by kainalu » Thu May 31, 2007 17:06
this is my DMESG, and yes, i did read that and many other wiki's. i am at a loss!
[ 32.629442] ivtv: ==================== START INIT IVTV ====================
[ 32.629449] ivtv: version 0.10.0 (tagged release candidate #1) loading
[ 32.629453] ivtv: Linux version: 2.6.20-sabayon-r3 SMP mod_unload 586
[ 32.629457] ivtv: In case of problems please include the debug info between
[ 32.629480] ivtv: the START INIT IVTV and END INIT IVTV lines, along with
[ 32.629484] ivtv: any module options, when mailing the ivtv-users mailinglist.
[ 32.629651] ivtv0: Autodetected Hauppauge card (cx23416 based)
[ 32.632309] ACPI: PCI Interrupt 0000:03:08.0[A] -> Link [LNKA] -> GSI 3 (level, low) -> IRQ 3
[ 33.321568] ivtv0: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 33.352130] ivtv0: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 33.383425] ivtv0: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 33.383483] ivtv0: unable to open firmware v4l-cx2341x-enc.fw (must be 376836 bytes)
[ 33.383488] ivtv0: did you put the firmware in the hotplug firmware directory?
[ 33.383493] ivtv0 warning: failed loading encoder firmware
[ 33.383497] ivtv0 warning: Error -3 loading firmware
[ 33.383501] ivtv0: Retry loading firmware
[ 34.031730] ivtv0: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 34.060435] ivtv0: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 34.090850] ivtv0: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 34.090908] ivtv0: unable to open firmware v4l-cx2341x-enc.fw (must be 376836 bytes)
[ 34.090913] ivtv0: did you put the firmware in the hotplug firmware directory?
[ 34.090918] ivtv0 warning: failed loading encoder firmware
[ 34.090922] ivtv0 warning: Error -3 loading firmware
[ 34.090926] ivtv0: Error initializing firmware
[ 34.091158] ivtv0: Error -19 on initialization
[ 34.091258] ivtv: ====================== NEXT CARD ======================
[ 34.091265] ivtv1: Autodetected Hauppauge card (cx23416 based)
[ 34.091365] ACPI: PCI Interrupt 0000:03:09.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 34.741782] ivtv1: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 34.770526] ivtv1: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 34.799813] ivtv1: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 34.799878] ivtv1: unable to open firmware v4l-cx2341x-enc.fw (must be 376836 bytes)
[ 34.799883] ivtv1: did you put the firmware in the hotplug firmware directory?
[ 34.799888] ivtv1 warning: failed loading encoder firmware
[ 34.799892] ivtv1 warning: Error -3 loading firmware
[ 34.799895] ivtv1: Retry loading firmware
[ 35.450567] ivtv1: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 35.479818] ivtv1: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 35.508771] ivtv1: retry: file loaded was not v4l-cx2341x-enc.fw (expected size 376836, got 262144)
[ 35.508835] ivtv1: unable to open firmware v4l-cx2341x-enc.fw (must be 376836 bytes)
[ 35.508840] ivtv1: did you put the firmware in the hotplug firmware directory?
[ 35.508845] ivtv1 warning: failed loading encoder firmware
[ 35.508849] ivtv1 warning: Error -3 loading firmware
[ 35.508853] ivtv1: Error initializing firmware
[ 35.509091] ivtv1: Error -19 on initialization
[ 35.509116] ivtv: ==================== END INIT IVTV ====================
