Mediatomb "segmentation failure" [Solved]
Postby greendave8 » Sat Jan 12, 2013 22:11
Hi Folks,
I just updated and find that mediatomb no longer works.
christine@dave-sabayon ~ $ mediatomb
MediaTomb UPnP Server version 0.12.1 - http://mediatomb.cc/
Copyright 2005-2010 Gena Batsyan, Sergey Bostandzhyan, Leonhard Wimmer.
MediaTomb is free software, covered by the GNU General Public License version 2
2013-01-12 21:07:32    INFO: Loading configuration from: /home/christine/.mediatomb/config.xml
2013-01-12 21:07:32    INFO: Checking configuration...
2013-01-12 21:07:32    INFO: Setting filesystem import charset to UTF-8
2013-01-12 21:07:32    INFO: Setting metadata import charset to UTF-8
2013-01-12 21:07:32    INFO: Setting playlist charset to UTF-8
2013-01-12 21:07:32 WARNING: You enabled the YouTube feature, which allows you
                             to watch YouTube videos on your UPnP device!
                             Please check http://www.youtube.com/t/terms
                             By using this feature you may be violating YouTube
                             service terms and conditions!
2013-01-12 21:07:32    INFO: Configuration check succeeded.
2013-01-12 21:07:32    INFO: Initialized port: 49152
2013-01-12 21:07:32    INFO: Server bound to: 192.168.1.46
2013-01-12 21:07:33    INFO: MediaTomb Web UI can be reached by following this link:
2013-01-12 21:07:33    INFO: http://192.168.1.46:49152/
Segmentation fault
I cannot access mt through the http address, and have no way of making adjustments to it. My PS3 sees mediatomb, but there are no files.... Help please...
TIA
gd8
greendave8
Re: Mediatomb "segmentation failure"
Postby anomaly65 » Sat Jan 19, 2013 23:44
Hi greendave8 :D
I've been running mediatomb on sabayon for a couple years now. Gonna include my [diffs from the defaults] config and such. Hope this helps, feel free to ask anything that might help too :) I don't do any transcoding or other nice features but there's decent info on that over on the mediatomb website.
I created (a disabled user) mediatomb to give it a home, and in /etc/conf.d/mediatomb set the following (been a while....):
MEDIATOMB_USER="mediatomb"
in /etc/mediatomb/config.xml I didn't make many changes but here they are, no location changes to these settings either (comments after the # symbol, not actually in the file itself):
<name>MegaTomb</name>  # why not have fun with the name eh?
<udn>uuid:5fc714bb-fe9d-4a6b-8cd2-8d4d653ee89a</udn> # auto generated IIRC...
<home>/export/home/mediatomb</home>  # set to home directory, thus mediatomb survives massive upgrades or OS rebuild (database gets store there as well)
ONE thing that did happen (my collection is massive; 6-7Tbytes...) is the db file gets chewed once in a while. Known bug, may be fixed at this point.
I did a fresh start when this happened like so:
(with mediatomb not running of course)
cat /dev/null > /export/home/mediatomb/mediatomb.db
then just
/etc/init.d/mediatomb start
visit the URL for it and start adding directories and the db usually gets filled in reasonable time.
Hope that helps, and good luck!!
andy
anomaly65
Postby greendave8 » Sun Jan 20, 2013 13:12
Thanks Andy,
I tried all that, and it still says....segmentation failure.....
Dunno what the problem is....I will wait for next updates....
cheers and thanks again for the help
gd8
greendave8
Postby Thev00d00 » Sun Jan 20, 2013 13:35
I would open a bug for this - it probably just needs a rebuild.
Check your /var/log/messages and dmesg also.
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby greendave8 » Sun Jan 20, 2013 14:23
Hi The VooDoo,
Dmesg says:
dave-sabayon christine # dmesg
[    0.903616] scsi8 : ahci
[    0.903681] scsi9 : ahci
[    0.903736] ata9: SATA max UDMA/133 abar m512@0xfa110000 port 0xfa110100 irq 48
[    0.903739] ata10: SATA max UDMA/133 abar m512@0xfa110000 port 0xfa110180 irq 48
[    0.905393] libphy: Fixed MDIO Bus: probed
[    0.905420] cnic: Broadcom NetXtreme II CNIC Driver cnic v2.5.14 (Sep 30, 2012)
[    0.905528] I2O subsystem v1.325
[    0.905529] i2o: max drivers = 8
[    0.905618] I2O Configuration OSM v1.323
[    0.905677] I2O Bus Adapter OSM v1.317
[    0.905699] I2O Block Device OSM v1.325
[    0.905795] I2O SCSI Peripheral OSM v1.316
[    0.905814] I2O ProcFS OSM v1.316
[    0.905835] Fusion MPT base driver 3.04.20
[    0.905836] Copyright (c) 1999-2008 LSI Corporation
[    0.905838] Fusion MPT SPI Host driver 3.04.20
[    0.905864] Fusion MPT FC Host driver 3.04.20
[    0.905890] Fusion MPT SAS Host driver 3.04.20
[    0.905915] Fusion MPT misc device (ioctl) driver 3.04.20
[    0.905946] mptctl: Registered with Fusion MPT base driver
[    0.905947] mptctl: /dev/mptctl @ (major,minor=10,220)
[    0.905948] Fusion MPT LAN driver 3.04.20
[    0.906026] Initializing USB Mass Storage driver...
[    0.906050] usbcore: registered new interface driver usb-storage
[    0.906051] USB Mass Storage support registered.
[    0.906071] usbcore: registered new interface driver ums-alauda
[    0.906092] usbcore: registered new interface driver ums-cypress
[    0.906113] usbcore: registered new interface driver ums-datafab
[    0.906133] usbcore: registered new interface driver ums-freecom
[    0.906154] usbcore: registered new interface driver ums-isd200
[    0.906174] usbcore: registered new interface driver ums-jumpshot
[    0.906194] usbcore: registered new interface driver ums-karma
[    0.906214] usbcore: registered new interface driver ums-onetouch
[    0.906234] usbcore: registered new interface driver ums-sddr09
[    0.906254] usbcore: registered new interface driver ums-sddr55
[    0.906274] usbcore: registered new interface driver ums-usbat
[    0.906363] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.909054] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.909058] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.909240] mousedev: PS/2 mouse device common for all mice
[    0.909459] rtc_cmos 00:04: RTC can wake from S4
[    0.909581] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[    0.909608] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.909631] md: linear personality registered for level -1
[    0.909632] md: raid0 personality registered for level 0
[    0.909633] md: raid1 personality registered for level 1
[    0.909634] md: raid10 personality registered for level 10
[    0.909635] md: raid6 personality registered for level 6
[    0.909636] md: raid5 personality registered for level 5
[    0.909636] md: raid4 personality registered for level 4
[    0.909637] md: multipath personality registered for level -4
[    0.909638] md: faulty personality registered for level -5
[    0.909798] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: dm-devel@redhat.com
[    0.909988] cpuidle: using governor ladder
[    0.910097] cpuidle: using governor menu
[    0.910100] ledtrig-cpu: registered to indicate activity on CPUs
[    0.910164] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    0.910986] usbcore: registered new interface driver usbhid
[    0.910987] usbhid: USB HID core driver
[    0.911160] ashmem: initialized
[    0.911309] TCP: bic registered
[    0.911310] NET: Registered protocol family 17
[    0.911345] Key type dns_resolver registered
[    0.917535] fbcondecor: console 0 using theme 'sabayon'
[    1.014186] fbcondecor: switched decor state to 'on' on console 0
[    1.206625] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.207637] ata7: SATA link down (SStatus 0 SControl 300)
[    1.207640] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.207695] ata8: SATA link down (SStatus 0 SControl 300)
[    1.208613] ata10: SATA link down (SStatus 0 SControl 300)
[    1.208651] ata9: SATA link down (SStatus 0 SControl 300)
[    1.208729] ata6.00: ATAPI: TSSTcorp DVDWBD SH-B123L, SB02, max UDMA/100
[    1.210261] ata6.00: configured for UDMA/100
[    1.212861] ata5.00: ATA-8: SAMSUNG HD204UI, 1AQ10001, max UDMA/133
[    1.212865] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.214531] ata5.00: failed to get Identify Device Data, Emask 0x1
[    1.222504] ata5.00: failed to get Identify Device Data, Emask 0x1
[    1.222511] ata5.00: configured for UDMA/133
[    1.222732] scsi 4:0:0:0: Direct-Access     ATA      SAMSUNG HD204UI  1AQ1 PQ: 0 ANSI: 5
[    1.223088] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    1.223115] sd 4:0:0:0: [sda] Write Protect is off
[    1.223116] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.223125] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.223380] sd 4:0:0:0: Attached scsi generic sg0 type 0
[    1.224117] scsi 5:0:0:0: CD-ROM            TSSTcorp DVDWBD SH-B123L  SB02 PQ: 0 ANSI: 5
[    1.226398] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.226401] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.226734] sr 5:0:0:0: Attached scsi CD-ROM sr0
[    1.227009] sr 5:0:0:0: Attached scsi generic sg1 type 5
[    1.254748]  sda: sda1 sda2 sda3 sda4 < sda5 >
[    1.255678] sd 4:0:0:0: [sda] Attached SCSI disk
[    1.255715] registered taskstats version 1
[    1.256851] rtc_cmos 00:04: setting system clock to 2013-01-20 11:31:03 UTC (1358681463)
[    1.258284] Freeing unused kernel memory: 644k freed
[    1.578985] scsi10 : pata_legacy
[    1.579072] ata11: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14
[    1.730848] scsi11 : pata_legacy
[    1.730939] ata12: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
[    1.823219] tsc: Refined TSC clocksource calibration: 3411.127 MHz
[    1.823225] Switching to clocksource tsc
[    1.968705] scsi: <fdomain> Detection failed (no card)
[    2.007994] imm: Version 2.05 (for Linux 2.4.0)
[    2.056333] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.056458] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[    2.056462] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[    2.056576] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    2.060468] ehci_hcd 0000:00:1a.0: debug port 2
[    2.060475] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[    2.060490] ehci_hcd 0000:00:1a.0: irq 23, io mem 0xfa627000
[    2.066028] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    2.066053] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.066056] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.066058] usb usb1: Product: EHCI Host Controller
[    2.066061] usb usb1: Manufacturer: Linux 3.7.0-sabayon ehci_hcd
[    2.066063] usb usb1: SerialNumber: 0000:00:1a.0
[    2.066409] hub 1-0:1.0: USB hub found
[    2.066412] hub 1-0:1.0: 2 ports detected
[    2.066492] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[    2.066494] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[    2.066559] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    2.070441] ehci_hcd 0000:00:1d.0: debug port 2
[    2.070447] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[    2.070450] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xfa626000
[    2.076011] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    2.076030] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.076033] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.076035] usb usb2: Product: EHCI Host Controller
[    2.076038] usb usb2: Manufacturer: Linux 3.7.0-sabayon ehci_hcd
[    2.076040] usb usb2: SerialNumber: 0000:00:1d.0
[    2.076380] hub 2-0:1.0: USB hub found
[    2.076382] hub 2-0:1.0: 2 ports detected
[    2.090032] uhci_hcd: USB Universal Host Controller Interface driver
[    2.099462] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.109292] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    2.109400] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[    2.109563] xhci_hcd 0000:03:00.0: irq 17, io mem 0xfa500000
[    2.109623] xhci_hcd 0000:03:00.0: irq 49 for MSI/MSI-X
[    2.109627] xhci_hcd 0000:03:00.0: irq 50 for MSI/MSI-X
[    2.109630] xhci_hcd 0000:03:00.0: irq 51 for MSI/MSI-X
[    2.109634] xhci_hcd 0000:03:00.0: irq 52 for MSI/MSI-X
[    2.109638] xhci_hcd 0000:03:00.0: irq 53 for MSI/MSI-X
[    2.109641] xhci_hcd 0000:03:00.0: irq 54 for MSI/MSI-X
[    2.109644] xhci_hcd 0000:03:00.0: irq 55 for MSI/MSI-X
[    2.109648] xhci_hcd 0000:03:00.0: irq 56 for MSI/MSI-X
[    2.109760] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.109761] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.109763] usb usb3: Product: xHCI Host Controller
[    2.109764] usb usb3: Manufacturer: Linux 3.7.0-sabayon xhci_hcd
[    2.109765] usb usb3: SerialNumber: 0000:03:00.0
[    2.109867] xHCI xhci_add_endpoint called for root hub
[    2.109868] xHCI xhci_check_bandwidth called for root hub
[    2.109922] hub 3-0:1.0: USB hub found
[    2.109928] hub 3-0:1.0: 2 ports detected
[    2.109973] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    2.110067] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 4
[    2.112988] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    2.112989] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.112990] usb usb4: Product: xHCI Host Controller
[    2.112991] usb usb4: Manufacturer: Linux 3.7.0-sabayon xhci_hcd
[    2.112992] usb usb4: SerialNumber: 0000:03:00.0
[    2.113087] xHCI xhci_add_endpoint called for root hub
[    2.113088] xHCI xhci_check_bandwidth called for root hub
[    2.113148] hub 4-0:1.0: USB hub found
[    2.113154] hub 4-0:1.0: 2 ports detected
[    2.120042] xhci_hcd 0000:06:00.0: xHCI Host Controller
[    2.120180] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 5
[    2.120339] xhci_hcd 0000:06:00.0: irq 16, io mem 0xfa300000
[    2.120398] xhci_hcd 0000:06:00.0: irq 57 for MSI/MSI-X
[    2.120402] xhci_hcd 0000:06:00.0: irq 58 for MSI/MSI-X
[    2.120405] xhci_hcd 0000:06:00.0: irq 59 for MSI/MSI-X
[    2.120409] xhci_hcd 0000:06:00.0: irq 60 for MSI/MSI-X
[    2.120412] xhci_hcd 0000:06:00.0: irq 61 for MSI/MSI-X
[    2.120415] xhci_hcd 0000:06:00.0: irq 62 for MSI/MSI-X
[    2.120419] xhci_hcd 0000:06:00.0: irq 63 for MSI/MSI-X
[    2.120422] xhci_hcd 0000:06:00.0: irq 64 for MSI/MSI-X
[    2.120532] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.120534] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.120535] usb usb5: Product: xHCI Host Controller
[    2.120536] usb usb5: Manufacturer: Linux 3.7.0-sabayon xhci_hcd
[    2.120537] usb usb5: SerialNumber: 0000:06:00.0
[    2.120659] xHCI xhci_add_endpoint called for root hub
[    2.120660] xHCI xhci_check_bandwidth called for root hub
[    2.120714] hub 5-0:1.0: USB hub found
[    2.120720] hub 5-0:1.0: 2 ports detected
[    2.120762] xhci_hcd 0000:06:00.0: xHCI Host Controller
[    2.120803] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 6
[    2.123767] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.123768] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.123769] usb usb6: Product: xHCI Host Controller
[    2.123770] usb usb6: Manufacturer: Linux 3.7.0-sabayon xhci_hcd
[    2.123771] usb usb6: SerialNumber: 0000:06:00.0
[    2.123833] xHCI xhci_add_endpoint called for root hub
[    2.123834] xHCI xhci_check_bandwidth called for root hub
[    2.123868] hub 6-0:1.0: USB hub found
[    2.123874] hub 6-0:1.0: 2 ports detected
[    2.262568] JFS: nTxBlock = 8192, nTxLock = 65536
[    2.285532] RPC: Registered named UNIX socket transport module.
[    2.285534] RPC: Registered udp transport module.
[    2.285535] RPC: Registered tcp transport module.
[    2.285535] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.301282] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[    2.335770] SPL: Loaded module v0.6.0-rc11
[    2.336560] zunicode: module license 'CDDL' taints kernel.
[    2.336561] Disabling lock debugging due to kernel taint
[    2.365649] ZFS: Loaded module v0.6.0-rc12, ZFS pool version 28, ZFS filesystem version 5
[    2.367820] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[    2.379053] fuse init (API version 7.20)
[    2.392717] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    2.392718] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    2.422106] iscsi: registered transport (tcp)
[    2.482129] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    2.482132] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.482440] hub 1-1:1.0: USB hub found
[    2.482503] hub 1-1:1.0: 6 ports detected
[    2.585679] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[    2.699990] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[    2.699993] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.700159] hub 2-1:1.0: USB hub found
[    2.700235] hub 2-1:1.0: 8 ports detected
[    2.725347] device-mapper: dm-log-userspace: version 1.1.0 loaded
[    2.748090] device-mapper: multipath: version 1.5.0 loaded
[    2.766060] device-mapper: multipath queue-length: version 0.1.0 loaded
[    2.786349] device-mapper: multipath round-robin: version 1.0.0 loaded
[    2.804825] device-mapper: multipath service-time: version 0.2.0 loaded
[    2.975577] usb 2-1.1: new high-speed USB device number 3 using ehci_hcd
[    3.064628] usb 2-1.1: New USB device found, idVendor=05e3, idProduct=0606
[    3.064632] usb 2-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.064636] usb 2-1.1: Product: USB2.0 Hub
[    3.065130] hub 2-1.1:1.0: USB hub found
[    3.065376] hub 2-1.1:1.0: 4 ports detected
[    3.141483] usb 2-1.2: new low-speed USB device number 4 using ehci_hcd
[    3.149919] bio: create slab <bio-1> at 1
[    3.223037] usb 2-1.2: New USB device found, idVendor=099a, idProduct=7202
[    3.223040] usb 2-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.223041] usb 2-1.2: Product: Wireless Keyboard/Mouse
[    3.226421] input: Wireless Keyboard/Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input2
[    3.226603] hid-generic 0003:099A:7202.0001: input,hidraw0: USB HID v1.11 Keyboard [Wireless Keyboard/Mouse] on usb-0000:00:1d.0-1.2/input0
[    3.233183] input: Wireless Keyboard/Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/input/input3
[    3.233461] hid-generic 0003:099A:7202.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Wireless Keyboard/Mouse] on usb-0000:00:1d.0-1.2/input1
[    3.269499] PM: Starting manual resume from disk
[    3.306385] usb 2-1.7: new full-speed USB device number 5 using ehci_hcd
[    3.320951] VFS: could not find a valid V7 on dm-0.
[    3.322037] UDF-fs: warning (device dm-0): udf_fill_super: No partition found (1)
[    3.322259] EXT2-fs (dm-0): error: couldn't mount because of unsupported optional features (240)
[    3.322352] EXT3-fs (dm-0): error: couldn't mount because of unsupported optional features (240)
[    3.364276] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[    3.394330] usb 2-1.7: New USB device found, idVendor=0b05, idProduct=179c
[    3.394335] usb 2-1.7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.459385] usb 2-1.1.1: new full-speed USB device number 6 using ehci_hcd
[    3.548729] usb 2-1.1.1: New USB device found, idVendor=03f0, idProduct=a407
[    3.548734] usb 2-1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.548737] usb 2-1.1.1: Product: HP Link-5 micro dongle
[    3.548739] usb 2-1.1.1: Manufacturer: HP
[    3.550662] input: HP HP Link-5 micro dongle as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1:1.0/input/input4
[    3.550791] hid-generic 0003:03F0:A407.0003: input,hidraw2: USB HID v1.11 Keyboard [HP HP Link-5 micro dongle] on usb-0000:00:1d.0-1.1.1/input0
[    3.553903] input: HP HP Link-5 micro dongle as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1:1.1/input/input5
[    3.554108] hid-generic 0003:03F0:A407.0004: input,hiddev0,hidraw3: USB HID v1.11 Mouse [HP HP Link-5 micro dongle] on usb-0000:00:1d.0-1.1.1/input1
[    3.627289] usb 2-1.1.4: new high-speed USB device number 7 using ehci_hcd
[    3.706960] usb 2-1.1.4: New USB device found, idVendor=05e3, idProduct=070e
[    3.706965] usb 2-1.1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[    3.706968] usb 2-1.1.4: Product: USB Storage
[    3.706971] usb 2-1.1.4: SerialNumber: 000000009317
[    3.892739] scsi12 : usb-storage 2-1.1.4:1.0
[    4.894528] scsi 12:0:0:0: Direct-Access     Generic  STORAGE DEVICE   9317 PQ: 0 ANSI: 0
[    4.895210] scsi 12:0:0:1: Direct-Access     Generic  STORAGE DEVICE   9317 PQ: 0 ANSI: 0
[    4.896003] scsi 12:0:0:2: Direct-Access     Generic  STORAGE DEVICE   9317 PQ: 0 ANSI: 0
[    4.896722] scsi 12:0:0:3: Direct-Access     Generic  STORAGE DEVICE   9317 PQ: 0 ANSI: 0
[    4.960654] sd 12:0:0:0: Attached scsi generic sg2 type 0
[    4.960884] sd 12:0:0:1: Attached scsi generic sg3 type 0
[    4.961019] sd 12:0:0:2: Attached scsi generic sg4 type 0
[    4.961154] sd 12:0:0:3: Attached scsi generic sg5 type 0
[    4.966637] sd 12:0:0:0: [sdb] Attached SCSI removable disk
[    4.967289] sd 12:0:0:1: [sdc] Attached SCSI removable disk
[    4.967886] sd 12:0:0:2: [sdd] Attached SCSI removable disk
[    4.968539] sd 12:0:0:3: [sde] Attached SCSI removable disk
[    6.714678] systemd-udevd[8455]: starting version 189
[    8.491188] input: PC Speaker as /devices/platform/pcspkr/input/input6
[    9.257357] i801_smbus 0000:00:1f.3: SMBus using PCI Interrupt
[    9.542121] mei 0000:00:16.0: setting latency timer to 64
[    9.542195] mei 0000:00:16.0: irq 65 for MSI/MSI-X
[    9.553617] mei 0000:00:16.0: wd: failed to find the client
[    9.594192] firewire_ohci 0000:08:03.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[    9.619195] e1000e: Intel(R) PRO/1000 Network Driver - 2.1.4-k
[    9.619197] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[    9.619217] e1000e 0000:00:19.0: setting latency timer to 64
[    9.619298] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    9.619327] e1000e 0000:00:19.0: irq 66 for MSI/MSI-X
[    9.878080] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) f4:6d:04:44:1f:53
[    9.878082] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    9.878116] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
[   11.024363] ACPI Warning: 0x0000000000000540-0x000000000000054f SystemIO conflicts with Region \_SB_.PCI0.SBRG.GPBX 1 (20120913/utaddress-251)
[   11.024368] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   11.024369] ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \_SB_.PCI0.SBRG.GPBX 1 (20120913/utaddress-251)
[   11.024371] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   11.024372] ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \_SB_.PCI0.SBRG.GPBX 1 (20120913/utaddress-251)
[   11.024375] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   11.024375] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   11.063285] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[   11.109313] iTCO_vendor_support: vendor-support=0
[   11.121492] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
[   11.121556] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[   11.121671] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   11.160351] microcode: CPU0 sig=0x206a7, pf=0x2, revision=0x14
[   11.173696] microcode: CPU1 sig=0x206a7, pf=0x2, revision=0x14
[   11.173892] microcode: CPU2 sig=0x206a7, pf=0x2, revision=0x14
[   11.174082] microcode: CPU3 sig=0x206a7, pf=0x2, revision=0x14
[   11.174283] microcode: CPU4 sig=0x206a7, pf=0x2, revision=0x14
[   11.174473] microcode: CPU5 sig=0x206a7, pf=0x2, revision=0x14
[   11.174675] microcode: CPU6 sig=0x206a7, pf=0x2, revision=0x14
[   11.174838] microcode: CPU7 sig=0x206a7, pf=0x2, revision=0x14
[   11.175059] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[   11.221221] asus_wmi: ASUS WMI generic driver loaded
[   11.221603] asus_wmi: Initialization: 0x0
[   11.221620] asus_wmi: BIOS WMI version: 0.9
[   11.221648] asus_wmi: SFUN value: 0x0
[   11.221847] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input7
[   11.222297] asus_wmi: Disabling ACPI video driver
[   11.371835] Bluetooth: Core ver 2.16
[   11.371843] NET: Registered protocol family 31
[   11.371844] Bluetooth: HCI device and connection manager initialized
[   11.371847] Bluetooth: HCI socket layer initialized
[   11.371849] Bluetooth: L2CAP socket layer initialized
[   11.371851] Bluetooth: SCO socket layer initialized
[   12.842162] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   12.842244] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  310.19  Thu Nov  8 00:52:03 PST 2012
[   13.200466] usbcore: registered new interface driver btusb
[   13.257790] kvm: disabled by bios
[   13.265940] kvm: disabled by bios
[   13.689931] snd_hda_intel 0000:00:1b.0: irq 67 for MSI/MSI-X
[   13.921720] NVRM: GPU at 0000:01:00: GPU-f32a2e0a-597b-ecee-a661-72bcd2512baa
[   13.921725] NVRM: Your system is not currently configured to drive a VGA console
[   13.921726] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[   13.921727] NVRM: requires the use of a text-mode VGA console. Use of other console
[   13.921728] NVRM: drivers including, but not limited to, vesafb, may result in
[   13.921729] NVRM: corruption and stability problems, and is not supported.
[   14.039132] hda_intel: Disabling MSI
[   14.039138] hda-intel: 0000:01:00.1: Handle VGA-switcheroo audio client
[   14.258034] Error: Driver 'pcspkr' is already registered, aborting...
[   14.469075] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[   14.469161] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[   14.469243] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[   14.469325] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[   14.546079] firewire_core 0000:08:03.0: created device fw0: GUID 001fc60000124583, S400
[   18.487448] EXT4-fs (dm-0): re-mounted. Opts: (null)
[   18.666733] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[   18.697113] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   22.333148] fbcondecor: console 1 using theme 'sabayon'
[   22.366441] fbcondecor: switched decor state to 'on' on console 1
[   22.401291] fbcondecor: console 2 using theme 'sabayon'
[   22.434522] fbcondecor: switched decor state to 'on' on console 2
[   22.469188] fbcondecor: console 3 using theme 'sabayon'
[   22.502435] fbcondecor: switched decor state to 'on' on console 3
[   22.537113] fbcondecor: console 4 using theme 'sabayon'
[   22.570337] fbcondecor: switched decor state to 'on' on console 4
[   22.605027] fbcondecor: console 5 using theme 'sabayon'
[   22.638369] fbcondecor: switched decor state to 'on' on console 5
[   22.673048] fbcondecor: console 6 using theme 'sabayon'
[   22.706257] fbcondecor: switched decor state to 'on' on console 6
[   22.740893] fbcondecor: console 7 using theme 'sabayon'
[   22.774100] fbcondecor: switched decor state to 'on' on console 7
[   22.808729] fbcondecor: console 8 using theme 'sabayon'
[   22.841909] fbcondecor: switched decor state to 'on' on console 8
[   22.876634] fbcondecor: console 9 using theme 'sabayon'
[   22.909837] fbcondecor: switched decor state to 'on' on console 9
[   22.944517] fbcondecor: console 10 using theme 'sabayon'
[   22.977727] fbcondecor: switched decor state to 'on' on console 10
[   23.012481] fbcondecor: console 11 using theme 'sabayon'
[   23.045704] fbcondecor: switched decor state to 'on' on console 11
[   24.092332] Adding 18546684k swap on /dev/mapper/vg_davesabayon-lv_swap.  Priority:-1 extents:1 across:18546684k
[   26.663250] fbcondecor: switched decor state to 'off' on console 6
[   26.935408] fbcondecor: console 6 using theme 'sabayon'
[   26.938191] fbcondecor: switched decor state to 'on' on console 6
[   27.664049] NVRM: GPU at 0000:01:00: GPU-f32a2e0a-597b-ecee-a661-72bcd2512baa
[   28.028132] 8021q: 802.1Q VLAN Support v1.8
[   28.183203] e1000e 0000:00:19.0: irq 66 for MSI/MSI-X
[   28.284104] e1000e 0000:00:19.0: irq 66 for MSI/MSI-X
[   31.617480] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[   32.350783] NET: Registered protocol family 10
[   35.233510] w83627ehf: Found NCT6776F chip at 0x290
[  545.466487] ata5.00: failed to get Identify Device Data, Emask 0x1
[  545.474185] ata5.00: failed to get Identify Device Data, Emask 0x1
[  545.474190] ata5.00: configured for UDMA/133
[  545.474201] ata5: EH complete
[  547.624538] EXT4-fs (dm-0): re-mounted. Opts: commit=0
[  547.627559] EXT4-fs (sda3): re-mounted. Opts: commit=0
[  548.498525] EXT4-fs (dm-1): re-mounted. Opts: commit=0
[ 1575.325567] operapluginwrap[11916]: segfault at 7fc171abf344 ip 00007fc171abf344 sp 00007fc1672a9df0 error 14
[ 1584.165470] operapluginwrap[11937]: segfault at 7fcb509b4344 ip 00007fcb509b4344 sp 00007fcb4619edf0 error 14
[ 6039.015660] traps: mediatomb[22850] general protection ip:7f05eec4f35c sp:7f05d8ff7c28 error:0 in libavutil.so.51.22.1[7f05eec41000+1c000]
[ 6476.973555] traps: mediatomb[23190] general protection ip:7fbf7a92035c sp:7fbf64dcac28 error:0 in libavutil.so.51.22.1[7fbf7a912000+1c000]
Shall I try to open a bug in bugzilla? I looked at this the other day, but it wasn't very clear how I should go about it...?
gd8
greendave8
Postby Thev00d00 » Sun Jan 20, 2013 15:47
Try running it in debug mode (-D) and post the log. I think this is because of an ffmpeg thing.
You can report bugs at bugs.sabayon.org -> log in with your forum details.
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby greendave8 » Sun Jan 20, 2013 16:00
So far no joy.... I think you are right about ffmpeg though...
Here is the log -D
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/hplip-3.12.11/ip -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/hplip-3.12.11/copier -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/kde4 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/kde4/services -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/22x22 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/22x22/apps -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/24x24 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/24x24/apps -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/48x48 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/48x48/apps -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/32x32 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/32x32/apps -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/16x16 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/icons/hicolor/16x16/apps -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/applications -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/share/pixmaps -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/lib -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/lib/kde4 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/lib64 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/lib64/kde4 -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Desktop/usr/bin -> /home/christine/Desktop wd=3169
2013-01-20 14:57:08   DEBUG: [../src/tools.cc:1059] normalizePath(): Normalizing path: /home/christine/Game of Thrones Series 1
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:203] threadProc(): adding recursive watch: /home/christine/Game of Thrones Series 1
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:376] watchPathForMoves(): adding move watch: /
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:376] watchPathForMoves(): adding move watch: /home
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:376] watchPathForMoves(): adding move watch: /home/christine
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2 -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.s02e02.720p.WebRip-x264.mp4 -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.S02E03.720p.HDTV.x264-IMMERSE -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.S02E01.720p.HDTV.x264-IMMERSE -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.S02E04.REPACK.720p.HDTV.x264-AVS -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.S02E05.720p.HDTV.x264-IMMERSE -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.S02E08.720p.HDTV.x264-IMMERSE -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 2/Game.of.Thrones.S02E06.REPACK.720p.HDTV.x264-2HD -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/zmmf/base_queue.h:87] resize(): resizing 67 -> 100
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/A Game Of Thrones Audio Book -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/A Game Of Thrones Audio Book/AudioBook George RR Martin -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/A Game Of Thrones Audio Book/AudioBook George RR Martin/A Storm of Swords -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/A Game Of Thrones Audio Book/AudioBook George RR Martin/A Clash of Kings -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/A Game Of Thrones Audio Book/AudioBook George RR Martin/A Feast of Crows -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/A Game Of Thrones Audio Book/AudioBook George RR Martin/A Game of Thrones -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/autoscan_inotify.cc:664] monitorDirectory(): getting start point for /home/christine/Game of Thrones Series 1/G.o.T Ser 1 -> /home/christine/Game of Thrones Series 1 wd=3314
2013-01-20 14:57:08   DEBUG: [../src/zmmf/base_queue.h:87] resize(): resizing 100 -> 150
2013-01-20 14:57:08   DEBUG: [../src/zmmf/base_queue.h:87] resize(): resizing 150 -> 225
2013-01-20 14:57:08   DEBUG: [../src/zmmf/base_queue.h:87] resize(): resizing 225 -> 337
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:747] _rescanDirectory(): start
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/The.Hobbit.2012.DVDScr.XVID.AC3.HQ.Hive-CM8
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Argo 2012 DVDscr Xvid Ac3-ADTRG
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Django Unchained 2012 DVDscr XviD AC3 - ADTRG
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Blackadder Remastered The Ultimate Edition DVDRip x264-BOB
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Greys.Anatomy.S09E01.720p.HDTV.X264-DIMENSION
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/The Secret of Crickley Hall.pt1.hannibal
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Elementary.S01E01.720p.HDTV.X264-DIMENSION
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Sket 2011 DVDRIP XVID AC3 BHRG
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/The.Doors-Collection
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Starlings.S01E06.720p.HDTV.x264-BiA
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Bill Hicks Collection
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Prime-Dvdrip-Xvid-MRFIXIT
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Merlin_2008.5x05.The_Disir.720p_HDTV_x264-FoV
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Lindsey Buckingham - One Man Show (2012)
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Prometheus.2012.R5.DVDRip.XviD-4PlayHD
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:821] _rescanDirectory(): Rescanning location: /home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1522] _recursiveRemove(): start
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1429] _removeObjects(): SELECT "a"."id","a"."persistent","o"."location" FROM "mt_autoscan" a JOIN "mt_cds_object" o ON "o"."id"="a"."obj_id" WHERE "o"."id" IN (548060)
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1434] _removeObjects(): relevant autoscans!
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1666] _recursiveRemove(): end
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1672] _purgeEmptyContainers(): start upnp: ,548031; ui:
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1710] _purgeEmptyContainers(): upnp-sql: SELECT "a"."id", COUNT("b"."parent_id"),"a"."parent_id","a"."flags" FROM "mt_cds_object" "a" LEFT JOIN "mt_cds_object" "b" ON "a"."id"="b"."parent_id" WHERE "a"."object_type"=1 AND "a"."id" IN ( 548031) GROUP BY a.id
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1783] _purgeEmptyContainers(): end; changedContainers (upnp): 548031
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1784] _purgeEmptyContainers(): end; changedContainers (ui):
2013-01-20 14:57:08   DEBUG: [../src/singleton.cc:73] registerSingleton(): registering new singleton... - 8 -> 9
2013-01-20 14:57:08   DEBUG: [../src/update_manager.cc:140] containersChanged(): signalling...
2013-01-20 14:57:08   DEBUG: [../src/update_manager.cc:215] threadProc(): threadProc: sleeping for 1763 millis
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:1258] addObject(): Adding: parent ID is -333
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part45.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part45.rar',805006011,'application/x-rar',548031,548064)
2013-01-20 14:57:08   DEBUG: [../src/content_manager.cc:1264] addObject(): After adding: parent ID is 548031
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:2370] flushInsertBuffer(): flushing insert buffer (1 statements)
2013-01-20 14:57:08   DEBUG: [../src/update_manager.cc:155] containerChanged(): containerChanged. id: 548031, signal: 0
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part45.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1429] _removeObjects(): SELECT "a"."id","a"."persistent","o"."location" FROM "mt_autoscan" a JOIN "mt_cds_object" o ON "o"."id"="a"."obj_id" WHERE "o"."id" IN (548061)
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part30.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part30.rar',1070512921,'application/x-rar',548031,548065)
2013-01-20 14:57:08   DEBUG: [../src/update_manager.cc:180] containerChanged(): last container changed!
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part30.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1429] _removeObjects(): SELECT "a"."id","a"."persistent","o"."location" FROM "mt_autoscan" a JOIN "mt_cds_object" o ON "o"."id"="a"."obj_id" WHERE "o"."id" IN (548062)
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part41.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part41.rar',800549823,'application/x-rar',548031,548066)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part41.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:1429] _removeObjects(): SELECT "a"."id","a"."persistent","o"."location" FROM "mt_autoscan" a JOIN "mt_cds_object" o ON "o"."id"="a"."obj_id" WHERE "o"."id" IN (548063)
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part38.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part38.rar',1079425297,'application/x-rar',548031,548067)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part38.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part02.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part02.rar',957924472,'application/x-rar',548031,548068)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part02.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part47.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part47.rar',807242681,'application/x-rar',548031,548069)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part47.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part19.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part19.rar',1004925458,'application/x-rar',548031,548070)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part19.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part29.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part29.rar',1043708401,'application/x-rar',548031,548071)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part29.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part20.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part20.rar',1033679672,'application/x-rar',548031,548072)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part20.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part24.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part24.rar',1029223484,'application/x-rar',548031,548073)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part24.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part17.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part17.rar',993785116,'application/x-rar',548031,548074)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part17.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part40.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part40.rar',799433726,'application/x-rar',548031,548075)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part40.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part34.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part34.rar',1066056733,'application/x-rar',548031,548076)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part34.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part37.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part37.rar',1067312350,'application/x-rar',548031,548077)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part37.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part44.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part44.rar',803889914,'application/x-rar',548031,548078)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part44.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part36.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part36.rar',1063828511,'application/x-rar',548031,548079)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part36.rar
2013-01-20 14:57:08   DEBUG: [../src/storage/sql_storage.cc:494] addObject(): insert_query: INSERT INTO "mt_cds_object" ("object_type","upnp_class","dc_title","resources","flags","location","location_hash","mime_type","parent_id","id") VALUES (2,'object.item','Lawless.2012.BRRip.part08.rar','0~protocolInfo=http-get%3A%2A%3Aapplication%2Fx-rar%3A%2A&size=15360000~~',1,'F/home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.part08.rar',964600178,'application/x-rar',548031,548080)
2013-01-20 14:57:08   DEBUG: [../src/layout/fallback_layout.cc:708] processCdsObject(): Process CDS Object: Lawless.2012.BRRip.part08.rar
2013-01-20 14:57:08   DEBUG: [../src/metadata/ffmpeg_handler.cc:279] fillMetadata(): Running ffmpeg handler on /home/christine/Deluge/Lawless 2012 BRRip XviD-BiDA/Lawless.2012.BRRip.XviD-BiDA.avi
Segmentation fault
It tells me nothing I understand...?
GD8
greendave8
Postby Thev00d00 » Sun Jan 20, 2013 16:04
Yeah it was ffmpeg based as I suspected, add that log to the bug you reported and assign it to the entropy team.
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby Thev00d00 » Sun Jan 20, 2013 19:05
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby greendave8 » Sun Jan 20, 2013 19:28
Hi Ian
Thanks for the attention and help, but how do I fix it on my system, or should I just wait for the next update? Thanks again
gd8 :)
greendave8
