error text appears when starting a terminal window [Solved]
Postby lupinehorror » Thu Dec 20, 2012 11:18
hi all.
just switched to sabayon from crunchbang...enjoying it so far.
however, when i open a terminal (using MATE version) the following text appears at the top (above the prompt)
bash: eval: line 28: syntax error near unexpected token `newline'
bash: eval: line 28: `Usage: lesspipe <file>'
everything works normally, all packages are up to date, but this always displays. any ideas? have never seen this before (on any distro).
thanks.
lupinehorror
Re: error text appears when starting a terminal window
Postby micia » Thu Dec 20, 2012 13:24
Hi, did you edit, by any chance, your .bashrc file or bash profile?
micia
Postby lupinehorror » Thu Dec 20, 2012 13:36
hi...
no but it would have been left over from my previous install as i use a persistant /home partition
.bashrc had this in it...
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
and commenting the second line out sorted it! thanks for pointing me in the right direction.
sabayon on my desktop - debian on my servers
lupinehorror
