LibreOffice - segfault
Postby bizonek » Wed Jan 16, 2013 21:32
Hi
After upgrade to new version LibreOffice stop working and from dmesg I get
[11815.909779] soffice.bin[648]: segfault at cdf0e0 ip 0000000000cdf0e0 sp 00007fffce93ec18 error 15
I have check system with deptest and libtest, nothing find.
If I run this from sudo it's working ;/ any ideas.
bizonek
Re: LibreOffice - segfault
Postby ignition » Mon Jan 21, 2013 11:33
The segfault problem with LibreOffice also exist on my system, the difference is that even 'sudo libreoffice' doesn't work. So no help for your problem yet but I will follow these threads with the biggest interest!
ignition
Postby ignition » Mon Feb 04, 2013 14:36
I have filed a bugreport in bugzilla:
https://bugs.sabayon.org/show_bug.cgi?id=3973
There are probably more people with the same problem:
viewtopic.php?f=86&t=28973
ignition
Postby ignition » Thu Feb 07, 2013 20:25
I solved the issue by deleting /home/USER/.config/libreoffice
ignition
Users browsing this forum: sigahotcore and 1 guest
