Audion in movies keeps cutting out [Solved]
Postby Glenn » Mon Jul 30, 2007 16:26
Noob here (if you cant already tell) So be easy on me.
I have tried many distros and always have the same thing Problem
Anytime I attempt to watch a movie (either downloaded or bought) the audio will cut out.. Sometimes after a while it comes back.. But most often Not..
Sabayon 3.3
I am using KDE also..
When I reset the soundcard with alsaconfig, the sound will work for a few Minutes..
Any Ideas? Any info needed just tell me how to supply it.
Thanks
Glenn
Postby zouzou85 » Mon Jul 30, 2007 16:51
ok, what video-card and sound card do you have? and is it 32bit or 64bit? (just a little more about your computer specs)
usually, re-emrging the media player (VLC, mPlayer, xine, or gstreamer) can help, but appearently it is a hardware problem since it didn't work in other distros.
also, when you play these videos, is beryl, or compiz on or not?
Ignorance is not shameful. Arrogantly ignoring and denying your ignorance is.
All men are capable of learning, except two: The Arrogant and The Shy.
zouzou85
Postby Glenn » Mon Jul 30, 2007 18:15
Thank you for the quick response...
I am running 32bit
And please tell me how to post a report of what things are running and computer setup.. I am about as new to the world of linux as possible.. lol
Thanks
I can tell you that I thought I had my sound problems fixed when i was using Debian under a net install..
If that helps any
Glenn
Postby wolfden » Mon Jul 30, 2007 21:36
What video software are you using? I have great luck using VLC - it plays anything it seems like
Postby Glenn » Mon Jul 30, 2007 23:15
I am using VLC.. I just updated it with emerge.. but I just tried to play a .avi that I downloaded.. and at about the 12 minute mark the sound cut out..
Glenn
Postby Glenn » Tue Jul 31, 2007 22:20
I think I have found what was causing the Audio to cut out of the movies yet the video continues..
For some reason ktorrent utilizes arts. When I turn off ktorrent, Problems with the audio goes way down..
Also I was doing some fooling around and found out the audio cache was set at 2000 bytes.. So I upped it to 4000.. I dont know if it means anything.. but it seems to be working...
Glenn
