How to remove pulseaudio without removing kde [Solved]
Postby desputin » Wed Nov 28, 2012 21:29
I tried to remove pulseaudio because for some reason my external USB sound card only works well with alsa.
Anyway. If I remove PA KDE is removed too!!! This must be a bug or something but can anyone here tell me how to get rid of PA WITHOUT getting rid of KDE?
Best regards
Desputin
desputin
Re: How to remove pulseaudio without removing kde
Postby steffie » Wed Nov 28, 2012 22:51
some of your stuff have use flags about PA so you can not remove it
you can use --nodeps but than some stuf will not work :-)
solution is to notifi wich pakets are involfed and than emerge this without pa use flag, but this is horrible...
i think if you will have an gentoo without PA you must build a new world without useflag...
cu, hf, stephan
steffie
Postby Fitzcarraldo » Wed Nov 28, 2012 23:50
You just need to do the following as root user in a Konsole window:
mv /usr/bin/pulseaudio /usr/bin/pulseaudio.bak
and reboot.
Postby jmparhan » Thu Nov 29, 2012 1:18
Yeah had the same problem. Was tinkering around getting rid of some noise in VLC and removed pulseaudio...
My problems are solved, but there should be some way to get KDE without Pulseaudio and just Alsa, right?
jmparhan
Postby desputin » Thu Nov 29, 2012 8:18
Super, danke, das Umbenennen hat's gebracht!
desputin
Postby steffie » Thu Nov 29, 2012 8:28
Umbenennen ist zwar banal aber ne heftige frickellösung die noch mehr fehler in der messages bringt....
steffie
Postby Fitzcarraldo » Thu Nov 29, 2012 11:33
jmparhan wrote:Yeah had the same problem. Was tinkering around getting rid of some noise in VLC and removed pulseaudio...
Only if you use Gentoo. Not with SL, in which packages that have a build-time option for PulseAudio have been built with that option selected.
Postby Fitzcarraldo » Thu Nov 29, 2012 11:34
desputin and steffie, please post in English in the English-language SL Forums. If you prefer to post in German then you need to use the German-language SL Forum.
Postby steffie » Thu Nov 29, 2012 15:42
sry, will do so in future
steffie
Postby desputin » Thu Nov 29, 2012 20:49
Sorry, your're right :) I was in a hurry.
So:
Renaming the the pulseaudio file in the /usr/bin folder did the job!
Thanks!
desputin
