Streaming Video Crashes in FireFox
Postby LinuxHack » Sun Jul 22, 2007 7:01
Hi Evereyone:
I'm new to Sabayon Linux, But not Linux as a whole.
I've used almost Every Major Linux distro out there.
But I've got a rather peculiar problem
When I go to PLAY Streaming Video in Firefox it Crashes and kicks Firefox out completely. :cry:
It will Play the Flash ads fine, I'll go to run the Streaming Video.
It starts to Load, Black window comes up and says NO VIDEO!
The Video STARTS to Load and comes up with No Sound.
Then it just CRAP's Out... :?
What could it be?
Any Ideas?
I was thinking it might be a Sound Issue?
I've had this prob a couple of times before...
I'd Right Click on the Window where the Video would Come Up, Change around some of the Config settings, and it would run fine after that...
But I never had any prob with the Sound, I'd get No Video but I'd get sound???
Thanks in advance for any HELP and or Ideas.... :D
I've got Several other questions, But I'll take them one at a TIME.... :wink:
LinuxHack
Postby WarraWarra » Sun Jul 22, 2007 7:38
Could be the video card driver that is not properly installed or running / mis-configured.
Sound run " alsaconf " to configure it.
As root in tenrminal:
# su
passwd: root
# glxgears
It should give you a reasonable amount depending on your card likely 5000fps or more. If nasty 900fps then driver needs reinstalling , you can use kuroo or as root in terminal " emerge nvidia-driver" or if not sure about name " emerge -s nvidia " and then once name is known install it.
Do not use the emerge -u to update as you would want a clean reinstall.
Mine nvidia 7800gtx laptop
localhost ~ # glxgears
65904 frames in 5.0 seconds = 13180.718 FPS
65255 frames in 5.0 seconds = 13050.818 FPS
65136 frames in 5.0 seconds = 13027.035 FPS
WarraWarra
Postby LinuxHack » Mon Jul 23, 2007 4:40
WarraWarra wrote:Could be the video card driver that is not properly installed or running / mis-configured.
# su
passwd: root
# glxgears
Thanks for the FAST response. I'll give'm a shot and let ya know how it goes...
Also again THANKS for the instructions I'm most Grateful... :D
Many will tell ya it's your drivers, but not tell the cmd lines, that are needed to be run in that OS.
I guess they figured If they knew, I knew...
And each OS is tweaked as we already know a Tad different...
8)
LinuxHack
Postby wolfden » Mon Jul 23, 2007 4:48
it don't sound like a video card problem if that is only problem.
Do:
USE="gtk quicktime divx gmedia realmedia wmp win32codecs nsplugins firefox xvid" emerge mplayerplug-in
and
emerge -u mozilla-firefox
that should do it.
Postby LinuxHack » Tue Jul 24, 2007 2:34
# su
passwd: root
# glxgears
NOPE tried it CRAPPED OUT :x
I ended up doing a reinstall because it CRASHED X and wouldn't let me back in.... :(
But in any event THANKS for the Help... :D
LinuxHack
Postby LinuxHack » Tue Jul 24, 2007 6:00
wolfden wrote:it don't sound like a video card problem if that is only problem.
Do:
and
that should do it.
OK did this BUT....
After typing in the cmd lines you told me to...I GET....
Calculating Dependencies... A thing sits there and STARTS to spin like Crazy...
The thing Slows up it's spining, and SPINS & SPINS, but nothing happens.... :?
I've let it run for 15 minutes with No Results...
Is this Normal, and if so how LONG does it take it to run???
Again THANKS for your HELP... 8)
LinuxHack
Postby wolfden » Tue Jul 24, 2007 6:09
well if it is your first time doing it, it can take a long time for some. :?
Postby LinuxHack » Tue Jul 24, 2007 9:26
wolfden wrote:well if it is your first time doing it, it can take a long time for some. :?
Once again THANKS so Much for the quick response.
A strange question though..
I also tried runnin Democracy TV, samething it loaded fine, but once it went to It's Screen it Crapped Out... :cry:
On a hunch I ran You Tube and their Videos ran GREAT.... :shock:
Can't say it makes a whole lotta sence to Me, but things like this defy Logic....
I'll run your Cmd Lines again, and let them Play themselves out, And let you know how it goes... 8)
LinuxHack
Postby Thrice » Tue Jul 24, 2007 10:53
do you have to take care of bookmarks extensions etc when doing emerge -u mozilla-firefox?
Thrice
Postby Thrice » Wed Jul 25, 2007 3:48
nvm got it working
Thrice
