XBMC not working after latest update [Solved]
Postby chasha420 » Fri Mar 08, 2013 19:51
Just like the topic says, I just installed the massive 300 Mb updates & now when ever I click on the video tab of xbmc it crashes. Damn, everytime theres a new update I always have to worry about xbmc going crazy :(
Next time I'll do updates on a monthly basis Lol....I'm tired of weekly updates.
Edit:
More details about the crash:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
 Date: Sat Mar  9 01:45:46 ICT 2013
 XBMC Options:
 Arch: i686
 Kernel: Linux 3.8.0-hardened #1 SMP Thu Feb 28 17:08:19 UTC 2013
 Release:
    LSB Version:   n/a
    Distributor ID:   Sabayon
    Description:   Sabayon Linux x86 11
    Release:   n/a
    Codename:   n/a
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
01:45:32 T:2712651584  NOTICE: -----------------------------------------------------------------------
01:45:32 T:2712651584  NOTICE: Starting XBMC (12.0 Git:exported), Platform: Linux (Sabayon Linux x86 11, 3.8.0-hardened i686). Built on Feb 27 2013
01:45:32 T:2712651584  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
01:45:32 T:2712651584  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
01:45:32 T:2712651584  NOTICE: special://masterprofile/ is mapped to: /home/irenicus/.xbmc/userdata
01:45:32 T:2712651584  NOTICE: special://home/ is mapped to: /home/irenicus/.xbmc
01:45:32 T:2712651584  NOTICE: special://temp/ is mapped to: /home/irenicus/.xbmc/temp
01:45:32 T:2712651584  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
01:45:32 T:2712651584  NOTICE: Local hostname: C0RE
01:45:32 T:2712651584  NOTICE: Log File is located: /home/irenicus/.xbmc/temp/xbmc.log
01:45:32 T:2712651584  NOTICE: load settings...
01:45:32 T:2712651584  NOTICE: special://profile/ is mapped to: special://masterprofile/
01:45:32 T:2712651584  NOTICE: loading special://masterprofile/guisettings.xml
01:45:32 T:2712651584  NOTICE: Getting hardware information now...
18:45:32 T:2712651584  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:45:32 T:2712651584  NOTICE: Loaded playercorefactory configuration
18:45:32 T:2712651584  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:45:32 T:2712651584  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:45:32 T:2712651584  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:45:32 T:2712651584  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:45:32 T:2712651584  NOTICE: Default DVD Player: dvdplayer
18:45:32 T:2712651584  NOTICE: Default Video Player: dvdplayer
18:45:32 T:2712651584  NOTICE: Default Audio Player: paplayer
18:45:32 T:2712651584  NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:45:32 T:2712651584  NOTICE: Log level changed to 0
18:45:32 T:2712651584  NOTICE: Loading media sources from special://masterprofile/sources.xml
18:45:32 T:2712651584  NOTICE: Running database version Addons15
18:45:32 T:2710453056  NOTICE: Thread XBMC Peripherals start, auto delete: false
18:45:32 T:2712651584  NOTICE: Setup SDL
18:45:32 T:2712651584  NOTICE: Checking resolution 16
18:45:33 T:2712651584  NOTICE: Using visual 0x21
18:45:33 T:2712651584  NOTICE: GL_VENDOR = Intel Open Source Technology Center
18:45:33 T:2712651584  NOTICE: GL_RENDERER = Mesa DRI Intel(R) 965GM
18:45:33 T:2712651584  NOTICE: GL_VERSION = 2.1 Mesa 9.0.1
18:45:33 T:2712651584  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
18:45:33 T:2712651584  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_vertex_program1_1 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_rgb10_a2ui GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_texture_storage GL_ARB_invalidate_subdata
18:45:33 T:2712651584   ERROR: GLX: Same window as before, refreshing context
18:45:33 T:2712651584  NOTICE: Running database version Addons15
18:45:33 T:2712651584  NOTICE: Running database version ViewModes4
18:45:33 T:2712651584  NOTICE: Running database version Textures13
18:45:33 T:2712651584  NOTICE: Running database version MyMusic32
18:45:33 T:2712651584  NOTICE: Running database version MyVideos75
18:45:33 T:2712651584  NOTICE: Running database version TV22
18:45:33 T:2712651584  NOTICE: Running database version Epg7
18:45:33 T:2712651584  NOTICE: start dvd mediatype detection
18:45:33 T:2712651584  NOTICE: initializing playlistplayer
18:45:33 T:2712651584  NOTICE: DONE initializing playlistplayer
18:45:33 T:2710784832  NOTICE: Thread CDetectDVDMedia start, auto delete: false
18:45:33 T:2712651584 WARNING: CreateFile, successfuly opened </home/irenicus/.xbmc/addons/skin.diffuse/colors/grey.xml> instead of </home/irenicus/.xbmc/addons/skin.diffuse/colors/Grey.xml>
18:45:34 T:2567957312  NOTICE: Thread XBPyThread start, auto delete: false
18:45:34 T:2712651584  NOTICE: Previous line repeats 3 times.
18:45:34 T:2712651584  NOTICE: initialize done
18:45:34 T:2712651584  NOTICE: Running the application...
18:45:34 T:2712651584  NOTICE: ES: Starting event server
18:45:34 T:2517601088  NOTICE: Thread CTCPServer start, auto delete: false
18:45:34 T:2525993792  NOTICE: Thread CEventServer start, auto delete: false
18:45:34 T:2525993792  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:45:34 T:2525993792  NOTICE: UDP: Listening on port 9777
18:45:34 T:2712651584  NOTICE: starting zeroconf publishing
18:45:34 T:2534386496  NOTICE: Thread XBPyThread start, auto delete: false
18:45:34 T:2500815680  NOTICE: Thread Jobworker start, auto delete: true
18:45:34 T:2567957312  NOTICE: -->Python Interpreter Initialized<--
18:45:34 T:2559564608  NOTICE: -->Python Interpreter Initialized<--
18:45:34 T:2534386496  NOTICE: -->Python Interpreter Initialized<--
18:45:34 T:2551171904  NOTICE: -->Python Interpreter Initialized<--
18:45:34 T:2542779200  NOTICE: -->Python Interpreter Initialized<--
18:45:34 T:2534386496  NOTICE:  StorageServer Module loaded RUN
18:45:34 T:2534386496  NOTICE: StorageClient-2.5.0 Starting server
18:45:34 T:2534386496  NOTICE: StorageServer-2.5.0 Storage Server starting /home/irenicus/.xbmc/userdata/addon_data/script.common.plugin.cache/commoncache.db
18:45:34 T:2551171904  NOTICE: Artwork Downloader: ## Service - Run at startup: False
18:45:34 T:2551171904  NOTICE: Artwork Downloader: ## Service - Delayed startup:  minutes
18:45:34 T:2551171904  NOTICE: Artwork Downloader: ## Service - Run as service: False
18:45:34 T:2551171904  NOTICE: Artwork Downloader: ## Service - Time: :00
18:45:42 T:2551171904  NOTICE: Thread Jobworker start, auto delete: true
18:45:42 T:2559564608  NOTICE: Thread XBPyThread start, auto delete: false
18:45:42 T:2559564608  NOTICE: -->Python Interpreter Initialized<--
18:45:42 T:2452134720  NOTICE: Thread Jobworker start, auto delete: true
18:45:42 T:2481814336  NOTICE: Thread CRssReader start, auto delete: false
18:45:45 T:2443742016  NOTICE: Thread Background Loader start, auto delete: false
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
I'm running Openbox @Sabayon 3.8 with the latest updates installed. If there's any more info I can provide to help let me know.
Thanks.
chasha420
Re: XBMC not working after latest update
Postby wolfden » Fri Mar 08, 2013 20:36
Postby chasha420 » Sun Apr 07, 2013 5:40
Seems like the problem has been fixed. Thank you guys :)
chasha420
Users browsing this forum: msdobrescu and 2 guests
