Democracy Player
Democracy Player
Postby Xtremesupremacy3 » Sun Jul 15, 2007 14:59
Hello there!
I am a new user to Sabayon and I think you will all agree that it has to be the most easiest to use and user friendly distros out there...well done!!!
I have truly enjoyed every aspect of Sabayon but there is just one little thing that still annoys me (apart from Beryl not working) and that is the Democracy Player. I installed DP quite easily using portage and all seemed well but now it seems to do this one thing: it opens up, then it loads all the channels on the left and main screen on the right. Once all channels are loaded you can see it loading up the last bits of the main window and once its all loaded...POOF!...as if by magic....it disappears.
Now I don't know what you need to know from me in order to help but I will do my best.But i am a bit of a dumbass so your going to have to be a little bit more describtive. I'm an ex-Windows user...its a cancer i tell ya!
Thanks before hand
Xtremesupremacy3
