Aptana Error?
Aptana Error?
Postby blazedforever » Thu Jun 21, 2007 3:18
Hey all I'm trying to get my favorite Web IDE Aptana runnig but i get this error after the splash "An error has occurred. See the log file /home/hans/workspace/.metadata/.log"
You can download Aptana free here http://207.97.207.77/downloads/current/ ... _Linux.zip
Some one wanna help a n00b out ?
blazedforever
Postby WarraWarra » Fri Jun 22, 2007 5:04
You can browse to this log file and open as there might be the exact error and usually a fix for it.
This error can happen as it is a beta version or it is missing some code or has incorrect code in it.
Fix likely = use a older that your version or a newer one.
Also when "emerge -uD aptana" and the -u = update and -D = deep dependacy check , -uD
This will check and make sure it is upto-date as well as install any missing other programs that it needs to work propperly.
Another way is to run " revdep-rebuild -X" but this will check all software + dependancy on your computer and update or fix broken missing pieces. Very long process.
Hope this helps.
WarraWarra
Postby blazedforever » Sun Jun 24, 2007 19:29
heres the log file :
!SESSION 2007-06-24 10:44:33.302 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86
!ENTRY com.aptana.ide.rcp.main 1 0 2007-06-24 10:44:34.952
!MESSAGE (Build 0.2.8.15171) Bound Aptana to port 9980
!ENTRY org.eclipse.osgi 4 0 2007-06-24 10:44:35.061
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: /home/hans/Appz/aptana/configuration/org.eclipse.osgi/bundles/159/1/.cp/libswt-pi-gtk-3236.so: /home/hans/Appz/aptana/configuration/org.eclipse.osgi/bundles/159/1/.cp/libswt-pi-gtk-3236.so: wrong ELF class: ELFCLASS32
   at java.lang.ClassLoader$NativeLibrary.load(Native Method)
   at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
   at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1660)
   at java.lang.Runtime.loadLibrary0(Runtime.java:823)
   at java.lang.System.loadLibrary(System.java:1030)
   at org.eclipse.swt.internal.Library.loadLibrary(Library.java:123)
   at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:22)
   at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java:63)
   at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java:54)
   at org.eclipse.swt.widgets.Display.<clinit>(Display.java:126)
   at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:436)
   at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
   at com.aptana.ide.rcp.AbstractIDEApplication.createDisplay(AbstractIDEApplication.java:152)
   at com.aptana.ide.rcp.AbstractIDEApplication.run(AbstractIDEApplication.java:89)
   at com.aptana.ide.rcp.Application.run(Application.java:43)
   at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
   at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
   at org.eclipse.core.launcher.Main.run(Main.java:977)
   at org.eclipse.core.launcher.Main.main(Main.java:952)
blazedforever
