Playing Real Player files in 64-bit Sabayon
Postby adewolf » Wed Jul 18, 2007 0:29
How can I play Real Player files/URLs on the 64 bit version of Sabayon 3.4 Loop3a
Alex
adewolf
Postby WarraWarra » Wed Jul 18, 2007 20:19
Think you can install realplayer / helixplayer.
Is there not a reallayer program installed already under multimedia.
http://www.real.com/linux
Or try as root in terminal
emerge -s realplayer
once it shows you if or what is there , should be " media-video/realplayer "
then
emerge realplayer
Kuroo on the desktop should be able to search for realplayer as well and or other software that can also play the real type files.
WarraWarra
Postby Dark_MaGe » Wed Jul 18, 2007 22:02
or simply use smplayer....
Dark_MaGe
Your Farmer
Re: Playing Real Player files in 64-bit Sabayon
Postby darkscot » Thu Jul 19, 2007 8:57
adewolf wrote:How can I play Real Player files/URLs on the 64 bit version of Sabayon 3.4 Loop3a
I have some RM files that most Linux media players (including Real/Helix) seem to have difficulty with. The one player that can cope with all of them is MPlayer.
Desktop1: Sabayon 3.4e, WinXP | Desktop2: Sabayon 3.4e, WinME |
darkscot
Postby WarraWarra » Thu Jul 19, 2007 20:51
Not sure but in windoze I had to add extra codecs for mp4 and other stuff to get most of my movies to be read.
It might be the same here not sure what name will be used for it , I used to everytime in SL install flac as well until amarok got to aac+ stable .
WarraWarra
Postby adewolf » Fri Jul 20, 2007 4:41
I can't play this on mplayer:
http://stream.unf.edu:8080/ramgen/wosp/wosp.smil
Alex
adewolf
Postby WarraWarra » Fri Jul 20, 2007 10:34
Could try to install wine and then "real alternative" or realplayer. Might just work.
Tried this link in windows and real alternative = "dead link file not found , outdated or inacurate"
You can try http://www.bbc.com and they have news video's on the left bottom 1/4 of the page.
They should work.
WarraWarra
Postby adewolf » Fri Jul 20, 2007 16:18
Can I install wine on a 64 bit Sabayon environment. Will it execute 32 bit Windoze apps?
On a 32 bit installed Sabayon I was able to get RealPlayer to work on that URL.
Alex
adewolf
Postby WarraWarra » Fri Jul 20, 2007 18:53
Have not tried it on 64bit as I have none.
http://winehq.org/
This should give you a idea if it will work on any 64bit then in SL too
WarraWarra
Postby adewolf » Fri Jul 20, 2007 20:16
Thanks
adewolf
