Login screen in sabayon 10
Postby pherynk » Thu Feb 14, 2013 18:16
I very appreciate new login screen in sabayon. But after logging screen is changing to old one with X. Any help is welcomed.
pherynk
Re: Login screen in sabayon 10
Postby Ryuno-Ki » Fri Feb 15, 2013 10:17
Which display manager do you use?
$ tail -n 1 /etc/conf.d/xdm
Ryuno-Ki
Postby lexonight » Thu Mar 07, 2013 3:53
Confirmed the x screen login doesn't work so you can
ctrl + alt + F1
and login there then reinstall kdm or gdm depending on your setup
equo install kdm --ask
or
equo install gdm --ask
if you have access to the internet another app you might want is lynx for searching for help
lexonight
Postby sabayonino » Thu Mar 07, 2013 13:43
i think that it 's cache prob.
you can find new wallpèaper in /usr/share/backgrounds.
