by WarraWarra » Tue Jun 19, 2007 0:23
Had it working in windows a while a go but not in linux.
You should be able to emerge it and then using the test server you connect to as in the readme file or from the help pages on hamachi website get it to work.
For windows it is very easy to run same as login onto email account , username , password , server / create or connect.
But I presume you already know how it works LOL.
