Google Earth,Wine-Doors, others not working [Solved]
Postby Espreon » Tue Jul 31, 2007 16:54
Yeah, Google Earth is not working, it onced worked in Ubuntu (but it stopped working in Ubuntu also). It never worked in Sabayon (I suspect XGL is the culprit). Also I got Wine-Doors to work once (I used it flawlessly in Ubuntu) it was able to create the all important Wine Drive and the submenu in the SUSE Styled KDE menu. But I tried running Wine-Doors in a terminal and it gave me a blank window for 2 milisecs and a bunch of errors in the terminal (I will post them later when I get home). And 2 games won't work (I forgot which ones but I will tell bout them when I get home to my Sabayon computer).
I am running a Dell Inspiron 1505 with 1 GB of RAM, a ATI Radeon x1400 Mobility with XGL and the fglrx driver ( I believe)
With Google Earth it just gives me the Startup Splash and freezes (not the whole comp).
Also Compiz-Fusion is not working (got it to work pretty good under Ubuntu), it gave me errors when running it in the terminal (I will post those and try to run Google Earth in the terminal and post those errors). Beryl works fine though (how do I install the unsupported Beryl plugins?)
And finally I can;t get Mettise working that good, (only works in GNOME) sometimes I can see the panels and most of the time I can't when I open 1 window the panels stop working (I can play around with the window just fine).
When I get home I will post the outputs from the terminal and post my xorg.conf
Espreon
Postby chickpea » Tue Jul 31, 2007 17:36
See this post.
http://www.sabayonlinux.org/forum/viewt ... 3018#53018
You have to unmerge and remerge wine and wine-doors. Somehow they went out borked.
chickpea
Postby Espreon » Tue Jul 31, 2007 17:39
I'll try that when I get home.
Espreon
Postby edgevision » Tue Jul 31, 2007 17:46
Also if you can post some of these errors you're getting with Compiz Fusion, I'm sure we can work them out.
edgevision
Here are the outputs
Postby Espreon » Wed Aug 01, 2007 4:44
Compiz Fusion:
spanek@localhost ~ $ compiz
compiz (core) - Error: Screen 0 on display ":0.0" already has a window manager; try using the --replace option to replace the current window manager.
compiz (core) - Fatal: No manageable screens found on display :0.0
Compiz Fusion with the --replace switch:
spanek@localhost ~ $ compiz --replace
XIO:  fatal IO error 104 (Connection reset by peer) on X server ":0.0"
      after 133 requests (132 known processed) with 0 events remaining.
Wine-Doors:
spanek@localhost ~ $ wine-doors
Started logging session
Checking wine drive: /home/spanek/.wine/
Error: No such file : /home/spanek/.wine-doors/packlists/System Global.xml
  File "/usr/bin/wine-doors", line 99, in ?
    ui.winedoors = ui.WineDoorsGUI()
  File "/usr/share/wine-doors/src/ui.py", line 920, in __init__
    self.tree = PackTree( self.window['tv_packlist'], self.window )
  File "/usr/share/wine-doors/src/ui.py", line 460, in __init__
    packlist.UpdateAll()
  File "/usr/share/wine-doors/src/packlist.py", line 284, in UpdateAll
    self.Update( ''.join( item[0:1] ) )
  File "/usr/share/wine-doors/src/packlist.py", line 266, in Update
    self.Parse( local_file )
  File "/usr/share/wine-doors/src/packlist.py", line 231, in Parse
    parser.parse( xmlfile )
  File "/usr/lib/python2.4/site-packages/_xmlplus/sax/expatreader.py", line 103, in parse
    source = saxutils.prepare_input_source(source)
  File "/usr/lib/python2.4/site-packages/_xmlplus/sax/saxutils.py", line 523, in prepare_input_source
    f = urllib2.urlopen(source.getSystemId())
  File "/usr/lib/python2.4/urllib2.py", line 130, in urlopen
    return _opener.open(url, data)
  File "/usr/lib/python2.4/urllib2.py", line 350, in open
    protocol = req.get_type()
  File "/usr/lib/python2.4/urllib2.py", line 233, in get_type
    raise ValueError, "unknown url type: %s" % self.__original
ValueError: unknown url type: /home/spanek/.wine-doors/packlists/System Global.xml
Google Earth:
spanek@localhost ~ $ googleearth
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
My xorg.conf:
Section "Files"
    #FontPath   "/usr/share/fonts/local/"
    FontPath   "/usr/share/fonts/misc/"
    FontPath   "/usr/share/fonts/Type1/"
    FontPath    "/usr/share/fonts/TTF/"
    FontPath   "/usr/share/fonts/75dpi/"
    FontPath   "/usr/share/fonts/100dpi/"
    FontPath    "/usr/share/fonts/corefonts"
EndSection
# Module section -- this is an optional section which is used to specify
# which run-time loadable modules to load when the X server starts up.
Section "Module"
    Load   "dbe"
    Load   "i2c"
    Load   "glx"
    Load   "ddc"
    Load   "type1"
    Load   "freetype"
    Load   "extmod"
    Load   "synaptics"
    Load   "vbe"
   Load        "dri"
EndSection
# Server flags section.  This contains various server-wide Options.
Section "ServerFlags"
     Option    "AllowMouseOpenFail" "true"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier      "Synaptics1"
    Driver      "synaptics"
    Option      "SendCoreEvents"   "true"
    Option      "Device"      "/dev/psaux"
    Option      "Protocol"      "auto-dev"
    Option      "HorizScrollDelta"   "0"
    Option      "SHMConfig"      "on"
    # For ALPS/MacBook TouchPads
    #Option      "MaxSpeed"      "0.7"
    #Option      "MinSpeed"      "0.18"
    #Option      "AccelFactor"      "0.08"
    #Option      "TopEdge"      "120"
    #Option      "LeftEdge"      "120"
    #Option      "BottomEdge"      "830"
    #Option      "RightEdge"      "650"
    #Option      "FingerLow"      "25"
    #Option      "FingerHigh"      "30"
    # MacBook touchpad
    #Option      "MaxTapTime"      "180"
    #Option      "MaxTapMove"      "220"
    #Option      "MaxDoubleTapTime"   "180"
    #Option      "VertScrollDelta"   "20"
    #Option      "HorizScrollDelta"   "50"
    #Option      "TapButton2"      "3"
    #Option      "TapButton3"      "2"
    #Option      "VertTwoFingerScroll"   "1"
    # Do you keep moving the mouse while typing? Try this trick.
    #synclient TouchpadOff=1 disable your synaptics touchpad
    #synclient TouchpadOff=0 enable your synaptics touchpad
EndSection
    Identifier   "Keyboard1"
    Driver   "kbd"
    Option   "AutoRepeat"   "500 5"
    Option      "XkbModel"   "pc105"
    Option   "XkbLayout"   "us"
    Option      "XkbRules"      "xorg"
    # Macintosh keyboard
    #Option   "XkbOptions"   "lv3:rwin_switch"
EndSection
  Driver        "wacom"
  Identifier    "wacom1"
  Option        "Device"        "/dev/wacom"          # Change to
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "stylus"
  Option        "ForceDevice"   "ISDV4"               # Tablet PC ONLY
EndSection
  Driver        "wacom"
  Identifier    "wacom2"
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "eraser"
EndSection
  Driver        "wacom"
  Identifier    "wacom3"
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "cursor"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
    Identifier   "Mouse1"
    Driver   "mouse"
    Option   "Protocol"   "ImPS/2"
    Option   "ZAxisMapping"   "4 5"
EndSection
    Identifier   "Mouse2"
    Driver   "mouse"
    Option   "Device"   "/dev/input/mice"
EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier   "Generic Monitor"
    #Option      "DPMS"
    VertRefresh 43 - 60
    HorizSync   28 - 80
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
    Identifier  "VESA"
    Driver      "fglrx" # do not remove vesa
    #Option "RenderAccel" "on"
    #Option "XAANoOffscreenPixmaps"
    #Option "BusType" "PCI"
    #Option "ColorTiling" "on"
    #Option "EnablePageFlip" "on"
EndSection
# Screen sections.
Section "Screen"
# The Identifier, Device and Monitor lines must be present
    Identifier   "Screen 1"
    Device   "VESA"
    Monitor   "Generic Monitor"
    #Option "AddARGBGLXVisuals" "true"
# The favoured Depth and/or Bpp may be specified here
    DefaultDepth 24
    SubSection "Display"
        Depth      8
        ViewPort   0 0
        #Modes      "1600x1200" "800x600" "640x480"
    EndSubsection
        Depth           16
        ViewPort        0 0
    EndSubsection
        Depth           24
        ViewPort        0 0
    EndSubsection
EndSection
Section "ServerLayout"
# The Identifier line must be present
    Identifier   "Main Layout"
    Screen 0    "Screen 1"
    InputDevice   "Mouse1" "CorePointer"
    InputDevice   "Mouse2" "SendCoreEvents"
    InputDevice "Synaptics1" "SendCoreEvents"
    #InputDevice "wacom1" "SendCoreEvents"
    #InputDevice "wacom2" "SendCoreEvents"
    #InputDevice "wacom3" "SendCoreEvents"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "DRI"
    Mode 0666
EndSection
Section "Extensions"
   #Option "Composite" "Enable"
EndSection
BTW How do I install the unsupported Beryl Plugins?
Espreon
Postby Fitzcarraldo » Sat Aug 04, 2007 18:32
If Google Earth 4.0.2723 just hangs at the splash screen and your PC has an ATI graphics card then try the following fix, which makes Google Earth use an older version of an ATI library (the older library is put in the Google Earth directory and does not affect the latest version of the library, which is in a different directory).
Download the file ati-driver-installer-8.27.10-x86.run from the ATI Web site. I downloaded it to my Desktop (/home/fitzcarraldo/Desktop). Then type the following commands into a Terminal window:
$ sudo mkdir /tmp/ati_extract
$ sudo sh /home/fitzcarraldo/Desktop/ati-driver-installer-8.27.10-x86.run --extract /tmp/ati_extract
$ sudo cp /tmp/ati_extract/arch/x86/usr/X11R6/lib/libGL.so.1.2 /opt/googleearth/libGL.so.1
To launch Google Earth, either type the following into a Terminal window:
$ DISPLAY=:0 googleearth
or edit the command in the Application tab of the Google Earth Desktop Config File (which was installed automatically when you installed SL to the HDD) to say DISPLAY=:0 googleearth %f instead of just “googleearth %f”.
Apparently some people have to use e.g. “DISPLAY=:93” instead “DISPLAY=:0”. You can probably tell which one is needed by looking in the /var/log/Xorg.?.log file.
Postby phzi » Sat Aug 04, 2007 20:42
I had the same problem with Wine-doors, after I had run the initial Wine-doors setup. Unmerging, ~/.wine-doors and ~/.wine, and re-emering, did the trick for me.
phzi
Thanx
Postby Espreon » Mon Aug 06, 2007 8:40
Thanx, fitzcarraldo, Google Earth works great now!
Espreon
