xbmc fails to start libGLU.so.1 [Solved]
Postby maulbongo » Mon Dec 10, 2012 9:26
Hi folks,
Since yesterdays update xbmc fails to start, it gives this error:
/usr/lib64/xbmc/xbmc.bin: error while loading shared libraries: libGLU.so.1: cannot open shared object file: No such file or directory
I found out that virtual:glu-9.0 seems to be a broken package, because theres nothing inside.
Before upgdating there was a symlink
/usr/lib64/libGLU.so.1
to
/usr/lib64/opengl/xorg-x11/lib/libGLU.so.1.3.09000
But after this update these files are missing.
fortunately I've got a testing machine and before updating there, I did a backup of
and
(which also is a symlink).
For getting xbmc to start again I put these two files (after update) to
/usr/lib64/
and now xbmc starts again.
So for all having this problems just start the sabayon 10 live dvd and copy these files to usb drive and then start your normal system and copy these two files to
/usr/lib64/
and xbmc should start again.
This problem has already been discussed here:
https://forum.sabayon.org/viewtopic.php?f=59&t=28575
greetings
maulbongo
maulbongo
