VLC failure [Solved]
Postby misty3 » Mon Dec 03, 2012 16:12
After latest upgrade, VLC will open but not play video. (3rd of December). Will play mp3`s OK. Is kernel 3.6-r3 and KDE. Installed Movie Player. It has no problem.
misty3
misty3
Re: VLC failure
Postby dunsurfin » Mon Dec 03, 2012 23:00
No problem here. KDE 32 bit kernel 3.6-r3. Have you tried different video formats or opening from CLI to see any error messages?
Self-righteousness is a loud din raised to drown
the voice of guilt within us - Eric Hoffer
dunsurfin
Re: VLC failure
Postby misty3 » Tue Dec 04, 2012 0:55
Got this.
VLC media player 2.0.4 Twoflower (revision 2.0.3-289-g6e6100a)
[0x22cd108] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Fontconfig error: Cannot load config file "infinality/conf.d"
[0x7fe5a4cc3c48] xcb_xv vout display error: no available XVideo adaptor
misty3
misty3
Re: VLC failure
Postby dunsurfin » Tue Dec 04, 2012 11:29
Your error message probably means something to someone else. All I can suggest is reinstalling VLC .
A google of xcb_xv vout display error: no available XVideo adaptor shows many people with the same error and some possible solutions. It may be worth looking at them.
dunsurfin
Re: VLC failure
Postby sabayonino » Tue Dec 04, 2012 14:00
infinality link seems broken or unlinked
check if you've installed
media-libs/fontconfig-infinality
and
app-admin/eselect-infinality
then use "eselect infinality list" to show full list
# eselect infinality list
and choose your prefer profile (I suggest "Linux")
# eselect infinality set <N>
to set ingfinality right links
Re: VLC failure
Postby misty3 » Wed Dec 05, 2012 4:13
Solved...thanks all. Not sure what fixed it. Did as Sabayonino suggested. No luck. Did reinstall. No luck. Went Tools/Preferences/Video/Output and started going through menu. When I selected X11 Video Output (XCB) vlc worked as it always has. Looks like Default, which is supposed to pick the best setting is not working properly. Did select different outputs yesterday before doing as Sabayonino mentioned but no luck. Probably a combination of both the above processes.
misty3
misty3
