Amarok can not play Flac [Solved]
Postby Raqua » Thu Jul 19, 2007 13:37
Hello.
I have used Amarok for some time. Two days ago I updated flac to 1.1.4 and (probably) since then Amarok can not find plugin to play these files. I tried to downgrade to previous version of flac, rebuild Amarok, but it did not solved my problem. Mp3 files play without problem.
Thanks for any hints.
Raqua
Re: Amarok can not play Flac
Postby Raqua » Fri Aug 31, 2007 10:55
I forgot to write here that I solved it then. If I remember right revdep-rebuild did the job.
Raqua
