LO Impress crash when a presentation starts
Postby belze » Sat Mar 09, 2013 14:01
I can use the meny entry od F5, result is the same. starting soffice fron a console just leave me with these errors
Xlib:  extension "XINERAMA" missing on display ":0".
(soffice:27465): Gdk-CRITICAL **: IA__gdk_window_get_origin: assertion `GDK_IS_WINDOW (window)' failed
(soffice:27465): Gdk-WARNING **: gdkdrawable-x11.c:952 drawable is not a pixmap or window
i'm on kde x86 and with a full upgrade (including 3.8 kernel). i'm not an experienced sabayon user (i used debian for most of last 6 years). any help will be appreciated
belze
Re: LO Impress crash when a presentation starts
Postby belcocco » Sat Mar 09, 2013 15:25
Please, could you tell us how you installed it?
Entropy or portage?
Ciao
belcocco
Postby belze » Sat Mar 09, 2013 18:52
i got it installed using entropy upgradevia regular updates (this what i mean with "full upgrade" sorry).
do you need any log? i'd be glad to give you all the bits you need!
italianamente volenteroso di aiutare :)
belze
Postby belcocco » Sat Mar 09, 2013 21:45
The system log can not help us in this case.
The crash of 'LibreOffice Impress' by simply pressing F5 is not related (imho) to the reported errors when the program starting from console.
The only advice I can give is to reinstall:
1) # equo remove app-office/libreoffice
2) # equo install app-office/libreoffice
hoping that the problem will be resolved. :?
Good luck!
Ciao
belcocco
Postby Matte88 » Sun Mar 10, 2013 1:44
belze wrote:I can use the meny entry od F5, result is the same. starting soffice fron a console just leave me with these errors
Is you a multi-monitor setup? Look at Xlib: extension "XINERAMA" missing on display ":0". in your output. An issue probably with Xinerama (multi-display manager).
Also please post output of
# lspci -v | grep -i vga
# glxinfo
# eselect opengl list
Meanwhile if you want you can try to update x11-libs/libXinerama to its unstable version present in Sabayon Limbo repos.
---> DON'T INSTALL ANY UPGRADES MAGNETO/RIGO WILL PROMPT! <---
a. Enable Limbo repos
# mv /etc/entropy/repositories.d/_entropy_sabayon-limbo /etc/entropy/repositories.d/entropy_sabayon-limbo
b. Update Entropy db
equo up --force
c. Install unstable version of libXinerama
equo i --nodeps x11-libs/libXinerama
d. Logout, login
When I became the sun,
I shone life into the man's hearts.
Matte88
Location: @/etc/entropy/repositories.conf.d/entropy_sabayon-limbo
Postby belze » Sun Mar 10, 2013 17:37
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07) (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RV710 [Mobility Radeon HD 4300 Series] (prog-if 00 [VGA controller])
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
    GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_create_context_robustness, GLX_ARB_get_proc_address,
    GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_create_context_es2_profile, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control,
    GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
    GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event
GLX version: 1.4
GLX extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Mobile Intel® GM45 Express Chipset
OpenGL version string: 2.1 Mesa 9.0.1
OpenGL shading language version string: 1.20
OpenGL extensions:
    GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_copy_texture,
    GL_EXT_polygon_offset, GL_EXT_subtexture, GL_EXT_texture_object,
    GL_EXT_vertex_array, GL_EXT_compiled_vertex_array, GL_EXT_texture,
    GL_EXT_texture3D, GL_IBM_rasterpos_clip, GL_ARB_point_parameters,
    GL_EXT_draw_range_elements, GL_EXT_packed_pixels, GL_EXT_point_parameters,
    GL_EXT_rescale_normal, GL_EXT_separate_specular_color,
    GL_EXT_texture_edge_clamp, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_ARB_framebuffer_sRGB, GL_ARB_multitexture,
    GL_EXT_framebuffer_sRGB, GL_IBM_multimode_draw_arrays,
    GL_IBM_texture_mirrored_repeat, GL_3DFX_texture_compression_FXT1,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_transpose_matrix,
    GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
    GL_EXT_secondary_color, GL_EXT_texture_env_add,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
    GL_INGR_blend_func_separate, GL_NV_blend_square, GL_NV_light_max_exponent,
    GL_NV_texgen_reflection, GL_NV_texture_env_combine4, GL_S3_s3tc,
    GL_SUN_multi_draw_arrays, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_EXT_framebuffer_object,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_MESA_window_pos, GL_NV_packed_depth_stencil,
    GL_NV_texture_rectangle, GL_NV_vertex_program, GL_ARB_depth_texture,
    GL_ARB_occlusion_query, GL_ARB_shadow, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_window_pos, GL_ATI_envmap_bumpmap,
    GL_EXT_stencil_two_side, GL_EXT_texture_cube_map, GL_NV_depth_clamp,
    GL_NV_vertex_program1_1, GL_APPLE_packed_pixels,
    GL_APPLE_vertex_array_object, GL_ARB_draw_buffers,
    GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_shader_objects,
    GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ATI_draw_buffers,
    GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_shadow_funcs,
    GL_EXT_stencil_wrap, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
    GL_NV_primitive_restart, GL_ARB_depth_clamp,
    GL_ARB_fragment_program_shadow, GL_ARB_half_float_pixel,
    GL_ARB_occlusion_query2, GL_ARB_point_sprite, GL_ARB_shading_language_100,
    GL_ARB_sync, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,
    GL_ATI_blend_equation_separate, GL_EXT_blend_equation_separate,
    GL_OES_read_format, GL_ARB_color_buffer_float, GL_ARB_pixel_buffer_object,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_float,
    GL_ARB_texture_rectangle, GL_EXT_packed_float, GL_EXT_pixel_buffer_object,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
    GL_EXT_texture_shared_exponent, GL_ARB_framebuffer_object,
    GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_packed_depth_stencil, GL_APPLE_object_purgeable,
    GL_ARB_vertex_array_object, GL_ATI_separate_stencil, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_gpu_program_parameters,
    GL_EXT_texture_array, GL_EXT_texture_integer, GL_EXT_texture_sRGB_decode,
    GL_OES_EGL_image, GL_MESA_texture_array, GL_ARB_copy_buffer,
    GL_ARB_depth_buffer_float, GL_ARB_draw_instanced,
    GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
    GL_ARB_map_buffer_range, GL_ARB_texture_rg, GL_ARB_texture_swizzle,
    GL_ARB_vertex_array_bgra, GL_EXT_separate_shader_objects,
    GL_EXT_texture_swizzle, GL_EXT_vertex_array_bgra,
    GL_NV_conditional_render, GL_ARB_ES2_compatibility, GL_ARB_debug_output,
    GL_ARB_draw_elements_base_vertex, GL_ARB_explicit_attrib_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_provoking_vertex,
    GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_shader_texture_lod, GL_ARB_texture_rgb10_a2ui,
    GL_EXT_provoking_vertex, GL_EXT_texture_snorm,
    GL_MESA_texture_signed_rgba, GL_ARB_robustness,
    GL_ARB_shader_bit_encoding, GL_ARB_texture_storage,
    GL_ARB_invalidate_subdata
32 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x020 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x021 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ca 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0cb 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0cc 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0cd 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0ce 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0cf 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0d0 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0d1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0d2 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0d3 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0d4 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0d5 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0d6 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0d7 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0d8 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0d9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0da 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0db 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0dc 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0dd 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0de 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0df 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0e0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0e1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0e2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0e3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0e4 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0e5 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0e6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x097 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
48 GLXFBConfigs:
0x09a  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09b  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09c  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09d  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x09e  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x09f  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0a0 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a1 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a2 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a3 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a4 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a5 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a6 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0a7 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0a8 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0a9 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0aa 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ab 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ac  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0ad  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0ae 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0af 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0b0 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0b1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0b2  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b3  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b4  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b5  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0b6  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0b7  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0b8 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0ba 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0bb 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0bc 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0bd 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0be 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0bf 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0c0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0c1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c4  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0c5  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0c6 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0c7 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0c8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
display: :0  screen: 1
GLX version: 1.4
GLX extensions:
OpenGL vendor string: X.Org
OpenGL renderer string: Gallium 0.4 on AMD RV710
OpenGL version string: 3.0 Mesa 9.0.1
OpenGL shading language version string: 1.30
OpenGL extensions:
    GL_IBM_texture_mirrored_repeat, GL_ARB_texture_cube_map,
    GL_NV_texture_rectangle, GL_ARB_depth_texture, GL_ARB_occlusion_query,
    GL_ARB_shadow, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
    GL_ARB_window_pos, GL_EXT_stencil_two_side, GL_EXT_texture_cube_map,
    GL_NV_depth_clamp, GL_NV_fog_distance, GL_APPLE_packed_pixels,
    GL_EXT_stencil_wrap, GL_MESA_pack_invert, GL_NV_primitive_restart,
    GL_ARB_depth_clamp, GL_ARB_fragment_program_shadow,
    GL_ARB_half_float_pixel, GL_ARB_occlusion_query2, GL_ARB_point_sprite,
    GL_ARB_shading_language_100, GL_ARB_sync, GL_ARB_texture_non_power_of_two,
    GL_ARB_vertex_buffer_object, GL_ATI_blend_equation_separate,
    GL_EXT_blend_equation_separate, GL_OES_read_format,
    GL_ARB_texture_rectangle, GL_ATI_texture_compression_3dc,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_rectangle,
    GL_EXT_texture_sRGB, GL_EXT_texture_shared_exponent,
    GL_ARB_framebuffer_object, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_packed_depth_stencil,
    GL_ATI_texture_mirror_once, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_gpu_program_parameters, GL_EXT_texture_array,
    GL_EXT_texture_compression_latc, GL_EXT_texture_integer,
    GL_EXT_texture_sRGB_decode, GL_EXT_timer_query, GL_OES_EGL_image,
    GL_MESA_texture_array, GL_ARB_copy_buffer, GL_ARB_depth_buffer_float,
    GL_ARB_draw_instanced, GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
    GL_NV_conditional_render, GL_AMD_conservative_depth,
    GL_AMD_draw_buffers_blend, GL_AMD_shader_stencil_export,
    GL_ARB_ES2_compatibility, GL_ARB_blend_func_extended, GL_ARB_debug_output,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_explicit_attrib_location, GL_ARB_fragment_coord_conventions,
    GL_ARB_provoking_vertex, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_shader_stencil_export, GL_ARB_shader_texture_lod,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_MESA_texture_signed_rgba, GL_NV_texture_barrier, GL_ARB_robustness,
    GL_ARB_shader_bit_encoding, GL_ARB_timer_query,
    GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
    GL_ARB_base_instance, GL_ARB_conservative_depth, GL_ARB_texture_storage,
    GL_ARB_transform_feedback_instanced, GL_EXT_transform_feedback,
96 GLX Visuals
0x05a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x05b 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x177 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x178 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x179 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x17a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x17b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x17c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x17d 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x17e 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x17f 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x180 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x181 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x182 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x183 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x184 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x185 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x186 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x187 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x188 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x189 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x18a 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x18b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x18c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x18d 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x18e 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x18f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x190 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x191 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x192 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x193 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x194 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x195 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x196 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x197 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x198 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x199 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x19a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x19b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x19c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x19d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x19e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x19f 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1a0 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1a1 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1a2 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1a3 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1a4 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1a5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x1a6 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x1a7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x1a8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x1a9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x1aa 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x1ab 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x1ac 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x1ad 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x1ae 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x1af 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x1b0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x1b1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x1b2 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x1b3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x1b4 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x1b5 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x1b6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x1b7 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x1b8 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x1b9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x1ba 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x1bb 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x1bc 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x1bd 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x1be 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x1bf 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x1c0 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x1c1 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x1c2 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x1c3 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x1c4 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x1c5 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x1c6 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x1c7 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x1c8 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x1c9 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x1ca 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x1cb 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x1cc 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x1cd 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x1ce 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1cf 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1d0 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1d1 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1d2 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1d3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x099 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
144 GLXFBConfigs:
0x0e7 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0e8 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0e9 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0ea 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0eb 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0ec 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0ed 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x0ee 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x0ef 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x0f0 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x0f1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x0f2 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x0f3 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0f4 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0f5 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0f6 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0f7 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0f8 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0f9 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0fa 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0fb 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0fc 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0fd 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0fe 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0ff 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x100 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x101 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x102 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x103 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x104 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x105 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x106 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x107 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x108 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x109 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x10a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x10b 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x10c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x10d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x10e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x10f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x110 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x111 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x112 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x113 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x114 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x115 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x116 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x117  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x118  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x119  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x11a  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x11b  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x11c  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x11d  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x11e  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x11f  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x120  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x121  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x122  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x123  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x124  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x125  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x126  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x127  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x128  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x129  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x12a  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x12b  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x12c  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x12d  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x12e  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x12f 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x130 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x131 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x132 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x133 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x134 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x135 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x136 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x137 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x138 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x139 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x13a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x13b 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x13c 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x13d 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x13e 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x13f 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x140 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x141 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x142 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x143 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x144 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x145 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x146 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x147 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x148 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x149 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x14a 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x14b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x14c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x14d 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x14e 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x14f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x150 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x151 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x152 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x153 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x154 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x155 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x156 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x157 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x158 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x159 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x15a 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x15b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x15c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x15d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x15e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x15f  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x160  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x161  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x162  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x163  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x164  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x165  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x166  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x167  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x168  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x169  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x16a  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x16b  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x16c  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x16d  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x16e  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x16f  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x170  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x171  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x172  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x173  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x174  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x175  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x176  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
  [1]   xorg-x11 *
ty for helping to solve this issue
belze
Postby Matte88 » Mon Mar 11, 2013 12:06
Wait: how did you solve?
Matte88
Postby belze » Mon Mar 11, 2013 16:05
Matte88 wrote:Wait: how did you solve?
e chi si muove!
i did not solve it. i just posted what i was asked to post. :D
i'm using chakra as main system right now (i just can't figure out why sabayon is SO slow starting kde, but that's another story). I'll be glad to see this LO issue solved becuase i really like sabayon's entropy and i would like to use it as my main box.
belze
Postby linuxfluesterer » Mon Mar 11, 2013 18:25
I used Chakra in March last year for changing from Kubuntu to another distro.
My experince was, Chakra is fast due to that seems to be a KDE distro only, with less overhead.
But also, there was no good hardware support (e.g. I couldn't do hibernate or suspend to disk) Then it was not easy to use the package installer. Last point is, the forum was not really helpful (too few members).
I had same problem like you with last OL version 3. But after installing version 4.0.1.2, I could start presentation without crash. I have a (disabled) NVidia GT630M and use only the build in Intel card (no idea, which type).
I did only activate Limbo repo and installed LO 4.0.1.2 package, then deactivated Limbo repo again, and now LO works.
Maybe, because you begin to use Sabayon, consider to download latest KDE Daily Build with date 10/03/2013, here:
http://mirror.de.sabayon.org/iso/daily/
and install that one... I've attached the German mirror as example. But it should support all languages. Look for the one, you need.
Hope to help you.
linuxfluesterer
Postby belze » Mon Mar 11, 2013 18:37
I'm not a real beginner, i use chakra also because i used to run arch in virtual machine for years. at the same time i used debian and gentoo for professional needs. so i know that a rolling system is not "safe", but i've understood how package managers work, and pacman is one of the nicest out there.
as soon as possible i'll try to use a LO package from limbo as suggested.
belze
