Steam - libSDL2-2.0.so.0 is missing [Solved]
Postby B3rtm3n » Tue Mar 05, 2013 16:22
Steam updated today and I got following error message:
You are missing the following 32-bit libraries, and Steam may not run:
libSDL2-2.0.so.0
Now steam does not start anymore .
Does anyone has a solution?
Ps. I also noticed that since almost 2 weeks no new updates/upgrades were released, is this correct?
B3rtm3n
Re: Steam - libSDL2-2.0.so.0 is missing
Postby Matte88 » Tue Mar 05, 2013 16:47
I see no library on my Sabayon box
# find / -name "libSDL2-2.0.so.0"
and also there are no belonging packages!
media-libs/libsdl-1.2.15-r2 branch: 5, [sabayonlinux.org]
>>         Disponibile:   versione: 1.2.15-r2 ~ tag: NoTag ~ revisione: 0
>>         Installato:    versione: 1.2.15-r2 ~ tag: NoTag ~ revisione: 0
>>         Slot:          0
>>         Homepage:      http://www.libsdl.org/
>>         Descrizione:   Simple Direct Media Layer
>>         Licenza:       LGPL-2.1
Damn Valve... It seems to be highly sperimental!!!
SDL 2.0 (WARNING: UNDER CONSTRUCTION):
hg clone http://hg.libsdl.org/SDL
You can build directly from a fresh clone of SDL 2.0.
SOURCE
Hope future developments won't be Linux is Ubuntu for Steam, and other distros will have to wait... :evil:
When I became the sun,
I shone life into the man's hearts.
Matte88
Location: @/etc/entropy/repositories.conf.d/entropy_sabayon-limbo
Postby cl00t » Tue Mar 05, 2013 19:39
Hi, can't help re steam but there were no updates to weekly this past weekend.
cl00t
Postby iScream » Wed Mar 06, 2013 15:16
Found the solution on Steam discussion:
Delete the file
~./steam/steam/package/beta
, this will opt you out of beta, and Steam will start up like it used to.
iScream
Postby B3rtm3n » Wed Mar 06, 2013 18:33
I am unable to locate this package , where is it in Sabayon
B3rtm3n
Postby Matte88 » Wed Mar 06, 2013 22:54
B3rtm3n wrote:I am unable to locate this package , where is it in Sabayon
$ find ~ -name "beta"
Btw, you can however remove yourself from beta branch, search for the option inside Steam settings.
Matte88
Postby B3rtm3n » Thu Mar 07, 2013 5:53
Ok, I used Dolphin to search but forgot to enable hidden files.
It is located in: /home/yourusername/.local/share/Steam/package/beta
Will give it a try...
B3rtm3n
Postby B3rtm3n » Thu Mar 07, 2013 17:22
It did not work (btw I am not in steam beta)
what I did was removing clientregistry.blob in the steam folder and everything located in the folder /.local/share/Steam/package/
restarted steam and it works
B3rtm3n
Re: Steam - libSDL2-2.0.so.0 is missing [Solved]
Postby Matte88 » Fri Mar 08, 2013 14:16
Remember adding [SOLVED] to the title of your 1st post.
Matte88
Postby colock » Sat Mar 09, 2013 18:32
s/[SOLVED]/[Solved]/g
colock
