[HowTo] Displaying packages needed to be updated
Postby Ryuno-Ki » Sat Dec 15, 2012 22:59
The following script works with equo-152 or higher.
#!/usr/bin/env bash
UPD="$(equo query updates)"
UP="$(echo $UPD|cut -d':' -f3)"
echo "$UP" packages needed to be updated!
I split the command, because equo needs some time for executing.
You can embed it into conky for example. Maybe you just want to print $UP.
Oh, and don't forget to make the script (here: .packageupdate.sh) executable:
chmod u+x .packageupdate.sh
Enjoy!
Ryuno-Ki
Re: [HowTo] Displaying packages needed to be updated
Postby svantoviit » Sun Dec 16, 2012 9:04
Hi Ryuno-Ki,
your script shows "Packages to remove". See below:
Before upgrade:
$ equo query updates
>>  @@ Available Updates
>>  Packages to update:  39
>>  Packages to remove:  42
$ packageupdate.sh
 42 packages needed to be updated!
After upgrade:
$equo query updates
>>  Packages to update:  0
>>  Packages to remove:  43
$ packageupdate.sh
 43 packages needed to be updated!
You actually need to get the second line line of the equo query output: "Packages to update".
Edit: So I altered the script a little bit
#!/bin/bash
UP="$(equo query updates | awk 'NR==2 {print $5}')"
...but you don't need to do anything like that, it's enough to run equo query with the -q argument for quiet output:
equo query updates -q
0
svantoviit
Postby Ryuno-Ki » Mon Dec 17, 2012 6:54
Oops!
Yes, you're right. Thanks for the hint!
Ryuno-Ki
