfden » Sun Aug 05, 2007 22:21
IMHO that is a good thing
Evil Beagle!! kill -9 beagle!!
Postby KRA » Mon Aug 06, 2007 9:42
why ? what is the alternative?
KRA
The alternative
Postby Espreon » Mon Aug 06, 2007 19:36
The alternative is the Tracker search tool, IMO Tracker is alot better, since it finds things FASTER than Beagle, plus it is much lighter on memory. Plus Tracker integrates with the Affinity Search tool (search eyecandishly!) otb.
Espreon
Postby phzi » Mon Aug 06, 2007 20:10
Why would you need a search tool? yeeesh, learn where you put your stuff! <sarcasm/joking>
phzi
Postby Espreon » Mon Aug 06, 2007 21:24
Is'nt Beagle a search tool?
If the Beagle daemon (which indexes things for Beagle) won;t work then use Tracker!
Espreon
Postby wolfden » Mon Aug 06, 2007 21:57
slocate works just fine
beagle is a resource hog
Postby Fitzcarraldo » Tue Aug 07, 2007 12:31
I don't use Beagle either, but perhaps KRA wants to get it working, or at least know that it's not broken.
From the error message posted, it looks like the file glib-sharp is missing on KRA's PC. I typed the following into a Terminal window:
sudo find / -iname glib-sharp
and the result was:
/usr/lib/mono/gac/glib-sharp
so could an "emerge" KRA has performed previously have removed this file? With my limited knowledge of SL, I would have started by trying:
sudo revdep-rebuild -X
and, if that didn't work:
sudo emerge beagle
Would that help him/her?
Postby KRA » Sat Aug 18, 2007 23:38
Thanks it seems to be working now.
thanks to Fitzcarraldo for pointing me in the right direction. Quite a few revdep-rebuild, seperate emerge and ebuild digesting later it is working. But I have no idea what was wrong though.
oh, and the "revdep-rebuild -X" didn't work, it complained about the -X, so I ran it without the -X
KRA
Postby AmpLiF1eR » Sun Aug 19, 2007 10:46
The only problem I had with Kerry Beagle (I use KDE), is that the service didn't start automatically, even when I launched Kerry manually.
I just emerged beagle (not kerry) again, new version was available, and now the indexing stays enabled on start of Kerry Beagle(you have to enable session-saving too or put in in your autostart folder to start the application in the first place of course).
I have never experienced slow speeds when kerry(beagle) is enabled.
(Athlon64 X2 2.8Ghz, 2048MB Ram)
gr.
Amp
AmpLiF1eR
