Google Earth exiting on signal 11 SL 10 32bit [Solved]
Postby Johnny Who » Thu Nov 15, 2012 17:54
I have a 32 bit pc with sabayon 10, and googleearth won` t work. Running it from terminal revealed that it would exit on signal 11 and installing it through equo suggested that there may be a problem with video card drivers an a "Mesa lib". It also suggests creating a config file, but it won` t work. What should I do?
Johnny Who
Re: Google Earth exiting on signal 11 SL 10 32bit
Postby albfneto » Sun Nov 18, 2012 16:11
when you try to open it, Google Earth opens, and after ferw seconds, closed in trash? if thisis your problem , post here, because it is a Bug in Google Earth.
The solution, is imediate close the TIP OF DAY Window, then DEACTIVATE it in the options. It is know bug in all linux google earth, some versions.
albfneto@fcfrp.usp.br
Favorite Distros: Sabayon, Gentoo, Mandriva and OpenSUSE
Re: Google Earth exiting on signal 11 [SOLVED]
Postby Johnny Who » Sat Nov 24, 2012 18:45
I have fixed it. The tips work well and cause no problems. I just had to set my GPU to gallium mode.
Johnny Who
