Opera update not working correct.
Postby NoSavy » Fri Nov 16, 2012 21:54
Have system updated today including an update of Opera to version.12.10.1615. Rebooted and then tried Opera.
It would load, but it was not usable due to the menu bar "pulsating" for want of a better description. I renamed my home/.opera directory and tried again.
It then loads OK until I try to choose " show Menu", it then becomes unusable again. I have removed Opera cleaned everthing out and then re-installed and same problem occurs. Re-installed version.12.02.1578 for the present.
Any one else with problems.???
Thanks
NS.
Asus M4A79XTD EVO motherboard, AMD Phenom II X4 965 CPU, 4 GB ram.
Gigabyte NVIDIA 9800GT Silent graphics card, Dell FP2007 22 Digital Flat panel.
Samsung harddisks 2 x 200gb SP2004S,1 x Hitachi 750gb HDT 72107,Optiarc SATA DVD-RW. Sabayon 64 & 32bit.
NoSavy
Re: Opera update not working correct.
Postby Asimov » Mon Nov 19, 2012 21:40
Have you tried with a different desktop?
Asimov
Postby NoSavy » Mon Nov 19, 2012 22:33
@Asimov
Tried different desktop KDE themes, different Opera themes etc. but still not usable. I have now downloaded the same version from the Opera site and am using it from my home directory. Mostly everthing is working as it should although I think it's a regession from the previous version. Small niggles etc.
NS.
NoSavy
Postby Asimov » Sat Nov 24, 2012 17:25
I try the version of the repo. And it do not show any problems.
Asimov
Users browsing this forum: TDKyon and 1 guest
