Qt libraries conflict: Can` t start kde apps. [Solved]
Postby Johnny Who » Sat Nov 24, 2012 18:43
A great deal of my kde apps keeps crashing on a regular basis and I do not know what is wrong. Moreover, I cannot run stellarium. The kde apps give this output (typically). For instance, when I run kturtle:
Cannot mix incompatible Qt library (version 0x40803) with this library (version 0x40802)
KCrash: Application 'kturtle' crashing...
KCrash: Attempting to start /usr/lib64/kde4/libexec/drkonqi from kdeinit
sock_file=/home/johnnywho/.kde4/socket-TOSH-SATELITEC66010C/kdeinit4__0
Warning: connect() failed: : No such file or directory
KCrash: Attempting to start /usr/lib64/kde4/libexec/drkonqi directly
drkonqi(27603): Unable to find an internal debugger that can work with the KCrash backend
[1]+  Stopped                 kturtle
When I run stellarium, I get the same:
Using default graphics system specified at build time:  raster
[ This is Stellarium 0.11.4 - http://www.stellarium.org ]
[ Copyright (C) 2000-2012 Fabien Chereau et al          ]
Writing log file to: "/home/johnnywho/.stellarium/log.txt"
File search paths:
  0 .  "/home/johnnywho/.stellarium"
  1 .  "/usr/share/stellarium"
Config file is:  "/home/johnnywho/.stellarium/config.ini"
Aborted
It is obvious that there is some kind of conflict in qt libs. What should I do?
Johnny Who
Re: Qt libraries conflict: Can` t start kde apps.
Postby Johnny Who » Sun Nov 25, 2012 20:48
 @@ Searching...
>>      @@ Package: x11-libs/qt-assistant-4.8.3 branch: 5, [__system__]
>>         Installed:     version: 4.8.3 ~ tag: NoTag ~ revision: 0
>>         Slot:          4
>>         Homepage:      http://qt-project.org/
>>                        http://qt.nokia.com/
>>         Description:   The Help module and Assistant application
>>                        for the Qt toolkit
>>         License:       GPL-3 LGPL-2.1
>>      @@ Package: x11-libs/qt-core-4.8.3-r1 branch: 5, [__system__]
>>         Installed:     version: 4.8.3-r1 ~ tag: NoTag ~ revision: 0
>>         Slot:          4
>>         Description:   The Qt toolkit is a comprehensive
>>                        C++ application development framework
>>      @@ Package: x11-libs/qt-dbus-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The DBus module for the Qt toolkit
>>      @@ Package: x11-libs/qt-declarative-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The Declarative module for the
>>                        Qt toolkit
>>      @@ Package: x11-libs/qt-gui-4.8.3-r1 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The GUI module for the Qt toolkit
>>      @@ Package: x11-libs/qt-multimedia-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The Multimedia module for the Qt
>>                        toolkit
>>      @@ Package: x11-libs/qt-opengl-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The OpenGL module for the Qt toolkit
>>      @@ Package: x11-libs/qt-qt3support-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The Qt3 support module for the Qt
>>                        toolkit
>>      @@ Package: x11-libs/qt-script-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The ECMAScript module for the Qt
>>                        toolkit
>>      @@ Package: x11-libs/qt-sql-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The SQL module for the Qt toolkit
>>      @@ Package: x11-libs/qt-svg-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The SVG module for the Qt toolkit
>>      @@ Package: x11-libs/qt-test-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The testing framework module for
>>                        the Qt toolkit
>>      @@ Package: x11-libs/qt-webkit-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The WebKit module for the Qt toolkit
>>      @@ Package: x11-libs/qt-xmlpatterns-4.8.3 branch: 5, [__system__]
>>         Slot:          4
>>         Description:   The XmlPatterns module for the
>>                        Qt toolkit
>>  Keywords:  x11-libs/qt
>>  Found:     14 entries
 @@ Searching...
>>         Slot:          4
>>                        for the Qt toolkit
>>         Slot:          4
>>         Slot:          4
>>         Slot:          4
>>                        Qt toolkit
>>         Slot:          4
>>         Slot:          4
>>                        toolkit
>>         Slot:          4
>>         Slot:          4
>>                        toolkit
>>         Slot:          4
>>                        toolkit
>>         Slot:          4
>>         Slot:          4
>>         Slot:          4
>>                        the Qt toolkit
>>         Slot:          4
>>         Slot:          4
>>                        Qt toolkit
>>  Found:     14 entries
Johnny Who
Re: Qt libraries conflict: Can` t start kde apps.[SOLVED]
Postby Johnny Who » Mon Nov 26, 2012 16:34
In the previous message I used that thread as a pastebin (sorry for that). The problem was solved with the great help of people in the irc channel. I had broken my system by mixing entropy with portage without masking packages.
Johnny Who
Postby Fitzcarraldo » Mon Nov 26, 2012 16:55
You need to click EDIT in your first post, not your last post. And it's "[Solved]", not "[SOLVED]". I'll do it for you this time. (And I've added the missing "[/code]" at the end of your second post.)
