LiVES not launching [Solved]
Postby osoloco » Tue Jan 22, 2013 3:19
When I try to run LiVES (video editor) from the cli I get the following error:
lives: error while loading shared libraries: liboil-0.3.so.0: cannot open shared object file: No such file or directory
I am running updated Sabayon X, kernel 3.5.0 on Intel 2.4Ghz, 4GB Ram.
osoloco
Re: LiVES not launching
Postby wolfden » Tue Jan 22, 2013 9:00
please file a bug report https://bugs.sabayon.org/
Postby sabayonino » Tue Jan 22, 2013 20:20
(re)Install dev-libs/liboil-0.3.17 ??
Postby osoloco » Tue Jan 22, 2013 22:43
sabayonino wrote:(re)Install dev-libs/liboil-0.3.17 ??
Obvious, right?
Previously I tried to re-install with Rigo, but it did't found. After your suggestion I tried with equo and ... voilá :oops:
Now LiVES is working fine.
Thank you!
osoloco
