Alternative to gthumb?
Postby cronotk » Thu Nov 29, 2012 22:35
Hi!
Since gthumb isn't in the repositories for whatever reason I'm looking for an alternative.
The single one feature that I absolutely need is to be able to run shell commands when pressing some hotkey on the currently selected image.
I've tried eog, shotwell and gwenview, but none of those seems to support that (or I just couldn't figure out how to do that with them).
Any suggestions?
cronotk
Re: Alternative to gthumb?
Postby Fitzcarraldo » Fri Nov 30, 2012 2:08
Would AutoKey or Easystroke suit your purposes? Either can be configured to execute a command or script when you press a hotkey. I'm lost without them.
Postby cronotk » Sat Dec 01, 2012 10:41
Hmm, it seems I haven't provided enough information in my post.
gthumb has a feature that you can assign actions to a set of hotkeys. Those actions are shell commands, but the special feature is that gthumb provides placeholders that can be used as parameter for those shell commands. For example I can bind the "0" key to the command "someprogram -a %F" then someprogram will be started like this: "someprogram -a /home/me/full/path/to/currently/selected/file.ext". It also has a few other placeholders (i.e. the current directory).
I'm mainly using this to keep track of files and running those commands from inside gthumb is the most comfortable way to do it that I have found. Of course I could open any image viewer and run the shell commands manually but that gets quite annoying after some time.
Regards!
cronotk
Postby lukazoid » Tue Dec 04, 2012 12:45
for me good alternative - geeqie , for show and see, maybe better gthumb. to SabayonX .
    sabayonh svi4ka # equo search geeqie
    >> @@ Поиск...
    >> @@ Пакет: media-gfx/geeqie-1.1 ветка: 5, [sabayon-weekly]
    >> Доступно: версия: 1.1 ~ tag: NoTag ~ версия: 0
    >> Установлено: версия: Не установлено ~ tag: N/A ~ версия: N/A
    >> Слот: 0
    >> Домашняя страница: http://geeqie.sourceforge.net/
    >> Описание: A lightweight GTK image viewer
    >> forked from GQview
    >> Лицензия: GPL-2
wallpaper SABAYON
MSI GT780DX : Intel Core i7-2670QM - NVIDIA GTX 570M/ 1,5GB GDDR5, RAM DDRIII 6GB, 17,3" FHD
lukazoid
Postby lukazoid » Wed Feb 13, 2013 21:17
very good, gthumb now to Sabayon
# equo search gthumb
>> @@ Поиск...
>> @@ Пакет: media-gfx/gthumb-3.0.2 ветка: 5, [sabayon-weekly]
>> Доступно: версия: 3.0.2 ~ tag: NoTag ~ версия: 1
>> Установлено: версия: 3.0.2 ~ tag: NoTag ~ версия: 1
>> Слот: 0
>> Домашняя страница: https://live.gnome.org/gthumb
>> Описание: Image viewer and browser for Gnome
>> Лицензия: GPL-2+
wallpaper SABAYON
lukazoid
Postby loverollingrelease » Fri Feb 15, 2013 17:47
Cool, thx for the suggestions guys...I was searching an alternative as well...now gthumb is available :)
loverollingrelease
