Images not being displayed in web browser [Solved]
Postby gocool » Wed Jan 16, 2013 5:55
My Sabayon is current. Only yesterday there were some updates which were sent out and I updated them all using "equo upgrade" and that updated my Firefox to version 18. But it doesnt display any images, say if I go to http://images.google.com and search for ipad (or any other images), all I get is grey boxes. I thought this is specific to firefox and did everything as mentioned here but nothing helped.
I then installed chromium browser to check if the issue exists...and even there the same problem...what could be the issue? and how to resolve it?
Any help on this will be highly appreciated.
gocool
Re: Images not being displayed in web browser
Postby wolfden » Wed Jan 16, 2013 6:54
Do you have media-libs/jpeg-8d installed? If so uninstall
equo remove media-libs/jpeg-8d --nodeps
than
equo install media-libs/libjpeg-turbo
otherwise check the log files
http://bugs.sabayon.org/show_bug.cgi?id=3791
Postby gocool » Wed Jan 16, 2013 14:09
Thank you Wolfden, that worked.
I see an earlier version (media-libs/jpeg-6b-r9) installed too, do you want me to remove that? Or is this something else.
gocool
Firefox 18.0 and Chromium don't show jpg [Solved]
Postby der kaltmacher » Thu Jan 24, 2013 8:27
Since the update on firefox-18.0 (and also gnome 3.6) the browser don't show any jpg pictures. Also video previews (e.g. youtube) not shown. I think its a dependecy problem because chromium don't show this pictures too.
der kaltmacher
Re: Firefox 18.0 and Chromium don't show jpg
Postby dunsurfin » Thu Jan 24, 2013 9:25
Self-righteousness is a loud din raised to drown
the voice of guilt within us - Eric Hoffer
dunsurfin
Postby der kaltmacher » Thu Jan 24, 2013 18:03
Thanks a lot dunsurfin! That was it. After removing jpeg-8d and reinstalling libjpeg-turbo everything works like a charme :D .
der kaltmacher
Postby wolfden » Fri Jan 25, 2013 3:55
merged, please use Search :)
Postby Ryuno-Ki » Fri Jan 25, 2013 10:21
Ryuno-Ki
Re: Images not being displayed in web browser [Solved]
Postby steffie » Tue Feb 05, 2013 3:09
many thx wolfden,
solved my probs in Chromium + Firefox too....
cu, hf, stephan
steffie
