Here's my ~/xbmc_crashlog:
- Code: Select all
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Feb 6 20:28:55 CET 2013
XBMC Options:
Arch: x86_64
Kernel: Linux 3.7.0-sabayon #1 SMP Thu Dec 20 07:12:55 UTC 2012
Release: lsb_release not available
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
20:25:17 T:140414359332800 NOTICE: -----------------------------------------------------------------------
20:25:17 T:140414359332800 NOTICE: Starting XBMC (12.0-RC3 Git:exported), Platform: Linux (Gentoo Base System release 2.2, 3.7.0-sabayon x86_64). Built on Jan 31 2013
20:25:17 T:140414359332800 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:25:17 T:140414359332800 NOTICE: special://xbmcbin/ is mapped to: /usr/lib64/xbmc
20:25:17 T:140414359332800 NOTICE: special://masterprofile/ is mapped to: /home/reemz/.xbmc/userdata
20:25:17 T:140414359332800 NOTICE: special://home/ is mapped to: /home/reemz/.xbmc
20:25:17 T:140414359332800 NOTICE: special://temp/ is mapped to: /home/reemz/.xbmc/temp
20:25:17 T:140414359332800 NOTICE: The executable running is: /usr/lib64/xbmc/xbmc.bin
20:25:17 T:140414359332800 NOTICE: Local hostname: ReemZ-SLMC.fritz.box
20:25:17 T:140414359332800 NOTICE: Log File is located: /home/reemz/.xbmc/temp/xbmc.log
20:25:17 T:140414359332800 NOTICE: load settings...
20:25:17 T:140414359332800 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:25:17 T:140414359332800 NOTICE: loading special://masterprofile/guisettings.xml
20:25:17 T:140414359332800 NOTICE: Getting hardware information now...
20:25:17 T:140414359332800 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:25:17 T:140414359332800 NOTICE: Loaded playercorefactory configuration
20:25:17 T:140414359332800 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:25:17 T:140414359332800 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:25:17 T:140414359332800 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:25:17 T:140414359332800 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:25:17 T:140414359332800 NOTICE: Default DVD Player: dvdplayer
20:25:17 T:140414359332800 NOTICE: Default Video Player: dvdplayer
20:25:17 T:140414359332800 NOTICE: Default Audio Player: paplayer
20:25:17 T:140414359332800 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:25:17 T:140414359332800 NOTICE: Log level changed to 0
20:25:17 T:140414359332800 NOTICE: Loading media sources from special://masterprofile/sources.xml
20:25:17 T:140414359332800 NOTICE: Running database version Addons15
20:25:18 T:140414008243968 NOTICE: Thread XBMC Peripherals start, auto delete: false
20:25:18 T:140414359332800 NOTICE: Setup SDL
20:25:18 T:140414359332800 NOTICE: Checking resolution 16
20:25:18 T:140414359332800 NOTICE: Using visual 0x28d
20:25:19 T:140414359332800 NOTICE: GL_VENDOR = NVIDIA Corporation
20:25:19 T:140414359332800 NOTICE: GL_RENDERER = GeForce 7100 / nForce 630i/integrated/SSE2
20:25:19 T:140414359332800 NOTICE: GL_VERSION = 2.1.2 NVIDIA 304.64
20:25:19 T:140414359332800 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20 NVIDIA via Cg compiler
20:25:19 T:140414359332800 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_
map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_
packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_ES1_1_
compatibility GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_OES_compressed_paletted_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_
render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_rgb8_rgba8 GL_OES_read_format GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
20:25:19 T:140414359332800 ERROR: GLX: Same window as before, refreshing context
20:25:19 T:140414359332800 NOTICE: Running database version Addons15
20:25:19 T:140414359332800 NOTICE: Running database version ViewModes4
20:25:19 T:140414359332800 NOTICE: Running database version Textures13
20:25:19 T:140414359332800 NOTICE: Running database version MyMusic32
20:25:19 T:140414359332800 NOTICE: Running database version MyVideos75
20:25:19 T:140414359332800 NOTICE: Running database version TV22
20:25:19 T:140414359332800 NOTICE: Running database version Epg7
20:25:19 T:140414359332800 NOTICE: start dvd mediatype detection
20:25:19 T:140414359332800 NOTICE: initializing playlistplayer
20:25:19 T:140414359332800 NOTICE: DONE initializing playlistplayer
20:25:19 T:140414358017792 NOTICE: Thread CDetectDVDMedia start, auto delete: false
20:25:20 T:140414359332800 NOTICE: initialize done
20:25:20 T:140414359332800 NOTICE: Running the application...
20:25:20 T:140413805131520 NOTICE: Thread Jobworker start, auto delete: true
20:25:20 T:140414359332800 NOTICE: ES: Starting event server
20:25:20 T:140414359332800 NOTICE: starting zeroconf publishing
20:25:20 T:140413796738816 NOTICE: Thread CEventServer start, auto delete: false
20:25:20 T:140413796738816 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:25:20 T:140413796738816 NOTICE: UDP: Listening on port 9777
20:25:20 T:140413788346112 NOTICE: Thread CTCPServer start, auto delete: false
20:25:20 T:140413771560704 NOTICE: Thread Jobworker start, auto delete: true
20:25:20 T:140414357788416 NOTICE: Thread CRssReader start, auto delete: false
20:25:20 T:140413527648000 NOTICE: Thread CFileCache start, auto delete: false
20:25:22 T:140413527648000 NOTICE: Thread Background Loader start, auto delete: false
20:25:24 T:140413527648000 NOTICE: Previous line repeats 2 times.
20:25:24 T:140413527648000 NOTICE: Thread CFileCache start, auto delete: false
20:25:25 T:140413527648000 NOTICE: Previous line repeats 1 times.
20:25:25 T:140413527648000 NOTICE: Thread Jobworker start, auto delete: true
20:25:25 T:140413549672192 NOTICE: Thread CFileCache start, auto delete: false
20:25:25 T:140413549672192 NOTICE: Thread Jobworker start, auto delete: true
20:25:25 T:140413541279488 NOTICE: Thread Background Loader start, auto delete: false
20:25:25 T:140413519255296 NOTICE: Thread CFileCache start, auto delete: false
20:25:25 T:140413541279488 NOTICE: Thread CFileCache start, auto delete: false
20:25:27 T:140413541279488 NOTICE: Thread Background Loader start, auto delete: false
20:25:31 T:140413541279488 NOTICE: Previous line repeats 9 times.
20:25:31 T:140413541279488 NOTICE: Thread CFileCache start, auto delete: false
20:25:31 T:140413519255296 NOTICE: Thread PAPlayer start, auto delete: false
20:25:31 T:140414021089024 WARNING: PulseAudio: Stream underflow
20:25:31 T:140413510862592 NOTICE: Thread Background Loader start, auto delete: false
20:25:31 T:140414021089024 NOTICE: Previous line repeats 1 times.
20:25:38 T:140413805131520 WARNING: Previous line repeats 2 times.
20:25:38 T:140413805131520 WARNING: FillBuffer: curl failed with code 28
20:25:38 T:140413805131520 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
20:25:38 T:140413805131520 ERROR: DeleteFile - cant delete file </home/reemz/.xbmc/addons/packages/metadata.artists.universal-2.6.0.zip>. trying lower case </home/reemz/.xbmc/addons/packages/metadata.artists.universal-2.6.0.zip>
20:25:38 T:140413510862592 NOTICE: Thread Background Loader start, auto delete: false
20:25:40 T:140414021089024 NOTICE: Previous line repeats 1 times.
20:25:40 T:140414021089024 WARNING: PulseAudio: Stream underflow
20:28:50 T:140413805131520 WARNING: Previous line repeats 404 times.
20:28:50 T:140413805131520 NOTICE: Thread CFileCache start, auto delete: false
20:28:50 T:140414021089024 WARNING: PulseAudio: Stream underflow
20:28:55 T:140413541279488 WARNING: Previous line repeats 21 times.
20:28:55 T:140413541279488 NOTICE: Thread Jobworker start, auto delete: true
20:28:55 T:140414021089024 WARNING: PulseAudio: Stream underflow
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
lspci -knn:
- Code: Select all
00:09.0 Audio device [0403]: NVIDIA Corporation MCP73 High Definition Audio [10de:07fc] (rev a1)
Subsystem: Giga-byte Technology Device [1458:a002]
Kernel driver in use: snd_hda_intel
Any ideas?
