Kazam Screencaster not working
Postby ryutenchi » Fri Mar 01, 2013 7:18
First of all the Kazam in the repo is pretty old. Also, it simply doesn't work anymore. Whenever you try to record it kicks back this error in the console:
ERROR Kazam      - Could not find any typelib for AppIndicator3
/usr/lib64/python2.7/site-packages/gobject/constants.py:24: Warning: g_boxed_type_register_static: assertion `g_type_from_name (name) == 0' failed
  import gobject._gobject
** Message: pygobject_register_sinkfunc is deprecated (GstObject)
  File "/usr/lib64/python2.7/site-packages/kazam/app.py", line 385, in cb_record_clicked
    region)
  File "/usr/lib64/python2.7/site-packages/kazam/backend/gstreamer.py", line 85, in setup_sources
    self.setup_video_source()
  File "/usr/lib64/python2.7/site-packages/kazam/backend/gstreamer.py", line 102, in setup_video_source
    self.videosrc = gst.element_factory_make("ximagesrc", "video_src")
gst.ElementNotFoundError: ximagesrc
I tried downloading the latest version from https://launchpad.net/kazam (only place I coud find it), and installed and eselected python 3 to try to get it to work, but then it kicked back when trying to install with the script provided with this:
  File "Downloads/kazam-1.3.101-0ubuntu1/setup.py", line 8, in <module>
    from DistUtilsExtra.command import *
ImportError: No module named DistUtilsExtra.command
has anyone gotten Kazam to work and if so, how?
Thanks for your help!
-Matt
ryutenchi
Re: Kazam Screencaster not working
Postby Ryuno-Ki » Fri Mar 01, 2013 10:55
Hm, I do not use Kazam, but if I have a look into the README, installation shall be done this way:
For distribution independent installation you will have to get the latest
tarball release from Launchpad:
http://launchpad.net/kazam/stable/1.4.0/+download/kazam_1.4.0.tar.gz
Unpack it and then run setup:
   $ tar -xzf kazam_1.4.0.tar.gz
   $ cd kazam-1.4.0
Run installation as root user, or use sudo:
   # python setup.py install
How did you do it? By the way, Launchpad is the only place, where the code is hosted …
It also recommend to run Kazam with --debug option when problems occur.
I could not find any hint, that Python3 is used.
Concerning your bug with Python 2.7: There's a bug report, which recommends to check, whether the following plugins are installed:
gst-plugins-base-1.0, gst-plugins-good-1.0 and gst-plugins-1.0. gst-plugins-ximagesrc-1.0 may help, too.
Ryuno-Ki
Postby Stupot » Fri Mar 01, 2013 18:26
I see the bug you opened:
https://bugs.launchpad.net/kazam/+bug/1132321
According to his response, the package could be missing some dependencies:
http://packages.sabayon.org/show/kazam, ... -show-what
He said that it needs the ugly plugins, which isn't included in that list:
#equo install media-libs/gst-plugins-ugly
However, the traceback seems to indicate that ximagesrc is where the problem lies, so I would try installing that package again, just for good measure.
#equo install media-plugins/gst-plugins-ximagesrc
Postby ryutenchi » Fri Mar 01, 2013 23:43
@Stupot and Ryuno-ki:
Thank you both for your quick replies! Unfortunately I have all of those packages installed and have tried the setup script as both normal user and root. However, in verifying that I had those packages installed I did notice that I had all but the gst-plugins-ximagesrc 0.10 version installed along side the 1.0 version... do you think this could be the issue? that it's trying to use the .10 version for some reason? How would I change/test that?
ryutenchi
