SL 11-KDE:Now possible to unmount ext hdd [Solved]
Postby linuxfluesterer » Sat Feb 16, 2013 18:30
Hallo guys.
Welcome SL 11.
I just downloaded SL 11 KDE 4.9.5-64bit, created a USB-Memory stick and launched my laptop with. So far, so good.
Graphics is nice, sound ok ... all in all for the first view it looks good.
There is one problem I have on my actual system now (SL X KDE 4.9.5), mentioned in many forums and here maybe also.
It still exists in SL 11. Pls. consider, I use Live System.
After mounting my USB3-1TByte ext. disk, I can't unmount it in Dolphin. When I try click 'Savely unmount' then I receive:
~umount /media/Toshiba-1TB-jfs/
umount: /media/Toshiba-1TB-jfs: target is busy.
        (In some cases useful info about processes that use
         the device is found by lsof(8) or fuser(1))
I can't also unmount as root in a cli. So, I did an:
lsof | grep '/media/Toshiba-1TB-jfs/'
and received:
nepomukse 12144       sabayonuser   22r      DIR               8,49     4096       4096 /media/Toshiba-1TB-jfs/Backup
nepomukse 12144       sabayonuser   24r      DIR               8,49       16          2 /media/Toshiba-1TB-jfs
nepomukse 12144       sabayonuser   25r      DIR               8,49        8    7165984 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012
nepomukse 12144       sabayonuser   28r      DIR               8,49     4096    7165703 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric
nepomukse 12144       sabayonuser   29r      DIR               8,49       72    7165732 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr
nepomukse 12144       sabayonuser   30r      DIR               8,49     4096    7189645 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share
nepomukse 12144       sabayonuser   31r      DIR               8,49    12288    6587946 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc
nepomukse 12144       sabayonuser   32r      DIR               8,49        8    7089300 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde
nepomukse 12144       sabayonuser   33r      DIR               8,49     4096    7226138 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML
nepomukse 12144       sabayonuser   34r      DIR               8,49     4096    7226160 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en
nepomukse 12144       sabayonuser   35r      DIR               8,49     4096    7248000 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en/kcontrol
nepomukse 12144       sabayonuser   36r      DIR               8,49       40    7248004 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en/kcontrol/bookmarks
QThread   12144 12168 sabayonuser   22r      DIR               8,49     4096       4096 /media/Toshiba-1TB-jfs/Backup
QThread   12144 12168 sabayonuser   24r      DIR               8,49       16          2 /media/Toshiba-1TB-jfs
QThread   12144 12168 sabayonuser   25r      DIR               8,49        8    7165984 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012
QThread   12144 12168 sabayonuser   28r      DIR               8,49     4096    7165703 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric
QThread   12144 12168 sabayonuser   29r      DIR               8,49       72    7165732 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr
QThread   12144 12168 sabayonuser   30r      DIR               8,49     4096    7189645 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share
QThread   12144 12168 sabayonuser   31r      DIR               8,49    12288    6587946 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc
QThread   12144 12168 sabayonuser   32r      DIR               8,49        8    7089300 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde
QThread   12144 12168 sabayonuser   33r      DIR               8,49     4096    7226138 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML
QThread   12144 12168 sabayonuser   34r      DIR               8,49     4096    7226160 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en
QThread   12144 12168 sabayonuser   35r      DIR               8,49     4096    7248000 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en/kcontrol
QThread   12144 12168 sabayonuser   36r      DIR               8,49       40    7248004 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en/kcontrol/bookmarks
QInotifyF 12144 12171 sabayonuser   22r      DIR               8,49     4096       4096 /media/Toshiba-1TB-jfs/Backup
QInotifyF 12144 12171 sabayonuser   24r      DIR               8,49       16          2 /media/Toshiba-1TB-jfs
QInotifyF 12144 12171 sabayonuser   25r      DIR               8,49        8    7165984 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012
QInotifyF 12144 12171 sabayonuser   28r      DIR               8,49     4096    7165703 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric
QInotifyF 12144 12171 sabayonuser   29r      DIR               8,49       72    7165732 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr
QInotifyF 12144 12171 sabayonuser   30r      DIR               8,49     4096    7189645 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share
QInotifyF 12144 12171 sabayonuser   31r      DIR               8,49    12288    6587946 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc
QInotifyF 12144 12171 sabayonuser   32r      DIR               8,49        8    7089300 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde
QInotifyF 12144 12171 sabayonuser   33r      DIR               8,49     4096    7226138 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML
QInotifyF 12144 12171 sabayonuser   34r      DIR               8,49     4096    7226160 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en
QInotifyF 12144 12171 sabayonuser   35r      DIR               8,49     4096    7248000 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en/kcontrol
QInotifyF 12144 12171 sabayonuser   36r      DIR               8,49       40    7248004 /media/Toshiba-1TB-jfs/Backup/Oneiric_2012/Oneiric/usr/share/doc/kde/HTML/en/kcontrol/bookmarks
I can't unmount only my USB3-1TByte disk with jfs. But another USB2! ext. disk with 500GByte with jfs I can easily unmount this 500Gb disk. Because of no error appears then.
Is this still a problem with Nepomuk??? I read, Nepomuk got better. Or is it maybe a 'JFS' problem?
And what can I do to my ext USB3-disk? Any idea?
Last edited by linuxfluesterer on Sun Feb 17, 2013 14:33, edited 3 times in total.
linuxfluesterer
Re: SL 11-KDE:Still not possible to unmount ext hdd
Postby sabayonino » Sat Feb 16, 2013 18:43
Disable Nepomuk service
System Settings --->
Postby linuxfluesterer » Sat Feb 16, 2013 21:21
Thank you for fast reply, Sabayonino...
I did what you've recommended. And now, I don't receive any error.
But .... then the conclusion is, that Nepomuk is buggy, am I right?
And this is a KDE project problem or?
I thought, Nepomuk is a 'backbone' of handling files KDE system.
linuxfluesterer
Postby sabayonino » Sat Feb 16, 2013 23:01
linuxfluesterer wrote:Thank you for fast reply, Sabayonino...
check NepomukService Options .
Some options enable file indexing for removable media.
Set your Own.
In my case , (I'm using KDE) i disable fileindexing for all removable media
I don't think nepomuk is buggy but this service could keep busy some localfilesystem
Re: SL 11-KDE:Still not possible to unmount ext hdd [Solved]
Postby linuxfluesterer » Sat Feb 16, 2013 23:44
As I said before, my 500GByte ext. disk is easily to be unmounted.
I checked, that removable media are set not to be indexed.
So, why my 500GByte (USB2) disk is not indexed and can be unmounted and
my 1TByte (USB3) disk is indexed (though removable) and can NOT be unmounted?
Pls. see, that both medias are removable medias with same file system JFS.
Good night for today, Sabayonino.
linuxfluesterer
Postby sabayonino » Sun Feb 17, 2013 1:10
external drives are mounted under /media folder
check and disabled file index for this directory (/media)
Postby linuxfluesterer » Sun Feb 17, 2013 11:42
Dear Sabayonino.
I know, that removable medias are mounted in /media (because I often use cli and mc to handle with).
But my question was, why is it possible to unmount my 500GByte ext. disk (/media/SGT-500GB-jfs)
but NOT my 1TByte ext. disk (/media/Toshiba-1TB-jfs)?
And ... I googled, that other person have the same problem with this topic.
linuxfluesterer
Dear Sabayonino.
linuxfluesterer
Postby sabayonino » Sun Feb 17, 2013 12:25
linuxfluesterer wrote:Dear Sabayonino.
Check "Device Notification" options (in system tray)---> removable devices (or something like)
I'm suppose that there are some options to disable regarding automount ....
Postby linuxfluesterer » Sun Feb 17, 2013 13:05
Ciao Sabayonino.
I don't automount...
I mount manually in every case of removable medias (USB-memory stick, USB ext. disk...).
I handle all medias manually, mount them, unmount them in Dolphin.
Memory sticks and 500GByte jfs disk (also another one ext. disk with NTFS) can be unmounted without errors,
but 1TByte ext. disk can NOT be unmounted (with activated Nepomuk).
By the way, do you have a big (USB3) ext. hdd with 1TByte or more? Did you try mount and unmount?
I mean, without changing any settings, just when run from Live system or just after fresh install on your internal disk.
linuxfluesterer
